Question about Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range
Gas oven heats, but not enough. take a really long time to cook
Maytag jen air model jgr8875qds
fridgetech
  • 473 Answers
SOURCE: maytag oven not getting hot enough
When you put the oven into bake it preheats with the bake and broil element both.  The broil element is most likely your only heat source if it took that long to cook the pie.  Need to verify that the bake element is coming on.  If it isn't then the problem is either in the control or the element itself.  Give me the model # off the sticker on the oven and I can help you do the check out.  In the mean time see if the bake element is getting hot.
Posted on Oct 27, 2007
SOURCE: Maytag Gas range
Had the same problem.... just replaced the ignitor in the bottom of the oven... worked like a charm. 10 minute fix
Posted on Oct 22, 2008
SOURCE: electric oven does not heat up enough
I had the same problem before the warranty expired. The heating element had exploded and there was white powder all over the inside of the oven. They replaced the heating element and it works as it should, however, this oven has never baked right. It gets hotter on the right hand side than it does the left and I have to constantly watch whatever I bake. I'm not very happy with this oven.
Posted on Jan 18, 2009
shinn8
  • 85 Answers
SOURCE: maytog gas oven model 5765QDB--oven will not heat up
Sounds like your oven igniter is bad.
Part number is 74007498
Posted on May 18, 2009
  • 10865 Answers
SOURCE: oven takes a long time to heat up.
Hello. To go 12 years without issues is excellent. Now however you will have to make a decision to repair or replace. Be sure to get a firm estimate before you repair and compare that to the cost of replacement.
here is what may be causing your problem:
Usually when an oven won't bake, it's because the bake igniter is weak or burned out. The igniter is a small, round or rectangular device, that's about 1 inch by 4 to 8 inches. It's near the burner itself.
The burner is the tube-type device the gas flows through before it's ignited. It has many small holes on the sides to let the gas, when ignited, form a long, low flame. If the igniter is weak, if it glows red but doesn't get hot enough, or if it's burned out, the gas doesn't flow to the burner and the burner won't ignite. If this is the problem, you may need to replace either the igniter or the gas safety valve. Usually the igniter is to blame.
Other causes Other reasons that your oven may not bake are:
  • The clock settings are incorrect (if you have timed baking or a self-cleaning oven).
  • The thermostat is defective.
  • The safety valve that prevents accidental gas flow is defective.
  • The selector switch is defective.
Posted on Aug 15, 2009
Maytag oven blowing hot air from bottom vent heating house
Wanted to know if you found the answer. I have the same problem.
Aug 31, 2012 | Maytag Ovens
HOW TO COOK RICE IN A JEN-AIR MICROWAVE OVEN jmw8000bas
Sorry to read about your problem, I hope this helps you out.
you really dont...unless you have a microwave pressure cooker
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Jenn-Air Microwave Ovens
I have a maytag MGS 5770 ADA range/oven. The oven does not heat. The top burners and broilers work fine. However, the bottom oven burner doesnt kick in. the igniter glows red hot but the gas never...
I would start by replacing the ignitor. It could glow enough to light the oven, but to maintain the burner, it often re-ignites several times during a cooking cycle. I have had the problem before, replaced the ignitor and all was well. You should be able to find an ignitor for under $40 online. Just google 'Maytag oven ignitor' and you should find many offers. My sister just bought one for $19.99!
Mar 15, 2009 | Maytag MGS5770 Gas Kitchen Range
Oven over heats/gas smell
Hi the fact that you smell gas near the floor suggests you do indeed have a gas leak, propane is heavier than air to will fall to the floor.
you really need to get the gas company to check
Mar 14, 2017 | Maytag MGR5875QD CleanDesign Gas Kitchen...
CRG9700 - OVEN TEMPERATURE BIG FLUCTUATIONS
biggest issue with any gas oven is a faulty ignitor, not maintaining oven temp, too long to preheat, taking too long to cook, possible slight gas smell during operation, all signs of a bad ( or going bad) ignitor
Nov 10, 2008 | Kitchen Ranges
Maytag range # MGR5775QDS
gas range, most common issue for extended cook time, long preheats, bad oven ignitor (it works but its slow to refire ) 75 dollar part servicer will get 175-265 depending wher you live
Oct 25, 2008 | Maytag Kitchen Ranges
Oven racks
Hello bargarmar
Welcome
You said, Your Jen-Air stove's oven racks keep falling after the heats been on. This is scary and unsafe. Your gas range is only 2 years old.
This may be caused by the racks being left inside the range when using the self cleaning system. Which can cause the racks to become warped and or discolored.
If they are warped they may not sit even in the oven while baking and also move or change their shape
form the heat every time you use the warped racks in the oven.
If you leave the oven light on before you start the oven and watch the racks as they warm up with weight on them you will see if this is the case.
Then you will want to replace them.
Let me know what happens.
Huuum
Please remember to leave a rating
Oct 16, 2008 | Kitchen Ranges
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Electronic touch pad problems
From what your telling me, you have tried all the numbers and only 1,4 and 7 beep when touched. Also, the timer display was set at 0:00 when you started. Also, you followed the manual's instructions first, and looked in the back of your manual in the trouble section, and found no answer.
Did you timer ever work? If not, you should be able to a free replacement of the control panel module from an authorized Jenn-Air repair company. It may be a good idea to contact Jenn-Air first.
The timer shows only hours and minutes when first started. For example 2:05 is two hours and five minutes. It goes into the seconds mode only during the last minute.
Dec 01, 2007 | Jenn-Air JGR8875QDS Gas Kitchen Range
Maytag oven not getting hot enough
Oct 26, 2007 | Maytag MER5552BAW / MER5552BAQ /...
Maytag MER5765RAW / MER5765RAQ / MER5765RAB Electric Kitchen Range Logo
51 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
