Question about Home
How to open the lid of toto sw 660 j - Home
The push button dual flush system on my Toto toilet is not working
the connection rod (under the cistern lid is not connecting or is broken off.. lift the lid adn have a look.
Oct 03, 2013 | Toto Home
The dual flush push button flushing unit on my Toto cistren is not working
the connection rod under the lid is broken or not making the connection just lift the lift to see.
Oct 03, 2013 | Toto Aquia II Dual Flush Toilet
What is the velcro that came with my toto tank lid used for?
it is used to soften the lid to tank and keep it from rocking and china from rubbing
Mar 15, 2013 | Toto TCU974CRE-12 Toilet Tank Lid with...
Toto toilet won't flush
Replace the assembly. This is common in areas with high mineral content in water. You will be glad you did. Delay too long, you may find your toilet running while you are at work .
Jan 25, 2013 | Toto Drake ADA Compliant Toilet with...
How can you disconnect the lid switch so the washer works when the lid is open? I am asking this because the switch has failed, and I want to bypass it, not fix it.
by passing the lid sw is ok if owner is only on that uses it . but this sw is there for a reason .( I think you know why . ) if you by pass it it may save yor a small part cost . but what if you open the lid and its still spinning and your hand or arm gets caught in it . and in some cases i know of the agitator and come loose and damaged the lid but the machine did stop . hope this helped mm
Oct 13, 2010 | Kenmore 22422 Top Load Washer
Toto toilet is constantly running, even though the tank is full
it sounds like it might be the floater ball in the toilet you can adjust the tension on it usually with a screwdriver.... if you look from the top down you should see a screw on the top of the arm that holds the floater adjust the tension and hopefully this will work
Jan 20, 2010 | Toto Drake ADA Compliant Toilet with...
-Washer Lid Switch 3949247 (3949237) for WhirlpooI received and installed a washer lid switch. Washer runs fine, only thing is when the lid is opened the washer does not stop. Lid switch is suppose to stop...
why did you change sw/ did washer not spin ? or same problem . you may have a shorted of faulty ( new ) sw . just because its new doesn't make it good / ck with ohm meter .. if the problem is same as before sw installed the we need to lok at a different problem . like ( timer ) or wiriing . ) mm give me some feed back and wi can go / and model # brand .. . help is on it way .. mm
Dec 12, 2009 | Washing Machines
The button that engages when the lid is shut
512 are some of the best maytag made. the lid assemble is also you off balance . you should purchase a lid sw/ assemblyl and replace it . it's not a hard job .the lid will pop off if you pull it hard / do not lose the lid balls / this will let you get to the screws . p s order extra lid balls when you get the sw . they some time break . mm
Nov 22, 2009 | Refrigerators
Home Logo
29 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
