Question about Unknown Vizio SB4020M-A0 Home Theater Sound Bar
I cannot get sound from my Vizio 2.0 40" sound bar after connecting to an LG5400 42" TV.
Soundbar works on other devices (laptop/phone), and headphone jack on TV works with headphones, they just don't work together. Also tried headphone input to soundbar and RCA cable to TV. Tried both connection combinations with TV speakers ON and OFF. Tried cycling inputs on soundbar, with the two different connections (RCA/headphones to soundbar/TV) with speakers ON and OFF. Tried different channels with those connection combinations as well. Still no sound.
I have a 42 Insignia TV and a Vizio 3821 sound bar. I also have Dish Network Hopper on this TV. I have tried all sorts of hook ups, but still no sound. Help
Soundbar & TV connection issues...Please Help!! - TV - Audio
www.tomsguide.com/answers/id.../soundbar-connection-issues.html
Aug 5, 2013 - the tv does have an optical output according to the website, it may just look hidden because ... I am trying(without success) to connect a JBL SB100soundbar to a Samsung ... Since your sound bar has an optical in then problem solved. .... a b x TV. August 5, 2013 10:32:42 AM. something like this should do ...
How to Connect a Soundbar to TV audio - YouTube
? 3:19
https://www.youtube.com/watch?v=Z27WtBy4IUs
Nov 22, 2013 - Uploaded by All About Home Electronics.com
The issue is not how to plug the cables in, it's all color coded and easy. ... I have a Sanyo sound bar but it won't connect to my LGtv nor my ps4!
Amazon.com: Sound Bars
Jan 10, 2016 | Vizio Televison & Video
The vizio amp speaker plugged into my tv and bluray player stopped outputting sound when watching a dvd and now only blinks in a set of light at the bottom. What does this mean and how can I fix it?
TV sound bar problem - Audio - Audio - Tom's Guide
www.tomsguide.com/answers/id-1991267/sound-bar-problem.html
Jan 23, 2014 - I recently purchased a Vizio E Series Razor LED 60" tv for my home, and ... The TV plays sound with built in speakers fine, ... on the source playingthrough the tv, if via hdmi, the soundbar would ... Alright I plugged it in but still nosound. ... the tv hooked up yet but my bluray player runs off HDMI and my xbox ...
No Sound Thru Speakers (only sound thru TV) - VUDU Forums
https://forum.vudu.com/showthread.php?...No-Sound...Speakers...sound...
Jun 18, 2011 - 10 posts - ‎8 authors
Just purchased and connected an LG wireless internet-ready TV to a receiver, a DirectTV HD DVR satellite box, and surround sound speakers. ... Cable, Blueray player, and others internet services, like Cinemanow provide ... because i have a Vizio Soundbar 210WS model, and i have to go into the TV ...
Jan 01, 2016 | Vizio VSB210WS Soundbar
Vizio sound bar won't turn on with tv
How to Fix the Vizio Soundbar ' Chron.com
smallbusiness.chron.com > Finances & Taxes > Other Finances & Taxes
Soundbar Won't Turn On ... Turn the volume up on the Vizio soundbar and also ensure the soundbar isn't muted. ... For example, even if the Vizio soundbar is connected properly, if the TV is set up to output through the internal speakers only, ...
Fix A Vizio Soundbar Remote In 4 Simple Steps ' Vizio TV ...
vizhdtv.com/fix-a-vizio-soundbar-remote-in-4-simple-steps/
Aug 25, 2015 - Each model of Vizio soundbar includes its own remote. It's what is ... Use the power button on the soundbar to turn it on. Then test ... So replacing thesoundbar won't resolve the issue if you have one of the effected models .
Nov 28, 2015 | Vizio Televison & Video
How do I connect my skullcandy headphones to my vizio sound bar ..... When I have the two in sync mode they don't connect to each other ...... How do I get them to connect to each other
I don't think you can connect the two because at least the headphones are not Bluetooth-enabled. Probably the soundbar is not Bluetooth-enabled either.
Dec 27, 2014 | Skullcandy Hesh 2 Headphones Grey/Gridlock...
Connecting a sound bar
Typically you will connect the RCA audio output jacks to the audio input jacks on the sound bar, but if your television does not have RCA audio output, you may have to buy additional hardware to make the soundbar work. If your TV has a headphone jack, then you will need to purchase an 1/8" Headphone connector to RCA Connector cable from a local electronics or audio store. If your TV doens't have any audio outputs, you may need to purchase a digital tuner box and connect it to your TV and soundbar.
Jul 19, 2014 | Sharp home theater system HT-SB300 User...
Vizio tv settings
You use to many word like clicks over . Please be more specific and use every day terms. How is the sound bar connected to tv. IE rca in , optical or what. Don't tell what you think happened just describe what happened.
May 09, 2014 | Televison & Video
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
How to connect a laptop 3.5mm audio out to a Vizio soundbar
You need a 1/8" stereo jack to rca....can get on at walmart....hook it from your headphone jack on your pc to the input on the sound bar....input 1 or 2....make sure you have the right iput selected for the sound bar and you should be in business
Mar 10, 2012 | Vizio VSB210WS Soundbar
I want to connect my mp3 player to either my soundbar or flat screen. How would i go about that?
Hi
You don't identify your make and model of MP3 player or your Flat Screen TV.
Some types of MP3 player can dock into a device (MP3 Dock) that has audio output connectors that can connect to either your TV or your Sound Bar with either standard stereo phono or HDMI cables (your TV has HDMI capability).
If no dock is available for your MP3 player, a stereo phono to 1/4 inch stereo jack will connect either audio Out or Headphone Socket to your TV or Soundbar. The sound quality may not be the best with this type of connection but it should be adequate.
A retailer like Radioshack, Best Buy, PC World, Maplin, etc. (depending on where you are) should stock these MP3 Docks and cables.
Hope this helps.
Aug 24, 2011 | Vizio VSB210WS Soundbar
Unknown Vizio SB4020M-A0 Home Theater Sound Bar Logo
53 people viewed this question
Top Unknown Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Unknown Audio Player and Recorder Expert? Answer questions, earn points and help others
