Maddog External Harddrive Enclosure not recognized by computer
I have a Maddog Multimedia USB2.0 external harddrive enclosure. It usd to work at one point, but is not anymore. When I plug it in to the computer, I get the sound effect of my computer registering that it is there. It is not listed as a storage devide such as G:\\. I cannot get access to the files. Should I try to download a new driver. I have not done that yet.
  • Anonymous Jan 19, 2009
    I too have the same problem. Put in a 40g hd that worked at first and then quit. Have also put in a 30g hd to try and get it to work but to no avail. Changed jumper settings to set as slave but did not work.
  • Mark Robinson May 11, 2010
    does the drive show up in computer management ? (under administrative tools in control panel) if so does the drive say raw data format ?
  • 4 Answers
I realize the above questions are almost a year old but someone may try to research this at a later time so I thought I'd throw in my two cents.I have the Maddog Multimedia USB2.0/eSATA external harddrive enclosure which I connected to my computer last night but could only get it to appear as a "USB device" to my computer (in control Panel-System-Device Manager). It would not appear under Computer management so I could not force a drive letter on it and it would not appear in Windows Explorer. I removed the Seagate 1TB drive from the enclosure and connected it to my computer without an enclosure using an IDE/SATA interface I bought for another purpose. The drive worked fine. Today I took another look at the situation - I was going to try another drive in the MadDog enclosure to see if that worked but instead decided to reinstall the Seagate 1TB into the enclosure and try again. Same result until...I started reading through the comments above which forced me to look closer at the back of the device. That's when I remembered the device has a physical switch in the back for eSATA vs USB. I hadn't used this device in many months and my eSATA card has never worked on external drives so I forgot about it. sure enough I powered down the drive, flipped the switch to USB an powered up again. Problem solved. I am not new to this stuff but even experienced users can make a silly mistake. I only hope your issues are as easily solved.
Posted on Apr 29, 2010
I had the same problem. My Fix was to use BOTH the USB Data Cable and the USB-to-Power cable. When I first started using it, it worked the USB alone. After a couple of days, however, it failed to power up. The Blue MadDog lable on the front wouldn;t light up, and when holding the unit to my ear, the spindle was not rotating. After finding a USB-to-power cable, which came with the unit, and hooking it up along with the data cable, the unit functioned fine. What sucks is that this uses up 2 USB ports. I have seen some USB cords with two leads that will branch POWER ONLY to one of them but then you end up with low performance and a rats nest of cables.
Posted on May 12, 2009
My desk top computers screen went black, can my data be save on the hard drive and how can i take it off
Not posting the model number of the Dell desktop computer, get's you generic information.
The model number can be found on the back of the computer, next to the Windows product key.
Moving on......
Suggest use an external enclosure.
Remove the harddrive from the computer, and install it in an external enclosure.
The external enclosure has a USB cable, and you just plug it into any available USB port, on a working computer.
Then go to My Computer, or Computer; depending on which Windows operating system the computer has; and double-click on the drive letter that corresponds with the external enclosure.
(WinXP: Start > My Computer
Win Visa / Win 7: Windows logo button > Computer )
Examples of drive letters;
C: Drive = Harddrive of the computer you are using
D: Drive = Separate partition on the harddrive for Restore files, or is for the optical drive (CD/DVD drive)
E: Drive = Optical drive generally, but may be the drive letter that corresponds to a Removable Device.
The external enclosure you plugged in, is a removable device.
None of the above is 'etched in stone', except the C:Drive
Things change from computer to computer, and the way you may have it set up.
Easy way to know?
Before plugging in external enclosure, open My Computer, or Computer.
Look at what each drive letter corresponds to.
Now when you plug the external enclosure in, you will see the change; and know which drive letter corresponds to the external enclosure you just plugged in.
Double-click on the name next to the drive letter, that corresponds to the external enclosure you plugged in.
Go into My Documents, or Documents.
Again, depends on which version of Windows you have.
Win XP = Start > My Documents
Win Vista / Win 7 = Windows logo button > Documents
Now open each folder, until you get the personal files you want to keep.
Photos, music, videos, documents you have created, or downloaded.
You cannot remove programs, or applications. Just your personal stuff.
(You can, but that is for a separate discussion)
Also open Downloads.
(WinXP = Click on Start > My Documents > DOUBLE-click on Downloads.
Win Vista / Win 7 = Click on the Windows logo button (Start), click on Documents, click on Downloads.
Harddrives are measured in Width.
2-1/2 inches across for a laptop harddrive. 2.5 inches.
3.5 inches for a desktop harddrive.
Don't know what Dell this is again, don't have the model number.
Cannot tell you if the harddrive is an IDE (PATA) unit, or a SATA unit.
So you will need either a 3.5 IDE (PATA) external enclosure,
OR,
a 3.5 SATA external enclosure.
There are external enclosures that are 3.5 and IDE/SATA, also.
Basic examples,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1733195&CatId=2779
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3883498&CatId=2780
http://en.wikipedia.org/wiki/Parallel_ATA
http://en.wikipedia.org/wiki/Serial_ATA
Easy way to identify what type technology is used, for the harddrive in your computer; IDE/PATA, or SATA;
Power cable for an IDE/PATA harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#peripheral
Power cable for a SATA harddrive,
http://www.playtool.com/pages/psuconnectors/connectors.html#sata
For additional questions please post in a Comment.
Regards,
joecoolvette
Mar 29, 2013 | Dell Computers & Internet
SONY VAIO PCV R53 39 DS WON'T BOOT UP
Pull the harddrive out, install in an economical external enclosure.
The external enclosure has a USB cable.
Plug the USB cable into any available USB port, on a working computer.
Go to My Computer, or Computer; and double-click on the drive letter, that corresponds with the external enclosure.
(Actually with the harddrive in that external enclosure, it is now an external harddrive)
http://esupport.sony.com/US/p/model-home.pl?mdl=PCVR539DS&LOC=3#/howtoTab
It's an IDE harddrive. Also known as a PATA harddrive.
A harddrive is measured across it's width.
2-1/2 inches across is a laptop harddrive.
3.5 inches across is a desktop harddrive. (3-1/2 inches)
So you need a 3.5 IDE (PATA) external enclosure.
One example,
Regards,
joecoolvette
Mar 26, 2013 | Sony VAIO Computers & Internet
WD 500G HDD suddenly un-readable; changed name to local disk, says I need to format in order to use it. I have tons of important stuff on there.
Could you confirm if the problem with the drive not being recognized is a problem with the USB cable? I have a 250GB passport and it worked fine with my XP. Once I decided to reformat it to NTFS and tried to do so by plugging into my new windows7 laptop the problems started.
Aug 21, 2011 | Western Digital My Passport Essential...
My lacie drive fell off desktop and is not recognized as readable by my Mac. What chance do I have of recovering the data?
Inside that LaCie external harddrive's enclosure is a regular SATA harddrive.
The kind that fits in a desktop computer (3.5 inches in width), or laptop. (2.5 inches across in width)
Open the external enclosure (Case) of the LaCie, remove the harddrive, and install it into a suitable external enclosure.
(Laptop size, or desktop size)
The external enclosure has a USB cable also. Just plug it into any available USB port on your desktop computer.
Do I know for a fact that the harddrive is okay, and this will fix the problem?
No sir/maam I do not.
But IMHO this is the first diagnostic method to use.
IF the harddrive is a desktop sized harddrive, it could be installed in your desktop computer as a Slave drive.
However the above method is so much easier, and it allows your harddrive to be an external harddrive once more.
Inside the external enclosure of the LaCie external harddrive, is a small circuit board that the Harddrive plugs into.
It is this small circuit board that receives the damage in most cases.
If the problem is the Harddrive itself, a professional data recovery shop will;
A) Try a new, or good used harddrive circuit board.
Check to see if the harddrive's circuit board received the damage.
B) If the circuit board proves to be good then the next step is to remove the Platters inside.
The room used is a Clean Room.
A room that is 99.9 percent dust free. (In most cases)
The Platters are installed into the case of a compatible harddrive, that has the Platters removed.
Then as much information as possible is copied off.
There are other methods data recovery specialists use also.
[A Harddrive is built in a Clean Room. 99.9 percent dust free. The technicians wear a Clean Suit, that resembles what a doctor would wear in an operating room.
They enter the work area after going through a corridor, fitted with air jets at various levels.
If a harddrive is opened up in a room that is not a Clean Room, the harddrive's 'life expectency' drops to a day, or a few hours. The dust 'kills' them ]
http://computer.howstuffworks.com/hard-disk.htm
http://www.youtube.com/watch?v=gpY8c7lT_7k&feature=related
http://www.youtube.com/watch?v=ax390l2A-AY
Observe the other videos also.
Examples of both a SATA 2.5 external enclosure, and a SATA 3.5 SATA enclosure,
(The Harddrive's width is measured in inches. (2-1/2 inches for a laptop drive, 3-1/2 inches for a desktop drive)
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
SATA 3.5 external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4421576&CatId=2780
Regards,
joecoolvette
Jul 02, 2011 | LaCie Hard Disk design by Neil Poulton...
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
My Lacie external hard drive used to turn on when the computer using XP was turned on. It has stopped doing this. Any suggestions to solve this?
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems hope this helps
Jun 12, 2011 | LaCie Computers & Internet
Seagate external harddrive with windows 98 OS
Remove (or take to your local computer shop) the Win 98 hard drive from the computer.
Put this drive in an external USB drive enclosure.
Plug this enclosure into a Windows XP vintage computer.
Copy the data to this computer.
Save Win 98 drive for posterity!
Regards,
GuruTim
Jan 04, 2010 | Dell Dimension 3000 PC Desktop
Having a similar problem with the La Cie 500gb. Powerbook G4.
The problem that has been inherent with all LaCie external harddrives, is the interface in the case itself.
Interface:
All external harddrives have a Style of harddrive that is used in a laptop, or one that is used in a desktop computer.
Laptop harddrives are 2-1/2 inches across in width.
Desktops are 3-1/2 inches across.
Your LaCie will have a 3.5, (3-1/2) inch desktop style harddrive, inside the case.
There are two main Types of harddrives.
IDE and SATA. (There is also a newcomer. SSD. SSD isn't being used in LaCie external harddrives at the moment, to my knowledge)
Your LaCie will use a SATA harddrive inside it.
This is an example of an average SATA harddrive,
http://en.wikipedia.org/wiki/File:Hdd.jpg
The photo of this harddrive is tilted at an angle, that doesn't readily show the interface connection, but it helps to explain.
At the bottom of this harddrive in the photo, and to the left, is the interface area.
Viewing the harddrive, look at the four metal pins on the extreme right of the harddrive. To the left of these pins is the Jumper pin area. (Has a white jumper on two of those pins)
To the left of the Jumper area is an opening, and to the left of that, is a long slot. The first small slot area is for the 7-pin Interface cable.
(Data cable) The next slot to the left, is for the 15-pin power cable.
This 7-pin Interface mates up to socket holes in a connector, of the case of the LaCie external harddrive.
It is this interface connector, inside the LaCie external harddrive case, that is the problem.
Solution?
Buy a quality, in-expensive External Enclosure, take the harddrive out of the LaCie, and install it in this enclosure.
Examples of 3.5 Sata External Enclosures,
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=2780&name=3.5-eSATA-enclosure&Nav=|c:2778|&Sort=0&Recs=10
(From $15 to $35, is a good range for a decent external enclosure)
Jul 22, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Bought harddrive enclosure
what is the make and brand ? of the enclosure and the hard drive
what method are you using to connect it to the computer and do you have an external power source hooked up for the enclosure
Robert
Aug 29, 2008 | Mad Dog Multimedia (MD16XDVD9) DVD±RW...
Computers & Internet Logo
2,170 people viewed this question
David Payne
David Payne
