Question about Western Digital My Book Essential 1TB External USB 2.0 Hard Drive
Can't read data on WD external my book hard drive
It seems that your WD hard drive is corrupted so
you are unable to access the stored files. But there is no need to worry since
it is very easy to recover data from corrupted WD partition by using Western digital partition recovery
software. Couple of days ago, even I was stuck under similar problem I tried
this software which really helped me to retrieve all my lost data.
All the best,
Linda William
Posted on Feb 24, 2013
5 Suggested Answers
  • 81 Answers
SOURCE: My WD 2T external My Book hard drive is not working
You will need to try formatting the drive. You can do this from the drive management section on the Mac.
Posted on Jul 10, 2009
bob_computer
  • 3153 Answers
SOURCE: I have a WD My Book 1 TB external hard drive. It
One or more of the hints below will probably sort out most USB problems with most USB portable / external hard drives and OTHER devices (though not always)
A few things to check but assumes USB and Windows for other interfaces / operating systems (mac/ Linux) similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly. 5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again. This can be especially true if you move a HUB to another port
6. For FLASH DRIVES you should ensure that the device is set for "quick removal" using the drive control panel properties or use the USB "Safely Remove Hardware" option. If you dont do this there is a very strong chance that any files you transfer may not be there when you plug into another computer.
7. It is possible to remove drives from the enclosures in most cases and connect directly inside a PC to fully check it.
You should also do this to cheack the drives connections are not bad inside the enclosure.
8. If none of the above steps help look at updating the drivers from the manufacturers web site in the support section.
9. If you checked and fixed anything there and still have issues then check your hardware from CONTROL PANEL / SYSTEM / HARDWARE.
Any exclamation marks by hardware need fixing before you investigate any further
10. ensure that you have set removable drives for "quick removal" or that you use the "Safly Remove Hardware" option often shown on the lower toolbar.It is possible that files my not be fully written to external devices before they are removed. This corrupts the file itself and even on occasion the drive.
Posted on Nov 17, 2009
lock123
  • 6831 Answers
SOURCE: external hard drive don't install
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
bronk50
  • 27725 Answers
SOURCE: wd external hard drive i can't see the datas
Figure out whether you need a hardware or software fix.
Look for grinding sounds from your drive or humming that starts or stops.
These are signs that the actuator arm and discs are no longer in alignment and your drive is timing out.
If it seems as though nothing is wrong with your hard drive, it's probably time for a software fix.
Run one of the many software fixes, if you think the problem is related to software.
These programs feature on-screen directions, making it easy for you to progress through them.
If this works, you don't need to fix a physical problem.
Remove the many tiny screws that holds the drive together.
Eventually, you'll get to the innards of your drive.
Be very careful not to bend or force a piece to go where it doesn't want to.
Determine if you've set things straight.
Look to see whether anything was loose inside your external hard drive.
If you have recently dropped it or traveled with it, it is possible that something came loose.
Also check that all the arms and platters are straight and do not appear bent in any way.
If they are bent, straighten them with your hands or pliers.
Put everything back together and check that everything in your external hard drive is working properly.
Try using the external hard drive on another computer.
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers right click to reinstall drivers
if you can see your usb but its not working ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output power
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Posted on Oct 30, 2012
I conected wd to mac book pro and the computer asked me if i want to use the wd for back up and i said yes.now all my files that i had there before does not recognize on my pc or apple.i can only use as a...
You will need to recover the data using something like asoftech data recovery program.
http://www.asoftech.com/adr/
I've had to use it many times in the past but in this case you need to plug that drive into another Windows system as an external drive or slave drive and run the software from there. It will rebuild the drive and hopefully recover the files.
Good luck.
Aug 19, 2011 | Western Digital My Book Essential Edition...
I HAD Western Digital My Book Essential 1TB External USB 2.0 Hard Drive ON M PC AND I CONECT WESTERN DIGITAL MY PASSPORT AND RUN THE AUTO FROM THIS SOMETHING LIKE WD SMART.... AND NOW MY Western Digital My...
Your WD HDD have been attacted by viruses for your computer or outside computer where you used it last. Make sure that you have an up to date antivirus software, scan your computer or the external hard drive, explore your computer, go to tools - folder options under view files & folders select show hidden files and folders apply and ok it.
May 18, 2011 | Western Digital My Book Essential 1TB...
External WD 1TB. I cannot retrieve my files it says Parameter is incorrect when that is gone It shows there are no files on my HD and there are plenty of files all psd files as well
I'm sorry to say that this may be due to a corrupt HDD. WD Hard drives tend to die far too fast (I know too well unfortunately).
If this is under warranty, I would call up WD support service for a free replacement.
If you want to take more invasive steps, I will be happy to help you try and recover your files.
Feb 23, 2011 | Western Digital My Book Essential 1TB...
My WD My Book Essential 1TB External is not showing up on 'My Computer'. It was working perfectly in the morning, then when I rebooted my machine it no longer showed up.
disconnect your WD ext HDD. and reboot your computer. then connect again. if still not showing. go to device manager (right click my computer then properties -- click device manager). expand by clickin "Disk drives" category here it will show all the hard drives installed in your computer including your WD ext HDD . if you see yellow sign on your external drive right click and remove then go to Action menu click on Scan for hardware. it should detect and install the driver again. if still the same or maybe its not on the list of Disk drives.. try to change another USB cable .. i hope this will help
Jan 03, 2011 | Western Digital My Book Essential 1TB...
How do i use a wd external drive 500 gb on a mac & pc
The MAC can read and write PC files but not the other way around.
To do this the USB external hard drive needs to be formatted using the PC and formatted in FAT32.
Once this is done then you can exchange data between the MAC and PC.
Nov 03, 2010 | Western Digital My Book Essential Edition...
It make tic noise when the hard drive is running
This sound is the heads of the disk hitting. The drive should be backed up immediately to another.
You can put this drive into a drive enclosure to clone it to another.
This drive will stop working and there is no telling how soon that failure will occur.
Jun 06, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Jul 10, 2009 | Western Digital 500GB My Book World...
WD Book reads unreadable and corrupted
the data is corrupted but if its very important you can choose to send the drive to one of the data recovery companies and get the data recovered for more info on the various companies that would provide such services and their charges for the same please check this link:
http://www.datarecoverycompanies.com/
Jun 24, 2009 | Western Digital 500GB My Book World...
Western Digital My Book Essential 1TB External USB 2.0 Hard Drive Logo
282 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Marcin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
