Question about Fantech FR100 Inline Fan
Want to oil a noisy bearing in Fantech FR100
How to I dissemble the plastic housing
How do I level my pioneer pl-50 turntable platter
When you removed the platter were there a couple of brass or copper washers around the spindle? If not you could try and find a couple to lift platter. Also check for wobble in the platter new ones can be had. There are clubs you may have to join on facebook that will help you one is Vintage HiFi and stereo mostly a bragging site but very helpful with links to others. that is where I found help with my Pioneer turn tables, also Ebay is where I found parts bought a PL518 sold for parts to fix the two I had.
Nov 17, 2015 | Pioneer Audio Players & Recorders
How do I lubricate it to quiet a noisy fan?
the condenser fan motor usually does not have a placed to oil. sealed bearings. the evaporator fan has plastic plugs on each end of motor you have to remove.
Jun 16, 2015 | Heating & Cooling
The spa blower on my spa is extremely noisy it works fine but it is way to loud to use
If you can access the blower housing, check for an obstruction such as paper, leaves, etc. It could need lube in the bearings/bushings. Also check for cracks in the fan blades (usually plastic).
Oct 28, 2014 | Dryers
How to change noisy bearing on Ariston AQXXF 129
inner and outer drum has to b removed replace the bearing kit 2 bearings one oil seal as kit
Aug 25, 2014 | Ariston Technologies Washing Machines
Fantech FD60EM electronic timer control makes a loud buzzing sound and does not operate the fan
This timer appears to be Leviton LTB60
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html
Timer has 1 year limited warranty, evidently from manufacturer.
If timer is making humming sound, then it is defective, possibly receiving undervoltage on the line, or wiring installed incorrectly.
Switch noisy timer with one of the other timers, and see if problem follows the timer, or is related to the specific location.
Otherwise replace with LTB60 from Amazon for $24.
Or buy Intermatic Ei200 timer, or replace non-electronic with spring-wound timer such as 60-minute Intermatic FD60, or 30-minute FD30, etc.
Nov 18, 2012 | Fantech FD60EM Electronic Timer Control
The fan is making a "scratching" noise.
Hi steffmarin...
The scratching noise is one of two problems.
1.noisy fan bearings, cannot be lubricated, must be replaced (big job), or replace fan....
2. Plastic/rubber bearing up near the ceiling...the fan will be connected to it.
Sometimes when they get dry they get noisy.
You can spray the plastic/rubber bearing with a little WD-40 and it will hold the noise quite for a while...be sure to "wiggle" the fan around after spraying to distribute the WD-40) evenly.
If your noise problem is this then problem solved.
Please take time to rate me
Jul 22, 2011 | Hampton Bay 52 In. Ceiling Fan, San Tropez
How do you do any maintenance (oiling or greasing - whichever is applicable) of rear wheel bearings in a 1987 jaguar xj6?
You don't. The bearing is greased for life. If the bearing is noisy it needs replacement.
FYI: Dismantling and greasing bearings does more harm than good due to the introduction of dirt, no matter how careful you are.
Modern greases are very sophisticated formulas of oil and soaps and last a long time.
Long gone are the days of white soap chassis grease that lasted 15,000 miles.
If the manufacture wanted it greased they would have installed a grease nipple in the housing.
However, over greasing a wheel bearing can sling grease onto nearby brakes and hoses.
The drive shaft CV joints are another thing however and you will find grease nipples in each joint behind the splash sleeves.
Jan 14, 2011 | 1987 Jaguar XJ6
Numatic gve370 canister wet/dry motor gone noisy
Try blowing out the motor housing with commpressed air through the cooling vents as it is running, if that dont quiet it down it may be the bearings are dry and need to be oiled, use 20w 3 in 1 oil in the blue container.
Nov 11, 2009 | Numatic GVE370 Canister Wet/Dry Vacuum
Very noisy Hoover VHD9143ZD washing machine - just 2 years old
yes bearing housing get loose in plastic drum. needs drum replacement.
Oct 29, 2009 | Candy Washing Machines
Fan problem
hi remove the net spry lubrication on bearings and the motor see if u spot on 1 of the blads signs of grinding if soo twist this blade the other way good luck windman
Nov 16, 2005 | Honeywell HT-800 Table Fan
Fantech FR100 Inline Fan Logo
64 people viewed this question
Top Fantech Electrical Supplies Experts
ken skalski
Gene Haynes
Are you a Fantech Electrical Supply Expert? Answer questions, earn points and help others
