Question about Vizio Televison & Video
My 32" vizio light indicates that it is on, but there is a black screen and no sound
Light indicates it is on, but black screen and no sound
  • Vizio Master
  • 8,617 Answers
Replace the main board very common problem with some vizio models. You can get a replacement main board from www.tvrepairworld.com
Posted on Jan 01, 2013
  • 92 Answers
SOURCE: No Screen or sound
there are two possibilities to this problem. First and cheapest way is to replace the main board. Second, replace the inverter board. This is the boards that are mounted vertically on both sides of the TV.
Posted on Jun 18, 2009
  • 92 Answers
SOURCE: I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
SOURCE: My Vizio 32 inch has a black screen. The Vizio
I have had the same problem. I called vizio they told me how to reset my tv. It did not help me, However, maybe it will help you. They said turn the power off, Unplug it hold in power button for 30 seconds then plug it back in and power it back up. My white light flickered and then nothing. So I am going to end up buying a new tv all together.
Posted on Oct 23, 2009
MLFnet
  • 328 Answers
SOURCE: Vizio plasma. screen went black, and the power light went out.
Sounds like the power suply went. I don't know that model off the top of my head, but you might find a replacement here http://www.electronica-usa.com/Merchant2/merchant.mvc?Screen=CTGY&Store_Code=EU&Category_Code=PLA
-=/ Daft Tech /=-
Posted on Oct 26, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Vizio VX32L and when I turn it on the screen flashes and
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Vizio+VX32L+
Please post back what you find.
Posted on Dec 16, 2009
Testimonial: "Thank you. I was checking them out."
Black Screen on Vizio E322Ar
Due to the cost of repairing this I would just replace the TV
Oct 12, 2016 | Vizio L32 32 in. LCD HDTV
I have a 32 vizio e320-a0 with a black screen with sound
probably the tv have problem with its back light, you have to check and replace the led driver. Che the video to more about back light.
Samsung TV Repair Part Number Identification Backlight Inverters LED...
www.electro-medical.blogspot.com
Sep 21, 2015 | Vizio E-series E320-A0 - 32" Class 31.5"...
How to fix black screen
Logic board fault. Replace it. If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 10, 2015 | VIZIO E320i B2 32 Inch 720p Smart
Vizio 420 screen black
if their is a light indicator in the front panel and with sound but the screen back light is totally black, the cause it could be the inverter board or the back light is bad.just let me know if it could help you.
Sep 01, 2012 | Televison & Video
Black screen on VOJ32o1A
Check and replace the back light inverter board. Check CCFL lamps too.
Jul 29, 2012 | Vizio VOJ320F1A 32 in. LCD TV
Vizio has sound but no picture.
Hello
The T'Con board [Timing Control Board] has damaged. This board can be located at the bottom side of the LCD panel. You have to open the tV, to take it out. There is no repair to this board, and only card basis replacement should be done. OK.
Feb 27, 2012 | Vizio VW32L 32 in. LCD HDTV
Screen black, front indicator light on. won't shut off, must unplug. Is there bulb to replace?
No bulbs to replace except for the CCFL's which is highly unlikely their causing the problem. If you have sound and no picture then either the inverter boards or power supply need repair or replacing. If there is no sound and no picture only the front indicator light is on then this is a power supply problem. It could also be the power supply is sensing a fault from another circuit and shutting its self down to prevent further damage too the TV and electrical fire hazards. The TV is in self-protect-mode because there's a OVP, OCP, detection on one of the circuits. OVP: Over Voltage Protection, OCP: Over Current Protection. This is a very common problem with Vizio LCD TV's so it shouldn't cost much to service this problem at your local shop.
http://tvtechwork.webs.com/
Nov 15, 2010 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
replace the sustainer boards should correct this problem. New sustainer boards may cause red and green pixilation. If this happen, replace control board and TV is as good as new.
Apr 05, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Televison & Video Logo
200 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
