Question about Pioneer XVDV830/SDV830 DVD AUDIO HTP System
Pioneer home theatre : oc error
Pioneer XV DV 232 (3 years old)
intermittent; playing DVD and stops "OC Error"
even happens when using just for surround sound
about to throw in bin; any suggestions?
SOURCE: Pioneer oc error 1
it's output power amplifier problem pls check and change ur faulty ic
Posted on Jan 27, 2010
CLARKPINK55
  • 71 Answers
SOURCE: Pioneer HTZ-370DV Home Theater System Suddenly Turns Off
out put protection fault check speaker cables and speakers
Posted on Dec 10, 2008
  • 4 Answers
SOURCE: DVD Home Theatre System Panasonic xv htd-330 dvd won't play
From the manual:
Press STANDBY/ON to put the system in standby, then press and hold the front panel (stop) button for about 8 seconds until the display shows Mem.clr?.
Press the front panel I<<<< or the >>>>I button so that the display shows Interlace?.
Press the front panel >/II button to set to interlace & switch the system back on.
Posted on Mar 12, 2009
  • 105 Answers
SOURCE: Pioneer dv 313 cant resume
go set up menu of dvd and set what you want
Posted on Aug 07, 2009
dunnbiker
  • 8546 Answers
SOURCE: on a pioneer xv-dv8 home theatre timer light
I found the manual here:
http://www.pioneer-latin.com/downloads/xrb3033a.pdf
This their recommendation for your exact symptom:
Timer indicator is blinking and the system will not switch on.
• Unplug the system, then plug back in. Wait for one minute then switch on.
• Make sure the fan at the rear of the system unit is not being blocked.
• Check that the speakers are connected correctly.
• Make sure the voltage of the mains power source is correct for the model.
• If the problem persists, take it to your nearest Pioneer authorized service center or your dealer for servicing.
Posted on Jan 07, 2011
Help me guys regarding my home tieter pioneer model xv-dv 272 .my problem is When I open my player the display is only oc error1 I don't know what kind of error code is this help me guys pls reply
Unplug the power then hold the power button down and plug the unit in again to reset it. If not this is probably a component fault.
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 03, 2017 | Pioneer Televison & Video
What is the solution to an error code ( OC ERR 1) ON PIONEER XV-DV360
The "OC ERR 1" code is a sign that there is something wrong with the speaker connection(s). Mostly one of the speaker cables is causing a short-circuit, which triggers the safety system. Power off the unit and pull out the plug. Check all the speaker connections (amplifier and speaker side) and make sure that no (parts of the) cable is (are) touching the chassis. Twist the cable ends to a single core if necessary.
Jul 21, 2015 | Pioneer Televison & Video
I HAVE A PIONEER MODEL XV-DV151 AND HAS OC ERROR
while stad by bottan pressing oc error coming on display
Jan 19, 2013 | Pioneer Televison & Video
OC ERROR in pioneer dvd player
read the use guide to get correct error and fix it
Apr 25, 2011 | Pioneer AVIC-N2 Car DVD Player
I have a pioneer home theatre system model no.XV-DV262.i had bought in the year 2007 in malaysia.now i have shifted to india and hence cannot view all the dvds as it has some regional code,which denies it...
Hi, iam having Pieneer XV-DV262 Model H/Theatre it was good working but recently Audio is not working, and i think DVD Player Audio Ampliplyayer is not working Hence pls us to get solution / we can get only same model DVD Player or this can be repairable?? Pls advise us!!
Have Great Day!
Regards,
Sreenivasa Rao
Hyderabad India
09160092288
sreenivasa.rao@demagcranes.co.in
Nov 30, 2010 | Pioneer Audio Players & Recorders
Pioneer oc error 1
Oct 17, 2009 | Audio Players & Recorders
Dsc-363 displays code " oc err 1 "
It's output power amplifier ic problem. change ur output ic
Mar 08, 2009 | Pioneer DV-363 DVD Player
From the manual:
May 04, 2007 | Pioneer HTD-330DV System
397 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
