Question about Bissell 3750 Lift Off Bagless Upright Vacuum
Bissell 3750-t brush not working
Nothing happens when I switch the brush on. Trying to find out if its a motor or a switch problem.
reddevil6
  • 1673 Answers
SOURCE: Bissell Lift-Off(R) Revolution(R) Turbo Upright.
If you have a rubber smell, then the belt is slipping, does the brush roll turn freely while holding the ends? If not then replace it, part #2036619, if it is ok, then the belt has strectched and is slipping under load, part # 2106679, Style 8.
Posted on Jan 21, 2008
  • 33 Answers
SOURCE: brushes not turning on 8920 2x Bissell
Brushes are switched on by lowering the handle which activates a micro-switch located inside the lower part of the machine. Vacuum must be running as well. The DC power for the brush motor comes from a Bridge rectifier located on the PC board located in the handle. I have drawings that might help you.
petedcurtis@gmail.com
Posted on Jan 18, 2009
SOURCE: The Brush Motor on my Bissell Healthyhome Vacuum wont start
I had this same problem. There is a screw that holds the top handle and the lower handle "together". If this screw is not TOTALLY tightly screwed in, this will cause the contacts in the switch to BREAK contact, and therefore one or BOTH motors may not start, or cut in and out. This was the fix for me.
Posted on May 12, 2010
BissellCSR
  • 276 Answers
SOURCE: The brush in my bissell vacuum does not work
Follow the link below to the belt change instruction video on Bissell.com.
proheat
-2x/">http://www.bissell.com/how-to-videos/replace-brush-proheat-2x/
Posted on Nov 16, 2010
  • 3 Answers
SOURCE: BISSELL PROHEAT 2X 9200E - BRUSHES WON'T TURN
Hi there if u have already replaced the brush motor and the brushes stil aren't rotating, you wil need to also replace the circuit board that is located in the upper part of the machine after u take the 5 screws out the back, hope this helps, I repair bissells for a living so any problems email me, scottjones@rockfan.com
Posted on Feb 08, 2011
No power to Bissell 3750-E
I'd test the new fuse with a meter. I'd then plug it in and retest for power and ground to and through the switch and motor. It could be as simple as a loose or pinched wire which grounded out.
Dec 07, 2013 | Bissell 3750 Lift Off Bagless Upright...
Bissell 3750 bottom brush will not spin belt is fine and lift off works great
Hey Jessica! Please contact us for assistance regarding your vacuum.
Here's a quick link to assist you:
http://www.bissell.com/contact-us/?cid=ccsocial
Mar 04, 2013 | Bissell 3750 Lift Off Bagless Upright...
No power to brushes no result when brush switch activated
If you hear the brush moter running then the belt driving the roller has probably broken. It can be easily replaced by removing the brush plate underneath and pulling the roller out. Replacement belts are available on-line or may be available in hardware stores.Fit the new belt over the steel motor spindle first, then place the belt over the roller and insert the roller.
The belt will break if the roller gets jammed, so buy 2 belts and keep one as a spare.
Mar 07, 2011 | Bissell 3750 Lift Off Bagless Upright...
I unscrewed the roller brush protective cover and removed the brush to clean it. Now the roller won't turn because the drive shaft is not turning. Is there a reset button or something?
I looked at the pictorial of this vacuum at this URL: http://middleeasten.bissell.com/images/UserGuides/3750.pdf
This shows the belt to slide on the motor drive pulley and also on the brush. If the brush is bound up on the two ends where it fits into the body of the vacuum, you would have a problem turning it. Please be sure the end pieces are clean and if possible, spray with a little bit of WD40. Replace the brush and belt according to the picture in the URL and it should work fine. Please contact me if you have questions or experience more problems. Paul
Sep 15, 2010 | Bissell 3750 Lift Off Bagless Upright...
Bottom brush will not turn.
Did you check the drive belt? There are (Ithink) 4 screws underneath that you must remove to access that belt. It's likely the cause of your problem. Iether that or a build up of other gunk there.
Jun 03, 2010 | Bissell 3750 Lift Off Bagless Upright...
My bissell ran over the cord and stopped sucking
The belt probably broke or stretched and that is why it stopped working. Here is the belt you need:
Bissell Lift Off Belts
Feb 07, 2010 | Bissell 3750 Lift Off Bagless Upright...
Brush motor quit
The beater bar belt is broken.
Nov 18, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissell 3750 Lift Off Bagless Upright Vacuum Logo
35 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
