Question about Bosch Dishwashers
Bosch sgs5002gb dishwasher not draining
Hi, I have had the Bosch SGS5002gb/01 for about 10 years it has worked perfectly until a few days ago when it would not drain and it left about 2 inches of water in the bottom of the unit,above the filter. I emptied the water using a cup, restarted it had flooded I leaned the dishwasher back to reset the pump. I ran it empty a couple of times without detergent and it worked fine. I loaded the washer and today tried it again and again it had not drained properly. Any ideas?
SOURCE: Bosch sgv53e13gb Integrated dishwasher - wont start a new cycle!?
Thanks for the input Dicky...I think my dad will be onto the place of purchase first thing tomorrow!!
Posted on Jul 13, 2008
  • 1462 Answers
SOURCE: bosch dishwasher regularly floods
fault is with dishwasher. even if drain blocked, would not cause overfill.
possibly the pipe to sump from fill mechanism partially blocked
Posted on Jul 18, 2008
ginko
  • 19396 Answers
SOURCE: Bosch shv56c03uc/114 Water is not draining
Check drain hose first.
If you do not find any blockage, then you will need to access the pump, remove pump hose and look for blockage in there.
If there is no blockage at all, then either the water level switch, a faulty pump, a wiring problem, or a faulty timer board can be cause the machine not draining.
Posted on May 21, 2009
SOURCE: Bosch Dishwasher wont drain
Crazy! I have the EXACT same problem....sounds like it wants to drain...but won't ...Water has been stuck in the bottom for days now
Posted on Jul 18, 2009
  • 1382 Answers
SOURCE: my bosch excell dishwasher won't drain it stops
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Many dishwashers use a drain valve with an electric solenoid. When electricity flows to the solenoid, the valve opens and diverts the water to the drain. Sometimes the solenoid, or the diverting lever, sticks and prevents the dishwasher from draining or filling properly. Try to free up the solenoid to lubricate the lever. Otherwise, you may have to replace the solenoid or pump assembly. With these systems, the motor always rotates in one direction. When it's energized, the drain valve diverts the water.
Other dishwashers simply reverse the direction of the motor to drain the dishwasher. These units don't have a drain valve. Instead, there's a drain hose connected directly to the pump housing.
Posted on Mar 22, 2010
Why is my Bosch SHE4AM15UC dishwashwer not heating water not sanitizing? How do I fix this problem?
The problem could be a failed heating element. If replacement of the control panel results in no change, the element could be the problem.
Jul 16, 2014 | Bosch SHE4AM15UC Dishwasher
My bosch dishwasher has a terrible from day one. I have tried running vinegar through a wash cycle. My dealer I need to run it a few times. I have had this machine for well over a year and still gives...
Hello and welcome to Fixya.
It "smells" ( just kidding ) like you might have a problem with the way your drain hose is connected by your description.
It is crucial that your Bosch dishwasher have a siphon break or "hi-loop" installed in the drainage between the dishwasher and where it enter's your homes plumbing.
If it does not you can try different cleaners until the cows come home with little effect because the odor is coming from the drain line itself.
Was this unit installed by yourself or someone you know ? Or was it installed by a plumber/professional installer.
In the end it actually makes little difference, I'm just curious. I see professional installers as well as plumbers fail to include this crucial feature over and over.
Let me know. I'll watch for your post. If you are unclear as to what I'm referring to, check your installation guide that comes with all Bosch dishwasher's.
If you do not have any instructions regarding the proper drain/install I can email you a copy, but I would need your email address.
Good luck.
macmarkus :)
Jun 17, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
I ned help finding a manual for a bosch dishwasher model sgs4012GB
i got the perfect answer. go to thermador.com they can order this for you. bosch, thermador and gaggenau is the same company. if this helps you post a 4 thumbs up post
Feb 21, 2010 | Bosch 24 in. SGS4072 Free-standing...
I have a 24" Bosch diswasher - water does not drain
I have the same problem with my she58 water does not drain. only 4 months old and repair man replace 3 diff parts ...same thing happen. Bosch send another company to repair..replace parts by parts. not working....almost 5 months now I don't have dishwasher...i have to call almost everyday to Bosch..to fight for it....couple of days ago customer support told me with in 10 days somebody would call me for the replacement....i have to wait and be back if i don't have heart attack..to tell if they really would replace...gemtx
Jul 26, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch dishwasher regularly floods
Jul 18, 2008 | Bosch 24 in. SHY56A05 Stainless Steel...
Bosch SHU5302UC/U06 dishwasher starts at 2H and eventually starts but continues for a long time at 1 without rinsing the dishes.
I had the same problem a few years ago and the tech replaced the control panel. No problems until....last night. Now a different problem.
Jun 17, 2008 | Bosch Dishwashers
Bosch Exxcel dishwasher "check light" indicator
**** out the water with a shop vac. Consult manual for self diagnosing keypad codes.
Jun 08, 2008 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
Bosch SGS5002GB/01 makes whirring noise but wont do a cycle
first thing comes to mind, switch off and restart choosing possibly another program.
Dec 03, 2007 | Bosch 24 in. SGS43C12 Classixx...
Dishwashers Logo
37 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
