Question about EliteGroup P4S5MG/GL+ Motherboard
Not boot from flash drive - EliteGroup P4S5MG/GL+ Motherboard
    Renaissance:
    An user who is expert in 3 categories / brands.
  • EliteGroup Master
  • 2,226 Answers
Go into cmos and change it to boot up
Posted on May 27, 2014
Motherboard shows many boot devicess ...which one i choose from it... to boot from usb drive
pls check how detecting usb device , as a flash drive or Hard drive
if hard drive pls check boot order in hard drives and set up flash drive name first
Nov 19, 2016 | Computers & Internet
Ze5170 not showing usb flash as boot option
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 0-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some older bios's may refer to your flash drive as a USB floppy or USB zip.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. There are several programs available if you do a Google search that will help you make your USB Flash Drive bootable as well.
Jan 17, 2014 | HP Pavilion ze5170 Notebook
Can't Boot From Flash Drive(Gateway ZE6)
I think it will describe hard drive then usb then LAN? If you set it to usb it should find it. Don't forget yo press F10 when selection is complete.
Dec 05, 2013 | Computers & Internet
How do I boot from a usb flash drive?
Go into BIOS by pressing correct F key that is noted during boot. Make USB drive 1rst boot, save and exit.
The USB installation also needs to be bootable and made so with software like Novicorp
Dec 13, 2012 | Everex StepNote NC1500 Notebook
Dont work and dont format
When the flash drive is inserted and is still detected Kingston, flash drives can be repaired and the data can be saved. Cause, there is damage to the partition table
Solution:
1. Save the data. To saved data, you can use EASEUS Data Recovery software.
2. After the data is saved, to fix the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
How to install the HP Drive Key Boot Utility to the operating system
Win XP: double click the file cp006049.exe - select Install
Win Vista & 7: double click the file cp006049.exe - select extrack
How to use the software HP Drive Key Boot Utility
For
Win XP, first way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For
Win XP, second way:
Insert the flash drive - open the HP Drive Key Boot Utility - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\Program Files\Compaq\hpdkbu\ flash\initrd.img - Next - wait until the process is complete.
For Win Vista & 7
, first way:
Insert the flash drive - double click cp006049.exe - for example, extract to C:\HP Drive Key Boot. Open folder C:\HP Drive Key Boot then double click file hpdkbu.exe - Next - select flash drives - Next - Create New or Replace ..., select Next - Next select Hard Drive - Create New File system, select Next - wait for the process is completed - Select Next - HP firmware Flash ..., select Next - wait for the process is completed - finish. Then, quick format the flash drive.
For Win Vista & 7, second way:
double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
initrd.img files, the image file for the schema partition flash drive capacity <= 2GB. For capacity >2GB, example: 4GB, 8GB, 16GB, 32GB, etc when we use the initrd.img file, will be changed to 2GB capacity. To restore the capacity of flash drives, do the Low Level Format. To make the process of Low Level Format, use software HDD Low Level Format Tool.
How to restore the capacity of flash drive Kingston
Open HDD Low Level Format Tool - select drive - Continue - click S.M.A.R.T - click Get SMART Attributes - click the tab LOW LEVEL FORMAT - click Format This Device - wait for the process is completed - Finish. Then, remove the flash drive from the computer, then insert it again. Then do a quick format the flash drive. Finish
Hope it helps
Sep 06, 2011 | Kingston Technologies 512MB DataTraveler I...
Sudenly kingstone usb changed to skymedi and doesnt formated
How to save data
To save data, use software full version, for example, you can use EASEUS Data Recovery. After the data is saved, do the repair flash drive.
Repair flash drive Kingston
1. Right-click the flash drive, select Format - select quick format. If this does not work, don't repeat, do the second.
2. Format from Administrative Tools.
Win XP: click START - Control Panel - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - select quick format
Win Vista & 7: click START - Control Panel - select View by: Large Icons - Administrative Tools - Computer Management - Disk Management - right click the flash drive - select Format - Perform a quick format - OK. If this does not work, don't repeat, do the third process.
3. Format using the software, the HP USB Disk Storage Format Tool. Make the process quick format. If this does not work, don't repeat, do the fourth.
4. Repair the flash drive using the software HP Drive Key Boot Utility (Support Win XP, Vista, 7)
Win Vista & 7: double click the file cp006049.exe - select extract
For Win XP, first way
For Win XP, second way
For Win Vista & 7, first way
Insert the flash drive - double click file hpdkbu.exe - Next - select flash drives - Next - select Backup/Restore - Next - click Restore - click browse, open file C:\HP Drive Key Boot\initrd.img - Next - wait until the process is complete.
Description
Hope it helps.
Sep 04, 2011 | Kingston Technologies 512MB DataTraveler I...
I need boot my computer from usb. what I need?
Generally, you need a few things:
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS settings to make this possible assuming your BIOS supports it. Some BIOS's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions.
Check out this comprehensive link to make a bootable USB / flash drive in your choice of several different Operating Systems.
I hope this helps and good luck. Please rate my reply. Thank you!
Apr 13, 2011 | Sony VAIO VGN-SR220J/B Laptop
How to boot laptop from usb flash disk
When u just turn on your laptop go to bios settings.....in bios settings change the boot priority to USB flashdrive....save and restart before you restart connect your flash drive to ur laptop......it will ask boot from flash drive press any key....n contiune...hope this helps
Mar 11, 2010 | Computers & Internet
Need to perform factory restoe on compaq nc4400 laptop. laptop has no disc drive, i do have an external memory to store data on
A program called Ultimate Boot CD for Windows might be of assistance, personally I have never used the program but its intentions are to allow you to create a boot cd (or possibly a boot flash drive) to actually boot the entire OS, desktop and everything directly from the flash drive so nothing ever hits the hard drive. However your intentions are to probably try and reinstall the os by booting the setup cd from a flash drive instead of the cds but i'm sure it can help do that as well.
Another attempt might be (if your laptop can boot from a flash drive and is set to do so) copy the entire contents of the restore disk(s) to a flash drive that is large enough to contain it all and have it boot from the flash drive. It should pull the bootup files necessary for it to run from the flash drive but it could also need some things set into it to instruct the computer how to boot it, and off hand I am uncertain of those things required.
This should be able to get you started anyways.
Good Luck
Oct 29, 2008 | Computers & Internet
INSTALLATION
I don't think this is possible. Still we can work on this.
Even I am verymuch Intersted with these kind of issues. I haven't tried installing XP on USB flash drive. But I installed the XP on USB harddrive and it worked.
We can try this with your co-operation. To boot with the USB devices, first your computer or laptop should have the option to boot with the USB devices. You can check in BIOS, under BOOT order for this option.
If USB boot option is not there, then you cannot boot with the Flash drive, not only flash drive all USB devices. They will work only after booting into Windows.
Comming to installation procedure, installtion is same as installing the XP on harddrive. While installing the XP, at partition page, you can see the USB flash drive, select it and continue the installtion.
If your computer has the option to boot with the USB devices and if the flash drive won't boot into Windows after installtion, then we have to set Flash drive as Active partition from Disk Management, and then we can try. In Disk Management, right click on the USB drive and select set active partition. If it won't allow to set the USb flash drive as active, then it is not possible to install XP on flash drive.
Even I googled everywhere on how to do this, but not information.
Try that and let me know the status. But I am sure, it is possible on Pocket drivers or USB harddrives.
Aug 09, 2008 | Computers & Internet
EliteGroup P4S5MG/GL+ Motherboard Logo
47 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
