Question about HP Officejet Pro8000 InkJet Printer
Officejet pro 8000
The printer will not print. It says on my computer that it is 'printing' yet nothing is coming out. The inkjets are ok, paper ok, so I don't know what the problem is. Can you help? thanks, Deborah
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 66 Answers
Check for spooler service in your computer.
Posted on Jan 02, 2013
IB4G2008
  • 3587 Answers
SOURCE: printer - Hp Officejet Pro K8600dn
yeppers..you'll need a special driver either from the autocad program's website, for HP(or postscript) or you might find it at this link
Posted on Mar 30, 2008
SOURCE: hp officejet 6210 won't print
Perform the following steps:
a) Turn the printer on.
b) Open the printer’s top cover.
c) After the print cartridges have moved to the center/home position of the printer, unplug the printer’s power cord from the electrical outlet.
d) Remove the print cartridges.
e) Using a dry, lint-free, clean cloth, wipe the print cartridge contacts, from the top to the bottom
f) The contacts inside the printer may also require cleaning. Using a dry, lint-free, clean cloth, gently wipe the contacts, from the top to the bottom
g) Plug the printer's power cord into the electrical outlet.
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
Now, perform the following:
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Posted on Apr 01, 2008
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
SOURCE: HP business inkjet 1100
This very simple solution works on my Business Inkjet 1100.
1) Turn the printer off, then back on, to clear the error.
2) Set your computer's clock back to a date prior to the cartridge expiry date.
3) Print something, (any documents will do).
4) Set your computer's clock forward to the correct date and the printer should still print, and ignore the expired cartridges.
My 1100 re-checks the cartridges and dates occasionally, but not frequently (it has been about two months between checks) so you might need to repeat this process every two months or so until you have used up your expired cartridges.
This solution is much easier than dismantling the printer and changing/removing wires!
Posted on Dec 16, 2009
SOURCE: HP Officejet Pro L7800. Had paper jam, but opened
mine was 2 there was paper stuck in the little white gears
Posted on Jul 17, 2010
HP Officejet Pro 8000 printing test page and hp advertisements but nothing else?
You may want to go to the HP website and download the software. It may need updated
May 23, 2014 | HP Officejet Pro8000 InkJet Printer
After installing new ink cartridges, when printing black and white, every 4th line of text is only partially printed
Some of the black print head nozzles maybe blocked.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Apr 15, 2013 | HP Officejet Pro 8000 Wireless InkJet...
Ph8000 prints a network configuration page every time I print
Go into your settings under reports. You should be able to adjust to your liking.
Sep 28, 2012 | HP Officejet Pro 8000 Wireless InkJet...
I have an hp 8000 and it is printing blue in place of green
Use the software the printer came with and clean the print heads
Aug 05, 2012 | HP Officejet Pro 8000 Wireless InkJet...
Printer claims ink cartridge is expired and won't let me print
Hello, if you change the date on your computer to 3 months previous (say), then reboot, you can probably overcome this temporarily. Obviously, for normal operation it's best to restore the date to current, and only set the date back when you want to print something.Regards,nicam49
Jan 10, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
The following printhead has a problem black yellow k y
I have brand new print head and saids that there is a problem with the printer head and will not print nothing the black will not go to the print head need code to over ride and print something in black and white I've tried to shut it down and restarted for 30 sec. and for 15 min's did not work keeps coming up that there's a problem with the printer head model #C8187A-013 serial # MY76553H2 series Officejet Pro L7580 All-in-One email: robertcforce@gmail.com
Nov 02, 2010 | HP Officejet Pro L7580 All-In-One InkJet...
How to print an envelope on the officejet pro
You have to remove the stack of paper, and then bring the "guide walls" to the center. Just found out. I haven't tested it but it should work.
Oct 06, 2009 | HP Officejet Pro8000 InkJet Printer
HP Officejet Pro 8000 Printer goes through motion of printing but page comes out blank
your pint head dirty. so pls clean with wet close. if not work try soak with warm water until all dry ink gone pls be carefull when you do that make sure your print head dry before you use again.
Aug 10, 2009 | HP Photosmart 8250 InkJet Printer
HP Officejet Pro8000 InkJet Printer Logo
91 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
