Question about Intel Desktop Board D845HV Motherboard
Where is the sata connection on this board FW82801
I'm trying to connect a cruicial SSD and I can't find the SATA connector on the motherboard.
  • Intel Master
  • 4,806 Answers
Hi.
You won't find any SATA connectors on that motherboard because it doesn't support SATA.
Regards.
Posted on Jan 01, 2013
  • 16 Answers
SOURCE: Connecting an IDE HDD to a SATA port using an IDE to SATA converter
Not complete product...need to buy additional adapter for IDE to SATA power source.
IDE drive will have to have the power source hooked up as well as the adaptor hooked up.
Installing the adaptor only will not work. Your computer should have the 4 pin plug for the power to the IDE drive, other wise you will have to buy another adaptor.
Posted on Mar 23, 2008
zohail
  • 1223 Answers
SOURCE: D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Posted on Mar 17, 2009
wayneard
  • 1901 Answers
SOURCE: Connection of DVD writer having SATA cable
The blue ports on this motherboard are SATA ports.
This is a SATA cable:
Posted on Mar 30, 2009
Sarethan
  • 76 Answers
SOURCE: Intel D945GCCR SATA driver problem.
You shouldn't need the drivers till after the OS is installed.....just go into BIOS and check to see what placement it is in.....or boot up the windows XP CD and select it as the drive to reformat and install XP on. In Bios you can select which drive you want to boot. i.e. IDE/SATA it should have a model number of the one you have selected to boot just make sure it matches the modle number of the drive and you good.
Posted on Nov 02, 2009
  • 11800 Answers
SOURCE: connecting sata hdd on 845ge
Directly you can't, the chipset on that motherboard doesn't support SATA. You will have to buy a PCI SATA card and plug the disk in it.
Posted on May 04, 2010
SATA port 0 INTEL ssd locked
Please check the solution here:
1) Find or make an XP install with SATA set to IDE mode
2) Install .NET 2.0 & Intel SSD Toolbox
3) Shut down
4) Connect up your 'bricked' Intel SSD
5) Turn on system
6) Start Intel SSD Toolbox, and the SSD should now show up
7) Start another secure erase on it, and it should go through
8) Your Intel SSD is now unlocked again
http://forum.notebookreview.com/threads/how-to-resurrect-an-intel-ssd-locked-by-the-intel-ssd-toolbox.583269
You might also want to follow this Microsoft KB - You receive Stop 0x0000007B error after you move the Windows XP system...
And for some background info - https://ata.wiki.kernel.org/index.php/ATA_Secure_Erase
Hope that helps!
Peace
Apr 20, 2015 | Acer Aspire 5610-4648 Notebook
What is the second connector on the NP305V5A-A05US motherboard?
perhaps connection for second/slave hardrive or data transfer conn when replacing hardive?
Feb 25, 2013 | Samsung Np305v5aa05us Quad-core...
Please tell me if I can install this SSD drive in my Acer Aspire V3-771G laptop. What is the difference between SSD SATA II and III
A sata 3 SSD on a sata 2 PC will slow down slightly to sata 2 speeds, and vice versa. But this is usually acceptable since any current model SSD is much much faster than a normal hard drive so even installing a slower model SSD will be a big improvement. Its analogous to a porsche 911 and a volkswagen beetle. The 911 is faster than the beetle but both are much faster than horses.
your laptop has a normal hard drive. Most SSD's except apple SSD's are the same size and have the same connectors so 99% of the time it will work. you can see pictures of the SSD and compare it with your current hard drive
Oct 25, 2012 | Computers & Internet
I have a Dell Inspiron 8600 which is running windows xp pro. I have 2 Gigs of memory, the computer runs ok, but I'm receiving info from scans that my HDD Pata is about to go,I'd like to change
Well, you will want to open up the side of your computer and see if there are SATA ports on the motherboard. They look like this:
Though they may not be blue.
If there are SATA ports on your board, you are in good shape. Just buy any SATA hard drive (SATA2 and SATA3 are backwards compatible) and connect it with the SATA connector and a SATA power connector from the power supply. Don't be afraid, these can only plug in one way without forcing them and only SATA plugs will fit.
After that, there are a variety of drive cloning programs you can use to clone your current hard drive onto another so that you don't lose anything.
If you don't have SATA plugs on your motherboard, it is easily remedied. You can buy a PCI SATA card for quite a reasonable price like this one:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816124024
You will also probably need a small adapter like this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16812189121
To convert a molex plug into a SATA power plug.
After you plug in the card and the new hard drive, run the driver CD for the SATA add-in card and then run a cloning program.
Oct 25, 2012 | Dell Inspiron 8600 Notebook
Can i replace the hdd of my compaq nx7010 with an ssd drive
Yes. as long as the interface of HDD matched with mainboard of laptop interface. compaq nx7010 use SATA interface so you should use SSD drive with SATA interface . :)
Oct 03, 2012 | HP Compaq Business nx7010 Notebook
How to connect a cd rom/dvd
If your CD / DVD is powered on Ok then you are missing the data cable connection which will be either a SATA (small connector) or IDE (much larger connector) both of which plug in to your motherboard....Look at the CD / DVD and try to identify which type of connector you are missing then look for an unconnected cable of the same type within your case.
Dec 17, 2011 | Gateway LX6820-01 Desktop PC
Hook up fro WD3200 SATA hard drive. I am trying a new power supply and I dont remember how the harddrive was connected ,DoH Do I need both the SATA and the 4 pin molex connectors connected ?
You cannot use a molex connector on a SATA hard drive. You need to connect one of the black plugs from your power supply and the SATA (red) cable from *********** board.
Best wishes,
Graemevm
Mar 09, 2010 | Computers & Internet
Connecting new hard drive
If the old one is still conected you can connect it the same way if not here is how to::
Well firstly they are 2 types IDE (large connector) and SATA (small connector)
IDE
of an ide cable has 3 jacks 1 for the main board and 2 for IDE drives
2 drive must be set to master and the other to slave
Set the drives by using the jumper on the back the instructions are written on the drives
Connect the Ide Cable and then the power and turn you system on
IF ITS SATA
connect the sata cable to both hard drive and main board
connect the power cable and your done!!
NB:: sata ports are labeled SATA 1 SATA 2 etc
IDE are LABELED IDE 1 IDE 2
Ide is a large grey cable black connector SATA is usually orange or red and small
Oct 26, 2008 | Gateway (M520HD80G) Hard Drive
Intel Desktop Board D845HV Motherboard Logo
44 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
