What do i clean the drum with clean cloth or acholol
    Filmmaker:
    Uploaded 5 video answers.
  • 45 Answers
In most printers with a drum (I assume this is a laser printer) it is a user replaceable but, not a user serviceable part. You may be able to order a replacement drum but, you should not attempt to clean or otherwise service the printer drum.
Posted on Jan 02, 2013
There is a Black line on the Ricoh Aficio 3045 Drum Help for Remove ????
if you can clean the black line with a cloth, than you need just to replace the cleaning blade, but if the black line is not removing without a cloth, then you need to replace the opc drum and the cleaning blade or both blades, some machines of this type have only one cleaning blade but some have two cleaning blade.
Sep 28, 2016 | Ricoh Aficio Office Equipment & Supplies
Maytag dryer clothes gray soot around the drum and door
Sounds like drum belt is out of alignment and rubbing. Check the rotation/alignment with pulleys and drum. If belt is worn replace it. Hope this helps.
Feb 17, 2014 | Dryers
I am getting an error message drum full of waste toner, I'm not sure that is actually the drum how do I check?
the drum is the color green appear like tube this is where the image to be printed is formed clean this drum by simply wiping the waste toner use a soft cloth to clean it do not apply any chemicals just a cloth rotate the drum manually to get it clean thoroughly..
Aug 26, 2011 | Dell 3010cn Laser Printer
Why does my washing comes out with stains on it.... they weren't there when it went into the wash...
yes sometimes ink pens can be washed when we are not aware it was in someones pocket. I use straight ammonia and a cloth to clean my washing machine drum a couple times a year because these things have happened to me before. The ammonia will cut the grime and pen stains out of the drum. Then take a squirt bottle and fill it with white vinegar and squirt all around inside the drum of the machine. Run a wash without any clothes with the hottest water to clean the drum and clear out the stains. Do this to the dryer also and clean out the filters. Take the dispensers out from the washing machine and clean those too and your cleaning is done for a while. Apparently the ink has been in the drum of your washing machine and putting the color into your clothes. You can bleach out the white clothes that turned blue. Use the stain remover for colored clothes. Hope this will help you.
Feb 01, 2011 | Whirlpool Washing Machines
How to save drum unit encrusted with ink?
A little denatured alcohol and soft cloth is ok. Water is a no-no. The wiper blade may be defective on the drum unit and or the excess toner cavity in the rear of the drum may be full. Best bet is to replace the drum.
Nov 19, 2009 | Brother MFC-9440CN Laser Printer
What is the recomended maintenance for this machine
check and clean the feed rollers at paper feed with cloth and water or cleaning fluid remove drum unit and check the condition of the foil on drum for dents or marks.. clean the rollers at pressure roller and clean this off with spirits and soft cloth(rollers under the drum) empty out the master waste treay and clean off rollers here with spirits and cloth and check nozzle at air blower to the left of drum (Yellow nozzle for damage and blockage.. then check the tension of the master feed roller and clean the thermal heads with a soft cloth..remove the scanner glass and clean both sides with glass cleaner and clean off the lamp unit mirrors(take care here you dont miss align on guides)
Nov 05, 2009 | Riso RZ220 Duplicator
Dust on drum
check corona wire, slide the blue tab 10 times check both side of drum if there is an toner on the surface of the drum try to clean it with metal polish and a cotton cloth
Aug 12, 2009 | Brother MFC-8460N All-In-One Printer
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Clean
Cleaning the drum is NOT RECOMMENDED. However if you really have to... use a very soft lint free cloth
Drums normally get dirty when they are at the end of their useful life, as parts are worn
May 21, 2008 | Brother HL 1440 Laser Printer
jasbo
jasbo
