Question about IBM G 96 (White) 19 in.CRT Conventional Monitor
IBM CRT Monitor - monitor off, red LED flashing
My monitor worked great for 4 years now, suddenly it didn't wanted to connect to the PC, although the Video Card was OK. The red LED was on so it isn't a problem with the power supply. It recovered in a few days then went off again. And now the red LED is flashing instead. I don't have any experience in repairing monitors, though I have repaired electronic appliances around the house like recorder, phones, washing machine and stuff... Can I fix it myself or do I really have to get a repairman?
  • 432 Answers
This monitor is worth $30.00. Trash it. http://www.etech4sale.com/IBM_6549_4AN_G96_19-Inch_White/G96/partinfo-id-119721.html
Posted on Jun 25, 2007
First years baby monitor Y7569P
That is due to some sort of electrical flux within the monitor CRT tube
Since the CRT tube has a very high voltage operation it may happen
You may have noticed similar noise coming out of any ordinary Tubelight condensers
Jul 15, 2013 | Computers & Internet
Tip
Monitor buying tips you should know.
Over the years monitors have transformed from those bulky CRT monitors to square LCD screens to stylish flat wide screen LCD's and now to new stylish extremely thin LED screens. On average every PC user spends at least 5 hours a day looking at the monitor. If the picture is fuzzy and not clear enough then there is a very high possibility that the eyes get damaged.
An older CRT monitor
A wide LCD monitor
A newer ultra flat widescreen LED monitor
Monitor Sizes
There are many different sizes of CRT, square LCD, wide LCD and wide LED monitors available on the market at the moment.
If you want an older CRT screen then sizes can range between 14" to about 20", they use the 4:3 aspect ratio.
If you want an older LCD screen then sizes can range from 15" to 19", they also use the 4:3 aspect ratio.
If you want a newer wide screen LCD then sizes can range from 18.5" to about 27" and even larger. They use the 16:9 if they are full HD or 19:10 if they are not ratio.
If you want a newer wide screen LED then sizes can range from 18.5" to about 27" and even larger. They also use the 16:9 if they are full HD or 19:10 if they are not ratio.
Image quality
The sharpness of the image in a monitor greatly depends on your Graphics card as well as whatever resolution you are running at. Nevertheless the quality of the monitor plays an important role.
Here are some of the tips that you should know before buying a monitor.
1. There are three types of monitors namely CRT, LCD and LED. The monitor that looks like a TV is a CRT monitor. In CRT monitors there is a Cathode Ray Tube that shoots electrons into the screen to create the image. An LCD monitor is smaller in width and consumes less power and is healthier if you are going to be spending large amounts of time at your PC. The LED screen looks the same as an LED monitor and the difference between it and the LCD is that it has a much higher contrast ratio resulting in darker blacks and much lighter whites.
3. A CRT monitor is much heavier than LCD monitor as you can imagine by it's bulky appearance. A LCD monitor is very lightweight and so is a LED monitor.
4. The distance between two adjacent pixels in a monitor is called 'dot pitch'. This is measured in millimeters (mm). Smaller the dot pitch the clearer the picture quality. Usually there are monitors with dot pitch varying between 0.20 mm to 0.27mm. Some manufacturers use diagonal dot pitch while most of them use horizontal dotpitch. The diagonal dot pitch is always longer than the horizontal dot pitch
5. Resolution of a monitor has to be considered with care. Most of the CRT monitors have resolutions of 800×600, 1024×768 and 1280x1024. The square LCD monitors have 1280×1024 and 1600×1200 resolutions. Newer wide screen LCD monitors have resolutions of 1600x1900, 1680x1050 and the Full HD 1920x1090. When the resolution is higher the images and text will appear smaller. But you can see more text and bigger pictures in the monitor with high resolution.
6. Another thing to note is the 'Refresh rate'. This rate is usually 60Hz, 73Hz, 75Hz, 85Hz. Refresh rate of 85Hz means the picture on the monitor is refreshed 85 times within a second.
7. The brightness and contrast can range between a low 5 000:1 to a high 80 000:1 in a LCD monitor and an average of 5 000 000:1 in a LED, yes that's 5 million to 1 with a LED. This just shows how much better a LED monitor is to a LCD.
8. If you are a gamer then the thing you have to look at with LCD monitors and LED monitors is the response time. If it is 16ms then this is a very bad monitor for gaming and you will experience a ghosting effect in most games and if it is 5ms then you will have an average gaming experience. What you want to get is a 2ms response time monitor, with it you will have the best gaming experience with no ghosting what-so-ever.
on Mar 06, 2011 | Computers & Internet
IBM Thinkpad R51 screen blacked out
try to plug in a extrernal monitor and see if that works if it does your backlight went out
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
Jul 21, 2009 | Computers & Internet
No Display on IBM G42 CRT Monitor's screen
if u change monitor . you came to know fault of monitor or cpu., if monitor works cpu is not woking properly..some itime we face same problem to creat by changining highgraphic. we can reduce graohic by using f8. re instiling xp we can solve that type of some problem.
Jun 15, 2009 | HP LP2065 (Silver) 20.1 inch LCD Monitor
Sir Help me with my Compaq monitor MV520 it won't turn the power led flashing orange to green continously
it could be th epower supply and it could be the monitor.
power ON button should not flash orange regardless what you do. it should stay green. then orange. not orange to green to orange.
try the monitor on another PC if you can fine one.
the other thing is are the 2 monitor similar (CRT to CRT and LCD to LCD), you can't mix the the two, they will work but need different video driver to function correctly.
Oct 20, 2008 | Compaq MV 540 15" CRT Monitor
Ibm 14"crt monitor white light is blinking screen is blank
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Oct 07, 2008 | IBM E54 15" CRT Monitor
Flashing Green Light on mx705 monitor
If the HP has onboard video but you have an add-on video card, remove the add-on and connect the monitor to the onboard vid. If it works you have a bad add-on video card. If it doesn't or you are already running on on-board video hook the mx705 up to a compatible HP. The older PB may be TOO old to handle it or not hve the correct drivers.
Feb 25, 2008 | HP mx705 17" CRT Monitor
Blank screen (led indicator is orange)
it could be the cable from the monitor to the pc it is defactive try a new one cuz if the monitor works then it is the cable that is makeing your screen go blank
Oct 10, 2007 | IBM E74 17" CRT Monitor
Flashing monitor
the ram itself is not related to your problem, but check the VGA lead connections at both ends and see if the connection is loose and also check the power cable. Other than that it may be the monitor circuitry or CRT itself thats the problem and after warming up the problem goes away, so a repair may be needed or a replacement monitor.
Jul 13, 2007 | Acer AC 713 17" CRT Monitor
LG Flatron 795FT - Led blinking
there is a step by step procedure 1.check the power cord. (try with a new one) 2.check the monitor on other pc, even if it is not working on the other pc, then carry to a service centre. 3.if it is working on the other pc then check the vga slot/card of your pc then 4.try to change the vga card and try connect an other monitor to your pc. so basing on this you will be able to trace the problem. 5.still the problem persists the consult the service centre.
Apr 05, 2007 | LG Flatron 795FT (White) 17" CRT Monitor
IBM G 96 (White) 19 in.CRT Conventional Monitor Logo
134 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
