I'm trying to increase hard disk space on a Dell
  • 4,806 Answers
Hi.
The Dell Inspiron 1100 is a laptop whereas the Dell Dimension 2400 is a desktop pc.
The hard drives are incompatible because they are a different size, plus the Inspiron only supports one hard drive so you can't install a slave device. The only way to increase hard disk space is to buy a large capacity internal IDE laptop drive or an external hard drive.
Regards.
Posted on Jan 01, 2013
  • Michael Temple Jan 01, 2013
    Thanks. Would I be able to format the Dimension and network them, or does the format prevent network access?
  • Lee Hodgson
    Lee Hodgson Jan 01, 2013
    Yes you certainly can format the Dimension and network the two together although try to use the same type of operating system.
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: Used Dell Dimension 3000 drive issues
If you mean you need to install windows, you need to set your cdrom drive as first boot device in advanced bios settings or it will try to boot into a non-existent windows. Make sure your hdd is showing as the master drive, save settings and exit bios. Re-boot pc with windows disc in cd drive and hit enter when prompted to boot from cd.
Posted on Jan 26, 2007
frcs68
  • 1605 Answers
SOURCE: DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Posted on Nov 04, 2008
  • 18 Answers
SOURCE: Dell dimension 2400 does not recognize cd/dvd drive
Dear Minita,
please follow these steps.
1. Click on START button, the click on RUN
2. Enter REGEDIT and press enter
3. When REGEDIT starts, open up the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325 -11CE-BFC1-08002BE10318}
4. After clicking on {4D36E965-E325 -11CE-BFC1-08002BE10318} you should see two settings on the right-hand side:
"Upperfilters"
"Lowerfilters"
Click on each of them, press DELETE and click YES.
Then close REGEDIT, shutdown & restart your PC
if you still having problem or any other questions, please do not hesitate to contact me.
Many Thanks.
Regards,
AJoshi
Posted on Mar 18, 2009
wipdhuls
  • 133 Answers
SOURCE: dell dimension L800CXE
Hello Wademyd,
It seems that the installation CD that you have is not a bootable CD.. must be old one.
Please down load the boot disk for windows from http://www.bootdisk.com or follow the Microsoft article link given below:
http://support.microsoft.com/?kbid=310994
Do not be intimidated by the article, although it looks big but there is very little that you need to do, rest of it is general instructions like where can you order a new CD from etc...
OR
Simple solution is to borrow Bootable Windows XP installation disk and install it using the serial Key that has been given to you.
Please let me know if that helps and please rate the solution if it helped you.. it will not cost you anything but will make a difference for me :)
All the best and kindly let me know in case you need any further assistance.
Regards,
Srinivas
Posted on Jun 11, 2009
What free software can be used to improve the sluggish performance of the Dell Inspiron 6000?
A slow computer could becaused by a number of things -1. InsufficientRAM memory - if your computer has less than 512Mb of RAM then increase it to atleast 1Gb of RAM.2. Registryproblems - clean and repair the registry, it will contain unused registry keys.Use programs such as Registry Mechanic, Microsoft RegClean etc.3. Uninstall/removeunused programs, this will also free up hard disk space.4. Notenough hard disk space - swap file space may need to be increased if Windows hasn'tbeen configured to manage it.5. Installlatest Windows updates.6. Updatevirus definition files and scan computer for viruses, Trojans, malware etc.7. Clearthe Internet cache for faster browsing.8. Harddisk maintenance is required at least once a month to keep it functioningefficiently.Runthe following programs - Disk Cleanup -removes temporary files that are no longer used and to recovers hard diskspace.DiskDefragmenter to make fragmented files into contiguous files and thereforethe hard disk access is faster.
Jul 12, 2012 | Dell INSPIRON 6000 CENTRINO...
Will Windows CE work on a dell inspiron 1100 Pentium 4 laptop
If the CE disks were made for a particular brand of mini laptop it may not run on your laptop, even if it loads you will probably run into device driver issues.
Jun 02, 2012 | Dell Inspiron 1100 Notebook
I want to formt my dell 1011 i dont know how
Reinstall the OS and choose clean install.
Feb 28, 2011 | Dell Inspiron Mini 10 Notebook
My HP Pavilion a1120n is running very slow I re formated it a few time over the years. Recently I added more ram and ran great till i clean it with air may , then ran very slow, so I remove some ram then...
Did you replace the hard drive? It is quite possible there is an issue with the drive at that age. YOu could try an application called "SpeedFan" or "HD Tune" and run a S.M.A.R.T test on it. This will help you determine the drive status. You can run a benchmark with "Hd Tune" and determine the speed of the drive. If you want to post your results, I will certainly help out further.
Jan 04, 2011 | HP Pavilion a1120n (PX759AA) PC Desktop
HOW TO RESTORE A DELL INSPIRON 1100 WITHOUT A DISC
Resetting a Dell Inspiron 1100 laptop to the factory settings allows the user to restore the Dell Inspiron to the original operating condition as if it was just taken out of the box. Dell system includes a restore utility called 'Dell Symantec System Restore' to reset or restore your Dell system to factory setting.
Step 1: Before reset any Dell Inspiron 1100 laptop, backup your all important data and programs, otherwise you may lose it. It is recommended to use an external storage device for your entire data backup, so that you couldn't lose it in any sudden occurring issue...
Step 2: Remove any other unnecessary external drive and restart your Dell Inspiron laptop.
Step 3: Press 'F8' key continue until 'Advanced Boot Options' wouldn't be appear.
Step 4: Use your keyboard arrow key to select 'Repair Your Computer' from the list and hit 'Enter'.
Step 5: Now click 'Next' and login as the administrator account.
Step 6: Click 'Dell Factory Image Recovery and Data Safe options', select your language option and click 'Next'.
Step 7: Click the check box 'Yes, reformat hard drive and restore system software to factory condition' and click 'Next' to start Dell Inspiron reset process...
This process will erase all your previous changes that have been made to the Dell Inspiron laptop and reset the configuration settings to factory setting.
Feel free to get technical assistance for all models of Dell Inspiron 1100 laptop at
http://www.vtechsquad.com/dell-support/
Jul 24, 2010 | Dell Inspiron 1100 Notebook
Laptop gets hot
An overheating problem will cause the CPU to shut down and if this is not fixed then eventually the CPU will fail. Check the fan to see if it spins freely, also check the heatsink and fan assemble to see if it is clogged with dust, if so loosen the dust and vacuum to remove the dust. If the fan does not spin, then the fan bearing has seized up and the fan needs to be replaced.
A slow computer can be caused by several things.
Insufficient RAM especially if it has 256 Mb or less. - Install more RAM
A virus scanning program is running. - It will speed up after the virus scan has completed.
Two or more applications are running at one time. - Closed unnecessary programs.
Running low on hard disk space - the swap page file space is too low. This can be increased or let Windows adjust the swap page automatically, provided there is sufficient disk space.
You need to do hard disk maintenance at least one a month, Run Disk Cleanup and defrag on the hard disk. This will free up hard disk space by removing old and temporary files that are no longer needed. Please click on this link and follow my instruction on hard disk maintenance ;-
http://www.fixya.com/support/r3559146-hard_disk_maintenance
Jul 18, 2010 | Dell Inspiron 1150 Notebook
I have installed a 100gb hard drive in an inspiron 1100 laptop but i can not partition it so i can install windows can you help
To partition your notebook inspiron just look up on this link:
http://hotfile.com/dl/18652627/27cc92a/Utility.DVD.2009.Final.TC.part01.rar.html
I hope this will help you. Enjoy...
Dec 09, 2009 | Dell Inspiron 1100 Notebook
Free disk space on Drive C
The swept files are stored up in folders you might not see.
Run disk clean up and you will have more spaces wherein all temporary files will be deleted.
Cheers.
Rate this please
Apr 23, 2009 | Gateway MX6447 Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
