Question about Steamist 7522 TSG 7 Total Sense Steam Generator 7.5KW 240V 3PH 7522
Error code E 03
I have a TSG 7 Steamist unit only 1 year old getting a error code e 03 and unit will not work
2007 toyota camry cd player reading error 1
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
Jun 03, 2012 | 2007 Toyota Camry
The system was worming, producing steam and then quit working. The key pad does not work when the start/stop pad is depressed. The system is about 5 years old.
Contact company directly for product manual and troubleshoot help from manufacturer
http://www.steamist.com/contact.htm
Steamist comes with 5 year warranty, hopefully yours is still under the line.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail or phone while you work on Steamist or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 04, 2011 | Steamist Digital Timer Temp Control...
E6 Display on the control unit
You posted question under Steamist:
Sample Steamist manual says:
"Error messages E4, E5 and E6 indicate a communication problem with the steam generator. If this error occurs, check both ends of the control cable for clean, dry and secure connections.
Dirty contacts can be cleaned with alcohol and a cotton swab or a toothbrush. This can also happen if the control is not sealed and the cable connections get wet."
Error codes change as technology changes, and sample manual may not include your model:
Feb 22, 2011 | Steamist 11 KW Steam Unit SM11IM
I don't get any response from my Steamist Steamshower timer. No lights nor timer goes on
I am going to suggest contacting Steamist since they are the experts in this product.
My understanding is Steamist has 5 year parts warranty, and 3 year labor warranty, which is good warranty.
The contact e-mails includes 'literature' so you can order a manual, 'troubleshoot' so can get directions from the folks who make the product, and email for sales manager.
I would also inquire about authorized service center, and ask what is likelihood of getting long-term repair vrs buying another unit.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on any do-it-yourself project.
Feb 09, 2011 | Steamist Digital Timer Temp Control...
We have an E 13 code on our Steamist keypad.
1) Sample manual for Steamist does not show E13 error code
http://www.steamist.com/Downloads/pdf1/554-G.pdf
2) Another sample manual does not show error codes
http://www.steamist.com/Downloads/pdf2/572.pdf
3) Steamist website has contact us link: With direct e-mail to 'troubleshoot' and 'literature'
I suggest next step should be contact manufacturer and request each of the following: a) a manual b) do-it-yourself assistance c) warranty information d) name of authorized technician who can make repairs.
For a price, expert speaks with you over phone while you work on Steamist or any do-it-yourself project.
Feb 05, 2011 | Steamist SMS-20 NA Residential Heater...
I have a Steamist SM-8 and I am receiving an E4 error message on the control panel. What does this mean?
1) Steamist SM-8 is a Steambath steam generator with 5 year parts warranty and 2 years labor
http://www.faucetdepot.com/prod/Steamist-SM-8-IM-InstaMist-Steambath-Steam-Generator-29984.asp
2) Steamist website does not have manuals that we can immediately download and look at error codes alongside you.
3) However your manual has that information, and you can add a comment and say what the manual suggests as troubleshooting, so we can offer some level of do-it-yourself help.
4) Perhaps you could scan your manual into pdf format and post your manual on your website.
And then add a comment with web location of manual so we can download and read your manual, alongside you, and perhaps offer additional do-it-yourself solution for you.
For example check that circuit breaker is delivering 240V to product, and element is not burned out, and there are no loose wires, and condensing reservoir is not clogged with sediments that can be cleaned with CLR.
5) The manual is key: I'm sure the manual also shows regular maintenance needed to ensure long life of product. For example avoid exposure to hard water, use water filter, clean reservoir and lines regularly. Avoid freezing.
I always tell people to save product manual like gold and read it cover to cover because it will save money and trouble long-run.
6) Steamist website has contact us link: With direct e-mail to 'troubleshoot' and 'literature'
I suggest next step should be contact manufacturer and request each of the following: a) a manual b) do-it-yourself assistance c) warranty information d) name of authorized technician to make repairs.
For a price, expert speaks with you over phone while you work on steamer or any do-it-yourself project.
Feb 03, 2011 | Steamist Hardware & Accessories
The machine wont empty water gives a code of 03 I have cleaned the drain filter and check the drain hose still wont drain water unit is 1 1/2 years old
03 is drain error, as you know. The machine is sensing that the water isnt draining enough in 5 minutes...Unless there is an electronic problem the main reasons for the error code is because the drain hose is blocked, or the pump has something preventing it from turning, like a coin jammed in the impeller, or the pump motor itself needs to be replaced....These pump motors tend to get detritis in behind the impeller shaft seal and this often causes the pump to fail.....Good luck....Nomess
Jun 16, 2010 | LG WM2233H Front Load Stacked Washer /...
E1 error code
my AC is going on 5-6 years, it's never failed me until the years. The Error E1 code hes been coming on lately.
i wait a few MIN's, then try again. about the 7-10 tries the unit comes on.
1. what is a error code 1
please reply to:
Derrick holiday
Email.... euphoricsounz@gmail.com
thank you.
dh
Aug 03, 2009 | Samsung AW1293L Air Conditioner
More Error Codes
Try a lens cleaner - but yes time to put it out to graze I would imagine
May 11, 2007 | NEC MultiSpin ND-1100A (ND-1100A) DVD+RW...
Steamist 7522 TSG 7 Total Sense Steam Generator 7.5KW 240V 3PH 7522 Logo
Top Steamist Electrical Supplies Experts
ray gallant
Tom Chichester
Are you a Steamist Electrical Supply Expert? Answer questions, earn points and help others
