I have a Cannon MP600 and it will not feed the paper one at a time. It always grabs multiple papers at once and messes up the printing. I think it's because I once did a Pinterest idea to print on a paper lunch sack and somehow it screwed up the feed. Any ideas how to fix this?
SOURCE: Paper does not feed - GRABS RIGHT SIDE
I once had a similar problem a few months ago and I tried EVERYTHING I could do (Without shaking the printer, I was scared to do that) nothing worked, till I actually got up on a chair and looked into my printer (It is up on a rise above my computer) and there was a push pin sitting in the feeder opening! (Remove pushpin = then it was fine)
Then it started doing it AGAIN yesterday at a time when I really needed my printer, and this time there was no obvious pushpin or any obvious obstruction. I read all the stories here and thought *WOW they had things that far in there?!" So I tried harder and FINALLY after opening the back panel I saw with a flashlight there was a FROOTLOOP (I don't even HAVE any frootloops in my dorm! XD) jammed in the right side inside it! With a chopstick I was able to get it out and now it's fine again. OMG.
But yea, things like to get stuck in printers I guess. XD
SOURCE: Paper feed problem
i disconnected turned upside down and started shaking it and believe it or not the roller starting working it prints fine!
gears below the paper feeding tray are damaged or some dust particle have blocked the gears try to clean it by blowing the dust use normal greece (oily substance) between the gears so that they can move frequently to pull the paper, and if the gears are damaged you have to change the gears.
SOURCE: my cannon pixma ip1600 has
Normal
0
I suggest you get a sheet of Card Stock (Heavy
paper) and place it in the feed way. Then press the print
button applying a slight amount of pressure on the Card Stock so it
will feed through the printer. The reason for this is in some cases I
have been able to clear the paper track of debris that was deposited there
over time.
Worth a try, as I have fixed a number of printers this
way, saving costly repairs.
Hope this helps.
Bud
