Question about Vacuums
We need new motor brushes no 476 for our Hoover steamvac 5914
Our motor was arcing, we took it apart and the brushes may be bad but I can't find the number 476 brush on any site. Can you help?
  • Vacuums Master
  • 18,424 Answers
  • shardware241
    shardware241 Jan 01, 2013
    Thank you, that site has lots of information but can't find the exact brush..it might be a different Hoover part but this site was extremely helpful!
  • Les Dickinson
    Les Dickinson Jan 02, 2013
    please rate me thanks
SOURCE: brushes not rotating on hoover f7425-900 steamvac v2
I had the same problem and it was inside the turbine assembly. If you take the turbine assembly off the machine and open it up, you will see the turbine blades on one side and the reduction gears on the other side. The problem on mine was a needle bearing sandwiched between two washers on the reduction gear side. This bearing/washer stack is the stabilizer for the turbine gear shaft. Mine was rusted solid. I removed the washers and bearing and cleaned them up with a wire wheel being careful not to lose any of the tiny needles. Once evrything was rust-free, I reset the needles with grease and sandwiched the bearing between the washers. I then reinstalled this stack back in the case along with the other gears, regreased everything, and buttoned it up. Brushes are spinning better than they have in a long time.
Posted on Mar 22, 2008
reddevil6
  • 1673 Answers
SOURCE: HOOVER STEAMVAC F7425-900
There some screws off from the bottom, remove the top cover, the turbine has 2 screws on the front of it and there 2 long screws you take off from the bottom, remove the tubing and it should come loose. Some times you can take it apart and clean the inside parts and it will work ok, if that doesn't do it then you have to replace it.
Posted on Apr 07, 2008
SOURCE: brushes do not rotate
Sounds as though your drive belt has come off. Or you have an object stopping the brushes from rotating.
Posted on May 18, 2008
reddevil6
  • 1673 Answers
SOURCE: Belt replacement Hoover carpet cleaner
Hoover steamvacs don't use belts. If the brushes are not turning, pull the brush block out, turn the machine on and see if the square hole where the brush block was, is turning. If not then the turbine is bad. Sometimes you can take the turbine apart and clean it out. most times I have found , replace it.
Posted on May 26, 2008
  • 37 Answers
SOURCE: hoover turbine replacement
first you must remove the dirty water tank then the nozzle window on top of the machine. (this is the clear piece that the dirty water is sucked through.) then remove all 8 screws from the bottom along with the 1 screw on the main housing. after all this the top housing will be snapped into the base at two spots in the rear of the upper housing. when these are loose the housing should be out. you will find the turbine in the front along with 2 more screws and 2 hoses that also must come off. attach new part and reassemble.
good luck!!!
Posted on Sep 24, 2008
The brushes are not working.
We have a Max Extract 60 and when we turned it on the brushes did not work. My husband took the pieces for the brush motor apart and put it back together and then they worked fine. They must of been bound up or put together wrong. Works great now.
Dec 21, 2010 | Hoover F6055-900 SteamVac Maxextract LS...
Hoover F7458-900 SteamVac The brushes quit
My Hoover F7458-900 was doing the same thing, brushes not turning and since it is about 7 years old and out of warrenty I decided I had nothing to lose so I took it apart after reading all the other posts on this problem. The brushes are actually turned by a turbine motor (no belts involved) that runs off air produced by the vaccum motor of the unit. The air turns a metal spindle that then turns several nylon gears in the turbin the last of which turns the brushes. The nylon gear that engages with the metal spindle was worn down to the point that it was no longer engaging with it and thus not turning.
The only fix for this problem is to buy a new turbin motor which is not that expensive about $34 plus shipping since they don't sell just the nylon gear. Hope this helps
May 23, 2010 | Hoover F7205900 SteamVac V2 Wet/Dry Vacuum
I can't get my attachment to put out the solution
According to www.vacuumpartstore.com, for model #'s F5903, 5904, 5905, 5906, 5910, 5912, 5914, and 5915, you need Hoover SteamVac Bare Floor Cleaning Attachment (old # 48417003). You can get it at www.amazon.com for $7.99.
Jun 17, 2009 | Hoover F5826-900 SteamVac Upright Wet...
SteamVac won't **** up solution from carpet
here is the website for your particular model http://www.hoover.com/pdfs/manuals/F5914900.pdf however if you cant fix it from that since you said its new you should have your warrenty still call them to fix it the contact info is on that site
Godbless
Jun 16, 2009 | Hoover SteamVac F5914-900 SpinScrub...
My Hoover SteamVac spin scrub #5914-900 will not **** up solution
http://www.hoover.com/pdfs/manuals/F5914900.pdf here is the manual for your model try cleaning the vent inside the plastic container in the front of the machine if its new you may still be under warrenty and contact info for that is on the site above as well!
Godbless
Hoover steamvac brushes don't spin. everything else works great. Took it apart and no visible problems
my husband took it apart today and the impellers were gunked up with black stuff.
he used these pictures that someone else generously posted. ours was slightly different in internal design, but they are helpful regardless.
here is an exploded diagram of the 5903, 04, etc. it will help you see if any parts are missing or broken.
http://www.vacuumcleanershop.com/images/Hoover/F5903-900.GIF
parts list if you need some:
http://www.vacuumcleanershop.com/hvrmdlf5903.htm
it's working fine now. sucks much better too. what a difference!
guess for the $179 these things avg, they just need annual maintenance. I wouldn't pay someone to do it though.
Jan 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
May 24, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover Steam Vav & Spin Scrub #F5899-100
Sorry it is not belt driven. There is a turbine that drives the brush. You have to remove the top cover to get to it. But if the motor smells hot, then you may have a problem with it also.
Apr 18, 2008 | Hoover F7431-900 SteamVac Vacuum
Vacuums Logo
56 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
