Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
The agitater has stopped working
My washing machine is a wirlpool ultamate care 2 . I need a schematic of the motor because I believe the belt needs replacing but Im not sure.
    President:
  • 1,214 Answers
Belt needing to be replaced is obvious.
As for a schematic of the motor, I think what you are really needing is a wiring diagram and schematic of the complete washing machine. Most often, there is a paper one glued to the inside of the removable panel on the back of the washing machine. Either there, or inside the control head on the top of the washing machine.
Please include the specific model number in any replies.
Posted on Jan 19, 2009
Whirlpool ultamate care 2 is making loud noise on spin cycle
1. Maybe you need to level the machine.
2. Open the drain hose from the pump and see if you find something stuck there
Aug 20, 2014 | Washing Machines
Will not drain, spin or agitate
make this test and fix it. God bless you
First you will need to identify if you have a direct drive type or a belt drive. The later is obvious if you have belts under your machine it is a belt drive, if not it is a direct drive. Also there are 2 basic agitator types with some variances among them. The 2 piece and the single.
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dog .
Agitator Coupling / Spline
The other type depending on age of your machine use a spline. Newer GE types have a coupling that gets stripped out and the older GE type has a spline directly on the agitater that gets stripped out. You will need to remove the agitator. The dispenser usually pulls right out. This will give you access to the bolt that holds the agitater down. Remove the bolt, then place your fingers under the agitator and pull up. This can take some force. A belt slid under the agitater can also work. Once off you will see if it is stripped or not.
Belt
If your washer is a belt drive type make sure the belt is tight. Check for black soot from belt wear. Replace if it has excessive wear or broke.
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente motor coupler.
Transmission
The transmission does not usually fail. To check this on a direct drive remove the motor and then turn tub inside. If it spins freely with no noise the problem is elsewhere. If it is noisy it needs replacing this is expensive and depending on the age of your machine you may not want to replace it. On a belt drive remove the belts and spin tub.
Jul 25, 2013 | Washing Machines
Vbsr2080woww
follow this steps and fix it. God bless you
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitator dogs follow video.
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacemente of motor coupler
Transmission
Jul 09, 2013 | Washing Machines
Agitator not working wont wash water does drain
see this steps and fix it. GOd bless you
Agitator Dogs
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of motor coupler
Transmission
Will not agitate, motor runs ok and will spin dry ok.installed a slightly shorter drive belt on and it would agitate but not spin dry, I have a new bet kit ordered is there something else to check, th
see this causes and fix it. God bless you
Agitator Dogs
The agitator dogs are in the 2 piece type of agitator. These wear out over time. They also break and can cause noise. To inspect and replace the agitaor dogs follow video.
Belt
Motor Coupler
This is a fairly common problem with direct drive machines but inexpensive and easy to replace. The Motor Coupler transfers power from the motor to the transmission. The following video will walk you through the replacement of the Motor Coupler.
Transmission
Oct 02, 2012 | Maytag Washing Machines
After top load washer fills with water you can hear the agitator but the agitator does not move
IF WIRLPOOL AGITATOR DOGS FUNNY A REMOVE CAP OF AGETATER REMOVE CAP INSIDE AGITATER REMOVE 7-16 NUT PULL AGITATER OFF FIRST CHECK TO SEE IF IT SPINS IF IT DOES DOGS IF NOT A DRIVE COUPLER IS YOU PROP ITS INBETWEEN YOUR PUMP AND MOTOR
Apr 03, 2010 | Washing Machines
Belt is squealing agitater not turning
The belt needs tightening -- it's slipping, causing the squealing and preventing it from turning the agitator.
Unplug machine, remove back to access motor. You'l see adjusting bolt(s) -- loosen them -- pry motor to get tension on belt -- while holding motor in place tighten adjusting bolt(s).
More info, let me know.
Charlie
Sep 01, 2009 | Maytag Washing Machines
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 6451 Stops abruptly at end of rinse cycle
sounds like the brakes squeal to me is that the end of the cycle if it is i would worry about it brakes do that not worth the effort of dealing with
Jan 27, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
143 people viewed this question
Dan Webster
Dan Webster
Sal De
