Question about Hotpoint-Ariston LFT 321HX Dishwasher
Lcode 1 flashes and drain pump doesn't stop
  • 75 Answers
The flash code means there is water in the base panel underneath appliance first check the support on your lower arm isn't loose then leave to dry out
Posted on Mar 27, 2014
I have a 1776 Asko model & it doesn't finish its cycle-code mesage f-2 keeps appearing. Can you help me out.
Hi
F2 is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Sep 18, 2011 | Asko 1375 Dishwasher
The second led is flashing. Water did nit drain at first. Then drained. Cannot press the start/reset button, nothing happens. Sounds like the pump was working, now doesn't seem to be. Help!!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 27, 2011 | Dishwashers
Maytag Model # MD87609AWB3 after rinse cycle it stops. I have to push button to finish drying cycle
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Maytag Dishwashers
Dishwasher started to wash then it stopped. Now there is water standing in the dishwasher and won't drain.
Hi
Daniel
Aug 22, 2011 | Kenmore 24 in. 16022 Built-in Dishwasher
Dishwasher will not empty water and has stopped Also a tap emblem has come on which I have not seen before
Hi
Daniel
Aug 16, 2011 | Neff 24 in. S5555X0GB Built-in Dishwasher
The dishwasher does not drain-- it leaves about 1-2" of water in the bottom after running a cycle
Hi
Daniel
Aug 16, 2011 | Dishwashers
Water doesn't drain
Hi
Daniel
Aug 03, 2011 | Maytag MDB8851 Built-in Dishwasher
Hi our Bosch exxcel washing machine has stopped spinning and doesn't reach the end of its cycle most of the time. If it does the washing is still soaking and needs a new rinse and spin cycle after....
Hi gillsteer,
I believe your drain pump filter is just clogged. The drain pump is trying to pump the water out before the Spin cycle, but can't. Usually this is caused by a foreign object that is obstructing the impeller. See my tip on how to access, drain & clean the Drain Pump Filter:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
After this, the Spin cycle will run, after the drainage procedure. If it does not, then you may need to replace the Drain Motor. Which is a easy task.
Kind Regards :-)
* If this solution helped you, please rate it
Jul 18, 2011 | Bosch Washing Machines
Hi i have an electrolux ewf 1087 that wont start everytime i press start it goes straight to drain, like from 2 hrs, it will go down to drain for 2 seconds then down to 0, if you turn it off then on again...
Here are two reset procedures for the control panel that might get your machine working again:
  1. Unplug the machine for about 1 minute. Plug it back in and check the machine's operation. If this doesn't work, try the next reset procedure.
or
  1. Turn the dial to Off.
  2. Press and hold the start/pause button and the nearest option button. While holding them down, turn the dial one notch clockwise.
  3. The machine will beep or flash, when it does let go of the buttons.
  4. After you release the buttons, turn the dial slowly, stopping at each click until you get to "off".
  5. Now, turn the dial to any setting, then turn to off.
  6. Check the machine's operation.
Jun 18, 2011 | Electrolux Washing Machines
Dishwasher stopped in the draining cycle and will not start back up, even after turning thye daqil to start a wash
Hi
Daniel
Jun 15, 2011 | Frigidaire 24 in. FDB221RF Built-in...
Hotpoint-Ariston LFT 321HX Dishwasher Logo
139 people viewed this question
Top Hotpoint-Ariston Dishwashers Experts
Owen Barnes
Are you a Hotpoint-Ariston Dishwasher Expert? Answer questions, earn points and help others
