Question about Western Digital WD My Passport Essential SE 1 TB USB 2.0 Portable External with WD Neoprene Carrying Case... Hard Drive
When i connect my WD passport 1TB USB 3.0 on my television or my car, we can't read it. But it's ok on the computer. What can we do ?
    New Friend:
What sort of computer do you have? mac is generally non-compatible with mainstream equip. does the hdd show up at all on the tv? If it does but you cant see any files, try removing the files from any folders, do you have any more info you can post?
Posted on Jan 01, 2013
SOURCE: dropped a WD passport drive, now it won't load. HELP!
Unfortunately, these drives are not made to be dropped.
It sounds like it was damaged by the drop which could have rendered the read/write heads inoperable or mis-aligned.
Contact Western Digital for a warranty replacement.
Posted on Apr 29, 2008
SOURCE: My PC is not recognizing my WD Passport 120GB USB external drive.
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter (http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=3770&name=USB_Hard_Drive_Adapter) and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Posted on Sep 18, 2008
zzptichka
  • 95 Answers
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it.
If not - try to remove the drive from the enclosure and connect it directly to the computer to recover your files.
Posted on Nov 30, 2008
I had the same issue. Its not a power issue because it shows up in device manager. Heres what I did.
Right-click on my computer and click Manage>Disk Management
Your drive should show up there. Right-click on it. If explore is not grayed out, assign a drive letter to it and you should then be bale to see it in my computer.
In my case explore was grayed out. I had to click on the option to format the drive. After re-formatting the passport explore was available. I then assigned a drive letter to it and I have access again.
I guess somehow using it on multiple computers srcewed up the file-system on it. I was using it between windows and linux.
This fixed my problem.
Posted on Jan 02, 2009
I had a similar problem with my WD passport 320GB. When I connected it to my laptop it never showed up on My Computer even though the blue light on the hard drive came on.
Here is what I did:  Right click on "My Computer" and click on "Manage" and then "Disk Management",. you should see your WD hard drive listed. then click on "change driver letters and paths"  and change it from the listed to another drive. I changed mine from G to F drive and it worked for me.
Posted on Mar 08, 2009
Recommend me branded USB drives ?
Honestly, any USB brand will cut it for you. What you want to ensure is that you are purchasing the proper version (1.0, 2.0, or 3.0) for whatever device the key will be associated with. Also make sure you don't buy too little or too much memory. But if you know all this and you just want a reliable brand, I would go with SanDisk.
Aug 04, 2015 | Computers & Internet
My WD 1TB my passport external hdd doesnt show up in my devices but the light is on and it makes a weird whirring sound, can this be fixed
You can download a program from WD called Data lifeguard Diagnostic for windows there is a floppy and a windows program. I made a bootable floppy and started my computer with the floppy and typed windlg.exe and followed the instructions...http://wdc.custhelp.com/app/answers/detail/a_id/1329/~/how-to-create-a-data-lifeguard-diagnostics-bootable-cd
Jan 01, 2013 | Computers & Internet
Hi, my ps3 won't recognise my 1tb wd external hard
The problem with the new 1Tb WD Passport that I just purchased is that it is a USB 3.0 format and apparently PS3 doesn't recognize that speed.
Haven't found a workaround for it yet, but all these people advising you to reormat anew Passport drive are wasting your time.
Jul 02, 2012 | Computers & Internet
My passport essential se 1tb can't show up on my tv,dvd or ps3
make sure u had formated the external hardisk and also see wehter your TV, DVD of PS3 support external drive or not
Nov 26, 2011 | Western Digital WD My Passport Essential...
My computer don't start after connect with my WD
From the FAQ section of the manual:
Q: Why won't my PC boot when I connect my USB drive to the computer before booting?
A: Depending on your system configuration, your computer may attempt to boot from your WD portable USB drive. Refer to your system's motherboard BIOS setting documentation to disable this feature or visit support.wdc.com and see Knowledge Base answer ID 1201. For more information about booting from external drives, refer to your system documentation or contact your system manufacturer.
I hope this helps! Please rate my reply. Thank you.
May 31, 2011 | Western Digital My Passport Essential SE...
The WD My Passport 1TB won't work on Windows after I formatted it for Mac.
You need to reformat it on windows. Plug it up then find it on your computer and format.
May 09, 2011 | Western Digital 1TB My Passport Essential...
My wd passport essential se is not being read by my computers it also making loud humming noise when i plug it in
I would return the Western Digital Passport Essential SE back to were you purchased it. Exchange it or get your money back. It is defective sounds like.
Jan 28, 2011 | Western Digital My Passport Essential SE...
Western Digital WD My Passport Essential SE 1 TB USB 2.0 Portable External with WD Neoprene Carrying Case... Hard Drive Logo
303 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
