Is there, or how can I link my 5.1 surround sound to my tv. The make is neon c3298dvb. I can't seem to find audio out sockets
  • 7,627 Answers
I don't know what your 5.1 sound system is? There a couple of ways, I can't tell much from the video, Use Analog cables from the audio output of the TV to input of the 5.1. You know you will not get a 5.1 sound, the TV, unless on a digital cable box, cannot create a 5.1 sound, without other equipment. There are many ways, depending on the available connections on your equipment, take a look at this: http://www.ehow.com/how_4779458_connect-tv-surround-sound-system.html
Posted on Jan 01, 2013
SOURCE: surround sound
You need a cable from your audio outlet to the home theatre receiver. Veira link is just for the picture. Only one way transmission. Optical cable or the 2 wires. Both options are available.
Posted on Dec 17, 2007
  • 44 Answers
SOURCE: Hooking up surround sound to TV
You have to get an optical audio cord.
The optical output on the vizio is right next to the ac cord. Make sure that your audio amp has the same input conection.
Lou Margo
Allied Electronics
loumargo@verizon.net
Posted on Dec 16, 2008
ronaldo_ross
  • 1056 Answers
SOURCE: can't find audio out on my 32
If there is it would be the "rca" cable that has a red and a white marking, and it would say "out" on it or "audio out" Some TV do not have an audio output so you maybe right.
Posted on Aug 12, 2009
vinnyq
  • 157 Answers
SOURCE: I'm having trouble connecting the tv to my
I checked Amazon, it says "For connections, you get 1 each composite- and S-video inputs for your DVD player, VCR, or other audio/video device, and a set of component-video inputs for your progressive-scan DVD player or DTV set-top box."
Your TV does not have a audio out since it is a smaller TV. You need to get a tuner and route the sound system through there.
Posted on Oct 09, 2009
Icebassman 5
  • 57 Answers
SOURCE: I have a trutech tv model # 008-09-0119 and I am
Hi there.
There is a scart cable connection on the tv, right! Buy a scart block with a switch on it with in/out switch. Plug it in the tv, put switch on out, plug yellow into yellow, red into red and black/white into black/white. Sound?
Iceman.
Posted on Nov 04, 2009
Need the four digit code for a neon tv model C3298DVB to reset sky remote
You have this backwards. The code would be in the remote.
Apr 19, 2017 | Neon Televison & Video
Unable to get TV sound and dvd sound through the surround sound speakers with samsung compatible tv and blu ray player
Hi,Even though you have not mentioned about the cabling connections you have done, for the sake of correct connection I describe all the possible cabling alternatives to you..You can select whichever you want..
TO WATCH DVD ON THE TV:
** Receiver's "AUDIO and VIDEO OUTPUT as " 2xRCA Audio+1x Video " or "Optic Cable OUTPUT or " HDMI Output " of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary cables on your hand )
** AT TV side : you need to connect "Audio+ Video input s " as can either be : 3xRCA jacks or "Optic cable input " or HDMI IN connector of your TV ,
** than just switch to DVD mode on Receiver and play DVD
You can use "HDMI" connections as well but sometimes HDMI creates problem on Audio..
TO LISTEN YOUR TV ON SURROUND SYS.
** AT TV side : you need to connect "Audio Output " as can either be : 2xRCA jacks or "Optic cable output" or HDMI connector of your TV ,
** to Receiver's "TV input "or "AUX input" or "Optic Cable input"
or HDMI of your Home Theater Receiver (whichever you want ,based on the existing sockets and necessary
** than just switch to respective SOURCE mode on
Receiver corresponding the connector you have used on the back of Receiver ..
Pls remember.."IN " goes to "OUT" or vice versa..all the times..
There you go..Both Tv and DVD sound are on the
Receiver as SURROUNDING SOUND .By this means ,whatever you watch on the TV will come thru your Receiver's SURROUNDING SOUND speakers as well .
Hope this helps!..if more help requires pls let me know.
Take care
Aug 17, 2011 | Televison & Video
I have a JVC TH-S3 surround sound system and would like to know if I can l watch television in surround sound as i can watch dvd's and listen to the radio in surround sound. thanks
Yes you can get simulated 5.1 surround sound from your TV as well as radio. Just switch the JVC surround mode to Pro Logic II movies or music In some systems it will display only PLII.
Just connect the TV audio out to the JVC Aux input at the back ( red and white sockets ).
Apr 26, 2011 | Audio Players & Recorders
Cannot connect Curtis DVD6091 to 42" plasma tv by digitcal optical or audio leads, works fine on dvd and cds no sound from tv. Have checked settings are both pcm, and have turned off speakers on the...
Speaking direct to the manufacturer it turns out that the intended use for the optical socket is to allow connection to other video devices and not for the connection of other audio signals. In short, you cannot use the optical socket to allow 5.1 surround sound from any other device as it is OUTPUT only.
Seems crazy I know but that's what the manufacturer told me.
Nov 09, 2010 | Curtis DVD6091 Theater System
Audio output on TV
Sounds like you have it hooked up properly. Be aware that if there is not a digitally encoded signal for surround sound [they don't always do that] you simply won't have surround sound. Usually there is a mode in your receiver/amplifier that will allow you to simulate surround sound. An example of that would be "theater" or "hall" sound. Try it with a DVD known to have surround sound encoding [most of them do] and see if it works that way. If it doesn't then check your owners manual for information about how to make sure that feature is actually turned "on".
Apr 16, 2010 | iLO Televison & Video
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Sound Problems with HD TV
This seems to be a problem that has to do with your HDMI audio output.
First check in your TV setting if audio out is selected on your correct HDMI port. Than check if your receiver is able to receive audio via HDMI (i assume you used the HDMI connection). Some receivers have HDMI IN connections but are not able to receive audio on it, the latest receivers/sets do have this feature. If your receiver doesnot support audio IN via HDMI you can only do one thing, connect the stereo audio-out of your TV to an AUX IN connection on your receiver.
Jan 18, 2009 | Samsung HT-Q100 System
Adding Surround Sound to Sharp 32R-S50 32" TV
if the tv has outputs at the back for surround speakers then you can connect it to them..else pass the audio of your TV thru a home theatre surround receiver
Mar 05, 2008 | Sharp 32R-S50 32" TV
NO SOUND
You need to plug the red and white cables from the audio out of your TV or the audio out of your cable box - you can't go from an in to an in
Nov 29, 2007 | Philips LX3700D System
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
