Question about Samsung LTN1785W 17 in. HDTV-Ready LCD Television
Light and dark?
No matter what video input I have on, the screen is always dark for the most part except for a strip of screen which is lighter 3/4 of the way up the screen. Anyone know what would be causing this? Thanks.
  • Christopher Bubbles Jun 26, 2007
    Really? Thanks. Do you know where I could find one?
  • Anonymous Apr 26, 2008
    Screen is uniform brightness unless left on for several hours. Then a darker band forms in the middle or top two thirds of the screen.
  • 432 Answers
The video invertor board needs replacing.
Posted on Jun 25, 2007
SOURCE:
The dark areas of a picture is red
the screen itself is going bad and wearing out . there is no repair except replacement of the tv .
the screens are so expensive to buy there would be no point
sorry i could not bring you better news
Feb 02, 2016 | Sony BRAVIA KDL-40EX400 40" LCD TV
What would cause very dark blurred display all modes on Samsung P2250?
the tube lamp is degraded an needs replaced . the high voltage to the lamp might be weak corroded connection too.
consider changing the lamp out for led strip
i ordered 1 ccfl lamp many times from china for 2.50 an they are always damaged . too long for the mail.
i can order the same ccfl lamp from us for 40.
so
im going to insert led strips in place of the lamp.
its not that hard if your a tinker
Jul 25, 2014 | Samsung SyncMaster P2250 22 inch LCD...
Christie LX700 projector causes the brithness very dark
does it matter what input you are using. Video or computer?
Dec 19, 2012 | Christie LX700 Projector
My camera over exposes everything - the shutter stays open for about 2-3 seconds. except when on video settings. No matter what I set it at nothing changes.
Looking down at the top of the camera, check the left knob. This is the exposure compensation dial. Adjust it to "0". If set one way or the other, it will make pictures darker or lighter. This comes in handy when the image has a lot of dark or bright areas - moving this dial will allow you to make the bright areas darker or the dark areas lighter when you camera's light meter is setting the exposure in a way you do not want.
If still having trouble, make sure the right knob (Mode) is not set to M or Manual. Switch it to Program or Auto and try taking a picture again. You might even want to set the outer knob (ISO) to AUTO as well to reduce the chances of an incorrect setting. If it now works as expected, but you want to shoot in M, you will need to learn how to use the meter to select the correct combination of aperture (f stop), shutter speed and ISO to obtain the desired results.
Oh, experiment with the exposure compensation knob when you have a chance, learn how it can help correct overly dark / bright scenes. Good luck!
Feb 14, 2012 | Canon PowerShot G10 Digital Camera
Blank Screen on Garmin E-Trex Vista
The problem is that your software version needs updating. A recently added satellite creates a glitch in the older software. Go to the Garmin website, load WebUpdater if you haven't already done so, and the updated version (3.8) will automatically install to your Garmin unit. I had the same symptoms, they have now disappeared and my Etrex Vista is back to normal.
Oct 14, 2008 | Garmin GPSMAP 76CS GPS Receiver
Why do pictures taken with my digital cameras nearly always look too dark when viewed through my computer although they look fine on the cameras screen
It's usually just a matter of calibration between your camera's LCD and your computer monitor. The default settings on your camera's screen should be pretty close to accurate. Your monitor could be lighter or darker, depending on many factors, such as your preferences, or out-of-the-box settings. The best bet is to adjust your computer monitor to closeley match your camera's LCD.
Jul 12, 2008 | Cameras
Samsung LTN1785W 17 in. HDTV-Ready LCD Television Logo
73 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
