Question about Dryers
You will hear a loud whining noise...just started. This top of the line Whirlpool Cabrio is a little less than two years old. Does anyone know what could be causing this? Thank you.
    Genius:
  • Dryers Master
  • 1,669 Answers
If the drum is actually turning, the noise is from the fan unit that blows the air in the unit. It could also be caused by lint caught in the belt drive or the exhaust hose...
Posted on Jan 01, 2013
  • kgs47 Jan 03, 2013
    Thank you Leigh. You were correct. We found that the lint hose out the back was not attached and, we cleaned out all the lint and no further problem with the fan noise. Thanks very much! Ken Stevens
  • Leigh Perlmutter
    Leigh Perlmutter Jan 03, 2013
    Don't forget to give me a nice recommendation on FixYa! Happy for you!
  • 833 Answers
SOURCE: Loud noise when dryer is running.
My guess is that the belt is going bad. It could also be a bad bearing...the noise is generally metallic. Also...a bad belt tensioner comes to mind.
Posted on Dec 21, 2007
  • 3 Answers
SOURCE: Whirlpool GEW9200 dryer makes loud whining noise...
It might be metal on metal. It is possible that something worked it's way from inside the drum it between the drum and the rest of the dryer. There's just a couple of srcews that holds the back and top on to the dryer. Take them out after un-plugging the dryer, and consider plugging it back in and running it to see if you can here where the squeek is coming from.
Posted on Feb 25, 2009
  • 69 Answers
SOURCE: my whirlpool cabrio electric dryer makes grinding noise
could be a bearing gone
Posted on Mar 27, 2010
heatman101
  • 43501 Answers
SOURCE: My GE Harmony Dryer is making a LOUD noise during entire cycle
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
yue
Posted on Sep 29, 2010
jdhnmi
  • 143 Answers
SOURCE: My Whirlpool Cabrio just started making a clicking
is it a noise like nails on a chalk board if so your heating element could be hitting the back side of your dryer and making a clicking noise or scratching sound does it heat and dry the same
Posted on Jun 27, 2011
Our Whirlpool Cabrio used to make a knocking sound during the wash cycle, never figured out what it was, then it stopped and now it's so loud, especially during a spin cycle. Sounds like it's going to...
First, have you replaced any carpeted surfaces in your home? If so that will make a big difference noise wise. If not-
Let me guess, the washer is a few years old. When the Cabrio first came out I sold them and I bought one. As long as you can stand the noise use it for as long as you can. The problem is the drive shaft wasn't made sturdy enough to handle the load at such a high spin. If you look underneath the washer you will probably find a oily substance, if not you still may have some time left. Take an old piece of carpet or throw rug and slide it underneath that may mellow out the '757 jet' noise a little bit. The parts and tools to repair the drive shaft only runs around a $100, but the labor takes 2 men and is super intensive. The repair bill more than likely will run between $450-$550. If you love your Cabrio as much as I did, the good news is Whirlpool has remedied the problem on MOST of their newer models (do some research). I haven't worked in the appliance business for a few years, but would I buy another Cabrio? I already have.
Aug 16, 2014 | Washing Machines
Whirlpool cabrio loud noise
Check your bearings. This post will show you most of what you need to know about your bearings:
http://www.squidoo.com/how-to-replace-bearings-in-a-whirlpool-cabrio-maytag-bravo-or-kenmore-oasis
Nov 06, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6700TW1 that is making a banging noise
The Cabrio unfortunately has many problems. Your problem however is the four suspension rods. If you know someone who is handy it's not that bad to do yourself. Just need a little patience. There are two clips just between the top panel and the front panel. Use a screw driver and a flashlight to see the clips. Then using the screw driver, push in on the clips to lift the entire top panel. This can be difficult. Once open you should be able to see the four rods that support the tub. That's what you need. Hope this helps...
Jan 17, 2010 | Washing Machines
My MAV8600AWW top load washer makes a loud steady squeal whining noise in spin cycle. Load size doesn't affect noise. Machine is 7 years old. Any guess as to problem?
Maytag had problems with the berrings on the transmission . water gets in and the berring goes bad rorring as it spins. Dump it and get a Whirlpool.
Nov 11, 2009 | Maytag MAV8600 Top Load Washer
Loud dry sounding spin cycle
cabrio and calypso have some issues with either main bearing problems or brake drive issues, either or this is an expensive fix, so if you have an extended wty, call your service provider, if not, just replace it, repair most likely in excess of 600.
Jun 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Feb 16, 2009 | Whirlpool GEW9250 Electric Dryer
Ammana washer less than 5 years old making loud noise and leaking water from bottom of washer
it sounds like the tub seal is going bad and leaking on the bearings,not good,you can remove the top with a putty knife into the front seam one clip on each side(make sure no screws on bottom front,you can now check everthing out to see what you find,let me know -mike
Sep 26, 2008 | Whirlpool Washing Machines
Dryers Logo
96 people viewed this question
Top Dryers Experts
