I have a htr-3065 Yamaha amp. I want to lock the unit to just run 2 channel stereo permanently as I only have 2 quality speakers and every time it powers down I have to re select 2channel stereo which is annoying. Is this possible?
SOURCE: Yamaha HTR-5990 Receiver
I JUST EXPERIENCED THE SAME SITUATION HERE IS THE SOULTION YAMAHA SENT ME TO RESET THE SYSTEM HTR-5990 YAMAHA HTR-5990 FACTORY PRESET PROCEDURES All models require the STANDBY/ON button to be turned OFF to start the reset process. NOTE: The remote control cannot be used during the reset procedure. All necessary buttons to complete the reset process are located on the front panel of the receiver. This procedure is not intended to correct intermittent shut-off symptoms or problems MODEL: HTR-5990 (U.S.A. model/s) (BEFORE YOU CONTINUE, PLEASE READ THE ABOVE NOTES!) 1. Before you start this procedure, locate the MASTER ON/OFF button and the STRAIGHT/EFFECT button on the Front Panel of the unit. 2. MAKE SURE THAT YOUR RECEIVER’S MASTER ON/OFF HAS BEEN TURNED OFF. 3. With the Right Hand, press and hold the STRAIGHT/EFFECT button. With the Left Hand, press the MASTER ON/OFF button and HOLD both buttons for no more than “3” SECONDS, AT THE SAME TIME. SP IMP. * 8 MIN. will appear on the display, which indicates you are in the Diagnostics Mode. 4. Rotate the PROGRAM KNOB to the right (ONCE) until the display reads PRESET *CANCEL. 5. Press the STRAIGHT/EFFECT button (ONCE) and the display will change to PRESET RESET. 6. Turn the unit off by pressing the MASTER ON/OFF button. 7. Wait 5 seconds, then turn the unit on by pressing the MASTER ON/OFF button. You have now reset your component to the factory settings. NOTE: Yamaha receivers don’t have to be reset during normal operation. It is not recommended that you reset the receiver unless a setting has been changed that you are not aware of, or the receiver is not operating properly. The reset procedure will clear an incorrect setting that might be causing abnormal operation. GOOD LUCK
Posted on Jul 30, 2007
petraman7
  • 1175 Answers
SOURCE: HTR-6130 will not turn on
Hi
Does the receiver have a switch that allows you to turn off all the speakers?
If so,turn them off and see if the problem stays.
If it still kicks off then , one of the power amp outputs has failed and it will require some fixing
Posted on Feb 04, 2009
smarthome2
  • 1114 Answers
SOURCE: HTR-5740 Subwoofer Hooking Up Issue
You can use a hi-level to low-level adapter. Just remember, the Yamaha does not send power (wattage) to the sub, just signal. You need to use a subwoofer that has an amplifier either externally or built in.
Posted on Jun 26, 2009
SOURCE: Speaker imbalance in Yamaha HTR-5630
how do i hook up a yamaha natural sound av receiver htr 5630
Posted on Aug 05, 2009
  • 4234 Answers
SOURCE: no sound from htr-5840 when switched on. I hear
These units have protection circuits that will prevent the speaker relay from engaging if there is a problem detected. There is also a circuit that causes a delay in the engaging of the relay to allow the amp to "settle in". This prevents the old "thump" that was common in older models when the set was first turned on. In your case, either the RC circuit is faulty causing excessive time to pass before turning on the relay, or there is excessive voltage floating around that the protection circuits are detecting and thus preventing the relay from turning on.
In any case, this will require additional diagnosis using some test equipment. This is not a problem that will be easily resolved remotely. Please bring this unit to a repair shop for an estimate. Once you have that info, we can assist with the actual repair.
Dan
Posted on Aug 25, 2009
I have a HTR-3065 receiver and no sound in center speaker
Try changing surround modes - the center channel is not used in all modes. If that doesn;t work, check your speaker settingsw and make sure the center channel is not turned off
Feb 22, 2015 | Yamaha HTR-3065 5.1 Channel AV...
What's your problem?how to reset yamaha htr 3065 to factory settings
I had the same trouble to reset this machine into factory setting and finally, I found out. Let's do this way.
- Leave your remote away as you won't need it
- Turn off the the unit to STANDBY mode
- Press and hold STRAIGHT button on the unit and press Power button while you are holding it. This will turn on the machine.
- Once the machine turns on, press PROGRAM to select the items on LCD display until it shows INIT **** CANCEL
- Press STRAIGHT button until it turns to INIT **** ALL
- Press Power to turn off the machine.
- Leave it for 2 sec. then turn on the machine again.
Now your unit turns to factory default setting.
Feb 25, 2013 | Yamaha HTR-3065
How do you hook up a external amp to a yamaha HTR-5790 av receiver? Do you have to change any settings?
Elaborate a bit on what you're trying to do if this doesn't work for you.
This unit has Pre Outs near the center of the rear panel for all audio channels which will allow you to use external amplification for any speakers you wish to use and the receiver will still control the volume.
See #12 on page 10 of the manual. Try retrevo.com
Just run RCA cable(s) from the desired Pre-Out jack to the input(s) on the external amp with its speaker(s) attached. Set the external amp's volume (if it has one) to very high, then leave it alone. Run through the Yamaha's speaker location and volume settings to level-match the external speakers to the rest.
If you want to simultaneously use the Yamaha-attached speakers for the same channels as the external amp you'll have to match the like channel volumes to each other using a volume control on your external amp, then level-match them as a unit to the other channels.
Dec 23, 2010 | Yamaha Audio Players & Recorders
Is there any way i can use all channels regardless of source? i would like to understand what i need have as an input source inorder to use all 5.1 or at least 4 speakers
The answer is yes - and no. By definition, audio sources are encoded or recorded in a specific manner. If I record a stereo signal, there really are no rear channels or center or bass specific channels. To be most faithful to the original, you play back stereo in stereo and 5:1 in 5:1 and so on. There ARE several units designed to "synthesize" additional channels from sources that do not contain all the info specifically. Some multi-channel receivers/amps incorporate such circuits and you can "derive" rear channels from stereo inputs and so forth. If not, you may need an additional box (device) to turn 2 into 4 or 5, 3 from 2 and so on. Your choice but that's how it works.
Oct 22, 2010 | Yamaha HTR-6130 Receiver
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
Stereo Set up
The physical TV is at best a lo-fi 2-channel analog audio device. Think about it this way: Most high-end users use video monitors (no audio or speakers on board). So where does the TV-related audio come from....
It comes from the same place the TV would get it - cable, satellite, dvd, blu-ray, vcr...
So why run audio from any of those sources to the TV and back to the receiver (whose specialty is
multi-channel sound)?
I imagine your cable or satellite box has Digital and Analog Audio Outputs. The receiver needs a digital input for anything multi-channel. Select the highest-quality one that's compatible with your HTR and use it for the audio feed.
You have one coaxial and one optical digital input. I imagine your (unnamed) DVD player has one or both types and your cable box has one or both types. If you have one of each type you're golden. Run each to its compatible input on the HTR.
If they're both optical, you have to make a choice, but if they're both coaxial only you could get away with using an RCA Y-cable to bring them both in to the one input. Then for each to work you would have to make sure the other device is turned off.
The video capabilities of this unit are limited to Composite (single RCA cable). Run one from the DVD and one from the cable box Video Out to the conveniently labeled inputs that match them.
I have no idea what your TV/Monitor has for inputs. If possible run the absolute highest quality video [HDMI, Component (3 RCA cables) or Composite (single RCA cable)] to the TV's inputs along with an RCA pair from DVD and Cable Ananlog Audio Out to the corresponding Audio In's on the TV. This way you can watch and hear TV from its own speakers without needing the Yamaha fired up.
Mar 15, 2009 | Yamaha HTR-5540 Receiver
Htr-5650 2 channel only...no 5.1...HELP!
MAKE SHURE THAT THE OUT PUT SIGNAL FROM YOUR DVD PLAYER IS SET 2 BITSTREAM 2 GET DOLBY DIGITAL AND DTS FROM YOUR AMP.FROM SOURCES LIKE SET TOP BOXS AND OTHER "STEREO" SOURCES YOU WILL GET PROLOGIC2 ,BUT YOU MUST SET YOUR AMP 2 THIS MODE.
HOPE THIS HELPS.
CABLE GUY
Mar 12, 2008 | Yamaha HTR-5650 Receiver
175 people viewed this question
 Grubhead
Grubhead
