Question about Thetford MRFT-40 Portable Refrigerator&fraslFreezer
My Norcold mrft40 refig/freezer is freezing everything at the lowest setting. Is this a themocouple problem that won't shut off the compressor? Is there a part number if it is? I have had this sin
Freezer not shutting off
Thermostat is not working and will not open to stop compressor and fan.
Nov 27, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
Ffu20fc4cwo won't freeze food
Check power to and from the thermostat first
Sep 13, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I have a deep freezer,the light is on but doesn't freeze. It's only 2 yrs old what could be the problem?I unpluged it and waited 10 mins pluged back in and nothing the red light stayed on but...
Well a freezer is easy to repair. The circuit goes from one side of the power cord to the cold control and down to the compressor then out to the other side of the power cord. Id the control or compressor relay is open then she won't freeze. All the parts to it are listed HERE.
From the list I see an overload for the compressor. If that one is open it won't freeze. Bypass the temp control wires to see if she runs.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 13, 2011 | Magic Chef Chest Freezer MCCF5WBX
Freezer won't get below 30 degrees at the highest setting, food won't freeze.
Possible that the gas pressure is down to low gas or leak on the system. Also it can be due to faulty thermostat, faulty compressor if the compressor is working all the time and reaching the set temperature. Also if the compressor is not cutting off this must be a suspect.
Aug 24, 2011 | Kelvinator Freezers
Freezer is around 3 years old. When set at -17 degrees the freezer clicks very noisely, a relay operating I think. When the fast freeze button is pressed this clicking stops but the display reads -27...
In my opinion, since your going for the fast freeze mode, your freezer sets to its lowest operating temperature to fast tract the freezing process.
and about the noisy clicking sound it is probably a thermostat or relays depending on your system which starts and stop the compressor.
i think your freezer is just doing fine.
Dec 29, 2010 | Whirlpool Freezers
Freezer temp turned down but still freezing everying
just look for a better fan to buy to prevent the compressor from having problem . thanks.
Feb 15, 2010 | Freezers
Freezer used as a frige?
it may be possible. Turn the temperature on the lowest setting and see what happens. If it still freezes everything up then it is not posible. If it doesn't freeze everything , then check the temperature with any temp probe. It should run at somewhere between 36 and 38 degrees. This is the normal cool setting on a refrigerator.
Nov 07, 2009 | Freezers
Freezer compressor runs steady & getting -30F
You probably have a defective thermostat or sensor for reading the temperature.
Mar 23, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Thetford MRFT-40 Portable Refrigerator&fraslFreezer Logo
63 people viewed this question
Top Thetford Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Thetford Freezer Expert? Answer questions, earn points and help others
