Question about Gateway Profile 4 Notebook
Gateway DS Profile 4X
Not sure what is up. When I power on the pc, all I get is a "white" screen. It never loads up the BIOS or the OS. I cannot access the BIOS. It just powers on as "white" and that is all. Could this be a video thing or something else?
Windows 8 Gateway desktop trying to load Win7. I
Hi
You can try with Free Boot Managers and Multi-Boot Loaders you can find lot of free stuff available in online. So download and follow the instructions.
OSL2000 is an advanced multi boot manager you can install multiple OS in a Single PC.
Hope this will be helpful
Have a good day.
Regards
NANDU
Aug 28, 2013 | Gateway SX2865-UR11P Desktop Black
I have a gateway DS Profile 5X, a small spot appeared on the lower right on the screen and it is now expandig like an ink spot. What can I do to fix this problem?
New screen, I expect. That's the liquid crystal seeping out, especially if it's not some prank software someone installed. Can you test another screen? You didn't get one of those easygoing replacement warranties, did you?
Jun 06, 2011 | Gateway Profile 5.5 Desktop PC w/17"...
I have a gateway 400 VTX that powers on to the Bios screen then goes to another screen that says operating system not found. I have tried to load the os cd and it looks like its loadind and says windows is...
Sounds like u need to go into CMOS (System Setup) upon boot & make sure that the HARD DRIVE is the FIRST item in the BOOT ORDER and NOT your CD DRIVE. Also, make sure your Hard Drive shows up in the CMOS. If it does, then note what it says about the hard drive as it boots... If it is a bad hard drive, then nothing will install to it unless it is fixed or replaced.
Sep 22, 2010 | Gateway 400VTX-3501335 Notebook
Toshiba Satellite L300D Start shows the Toshiba screen except BIOS hotkeys are not listed at the bottom.. then a black screen with a white bar at the top left freezes and thats it. Taking the battery and...
Black Screen with White bar is when Windows Vista loading. So it seems there is maybe problem with Windows.
When your Toshiba is starting up - try press F12 to enter Bios, to check if everything is OK.
If you have Vista on CD/DVD - you can try press "C" on keyboard when Toshiba start, to boot from CD/DVD and start to repair your OS, or reinstall it completely.
Here - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/globalEntitlement.jsp you can find repair centre for Toshiba near you, so they can help you.
Support Contact Numbers:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/navShell.jsp?cf=su_contact&pf=true
Or use their forum
http://laptopforums.toshiba.com/t5/System-Recovery-and-Recovery/bd-p/brd_recovery
Sep 21, 2010 | Toshiba Satellite A60 Notebook
Powers on, Fan runs at high for 10Sec's then goes off, but no OS loading nor any visual activity on the Display.
your screen may be broken.
Do you see the BIOS message at the beginning of the boot up? If you don't, then the screen or the video card/circuit is dead
Mar 18, 2010 | Gateway 6520GZ Notebook
My computer wont load pass windows screen it just freezes and dont load???
do a power drain...take out the ac adapter and the battery and then press and hold down the power button for 1 min....
then go to the BIOS screen and set a BIOS default...
then do a bios update from your computer's manufacturer's homepage...
Oct 23, 2009 | Computers & Internet
Gateway 5228 wont boot no lights on keyboard
does it load the bios screen? Does it get to the windows load screens if it does go to the bios screen? Does the computer power on at all?
Sometimes what happens is the bios chip can be faulty or die and this will have to be replaced to fix the issue. If the computer is not powering on then it is more than likely a power supply issue.
(just in case, you might want to make sure that all of the adapters that come from the power supply are connected to the motherboard as well)
Sep 30, 2009 | Gateway Computers & Internet
Blank screen
When u power up the computer press "del" or F2 key then check your harddisk is detected or not.
Also load optimal defaults settings.
then restart the computer press F8 key then enter in enable vga mode.then change screen resolution to 1024*768.
Please let me know.
Jun 06, 2009 | Gateway 7330GZ Notebook
Os reinstall for gateway desktop 5094E
When you power on the computer, go into the BIOS and change the boot device order to boot from your cd. Then you should be able to install from your cd.
Dec 31, 2008 | Computers & Internet
Profile 5.5 during startup screen goes blank
If the video card is an "onboard type" Is is not easy to replace.If you have a seperate video card, you may replace it with a like type, PCI, AGP,PCIe,etc. or if you computer has an open slot a video card can be added and turn off the "onboard video" in start up screen BIOS .    Since this is a GATEWAY(I do not know the model) computer you also always have the option of a complete restore . Below is their website to download al the info:
Dec 29, 2008 | Gateway Profile 5.5 PC Desktop
Gateway Profile 4 Notebook Logo
59 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
