Question about EuroCave INOA 1200 Wine Cellar Cooling Unit
Wine cooling system problem - EuroCave INOA 1200 Wine Cellar Cooling Unit
Wine cooler cools but has a very loud, too loud to ignore, whirring sound when it is in cooling mode. Any ideas?
And when the wine is cooled ... the noise stops?
It's like a refrigerator ... it only operates when it it is reducing temperatures. Once things have cooled, the system cuts out.
If your wine cooler stops making a noise when the wine is cooled ..ok.
Jan 19, 2016 | Refrigerators
Does a thermoelectric wine cooler have a ventilation system?
Absolutely, every wine cooling system has to have a ventilation system that will channel the heat generated in the operation, outside of the unit, including the thermoelectric wine cooler.
Aug 14, 2012 | Furniture
I live in a small apartment in New York City and don't have a lot of space for a wine cooler. Can anyone suggest a good cooling system for my situation?
You should get a countertop cooling fridge. They are very compact, about the same size as a microwave oven, and can hold up to 20 bottles of wine.
Jul 31, 2012 | Furniture
I need a wine cooler with more than two zones for cooling. Does anyone know of a multi-zone cooling system that I can purchase?
There are quite a few high-end multi-zone wine coolers. I found you a great 3-zone 143 bottle system. I must warn you, it is very expensive.
http://www.us-appliance.com/ws14300.html
Is there such thing as an eco-friendly wine cooling system?
Peltier wine cooling system (thermoelectric coolers) are very eco-friendly - in comparison to other fridges. They do not contain cooling agents such as CFC an HCFC.
Do I need a wine cooler to store my wines or can I store them in a normal refrigerator?
The purpose of a wine cooler is to store wines at their proper temperatures in a proper manner. Wine coolers are set to higher temperature ranges than other systems simply because wine should not be kept as cool as other beverages.
What is a thermoelectric wine cooling system?
Thermoelectric cooling is best used in small wine coolers. Small fans from inside the cooling fridge evenly dispense cool temperatures throughout the interior of the unit.
Vinotemp VT-16TEDS has light on but doesn't cool
First check the grating over the fan in the back. If it is covered with dust, there won't be enough air flow and the unit won't cool. Clean the dust off and see if it cools back down. It may take a long time to cool down if it is full of wine, so I recommend taking the wine out to test if it works.
Jan 17, 2009 | VinoTemp VT24-G 24 Bottle Wine Cooler
Wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Oct 07, 2007 | Marvel 61WC Wine Cooler
EuroCave INOA 1200 Wine Cellar Cooling Unit Logo
81 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
