Question about Neff W5340X0 Washer
Neff washing machine with error code 6
I have a neff washing machine/dryer ??model as no paperwork & nothing written on it. 3 yrs old wont drain & error code 6 on it, any idea what this may be please?
    Sergeant:
  • 228 Answers
Error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced they are not expensive,
hope this helps
Posted on Aug 05, 2009
My dryer keeps giving an E 14 error code. Even after resetting it, it runs for about two minutes & flashes the code again. How can I fix this?
Bosch Washer Dryer ' Neff ' Siemens ' Integrated ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3312-bosch-neff-s...
Jan 16, 2012 - Bosch, Neff and Siemens integrated washer dryer error codes and ... The error codes in this article pertain to integrated washer dryers ... E14 ...
how to mend it .com - error code E14?
howtomendit.com > Household Appliances, Washing Machines
Bosch washer/dryer wvti3240 stops wash and displays error code E14. Can anyone help please ? also a full list of the error codes applicable to this machine ..
Nov 03, 2015 | Dryers
GE Washer wont drain. Wont agitate, does nothing. Washer is part of a stackable unit about 4-5 yrs old. Checked circuit breakers and electrical and water supply. What should I check? Are there fuses inside...
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Here is a link to the part you need.
Jan 10, 2011 | GE WSM2700W Unitized Spacemaker Washer and...
We have a Neff washing machine with Error code E06. Model no 22052 Please can you let me know what the fault is Regards Justin Posner
error code 6 is drainage fault if it takes longer than 6 minutes it times out and aborts programme check filter isnt blocked and impellor spins freely,if ok may need pump replaced but first check to assure that nothing is stuck inside the pump or one of the lines goiing to the pump they are not expensive if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 10, 2010 | Neff Washing Machines
Washing machine not draining the water
the weater pump is bad replace....
Apr 13, 2010 | Neff W5340X0 Washer
NEFF washer not starting. error code 3/flashing anti-crease butto
This may be a simple control fault that can be reset by unplugging for 5 minutes or switching the breaker switch off for five minutes also. if the five minute reset doesn't restore the machine to its original operational value, you will then need to replace the main control board in this unit. it has failed.
May 11, 2009 | Neff V4380X0 Front Load Washer / Dryer
NEFF WASHING MACHINE
Error code e 10 means no cold fill.
Ensure that the water getting to the machine from the water supplies at the back. Check that the hoses are not bent or kinked and that the water tap is opened.
Try cutting power to the machine for ten minutes to reset the code.
If that does not work, then it is usually a faulty inlet valve stuck on closed on cold water.
Feb 27, 2009 | Neff V4380X0 Front Load Washer / Dryer
Neff washer dryer has error code e06 and the water wont drain
same problem, just replaced pump and cleared all outlet/inlet pipes (passed water through unhindered, still throws E06 when I try to start.
Feb 24, 2009 | Neff V4380X0 Front Load Washer / Dryer
Neff W4380 error or warning '03'
Hello there,
when the machine makes drowning sounds and beeps error dry (while trying to drin out) blow strongly into the drain pipe. It should result in a higher flow of water out the drain pipe and error 3 should go away.
Jun 02, 2008 | Neff W4380X1 Front Load Washer
Neff V4380X0 Front Load All-in-One Washer... error e06
Check the drain pump and any associated hoses to and from the pump. There may be a blockage, restriction or the drain pump could be jammed or seized.
Oct 07, 2007 | Neff V4380X0 Front Load Washer / Dryer
Neff W5340X0 Washer Logo
929 people viewed this question
Top Neff Washing Machines Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Are you a Neff Washing Machine Expert? Answer questions, earn points and help others
