Question about Sony Great Dav-bc150 5-disc Cd/dvd Receiver / S-master Digital Amplifier
C 31 message from sony dvd amplifier - Sony Great Dav-bc150 5-disc Cd/dvd Receiver / S-master Digital Amplifier
Video Camcorder Error Message
Per SONY; To service the C:31 code, Sony recommends you do the following: Turn off the camcorder. Remove the battery or disconnect the AC power adapter for 60 seconds. Insert the battery or reconnect the AC adapter. Turn on the camcorder. If the error message appears, service may be required.
Sep 15, 2007 | Sony Handycam CCD-TRV608 Camcorder
I have Home Theater Sony DAV- DZ151Kb. Display Push Power and then PROTECTOR. I need Help
Push power protect message appears when home theater got problem in amplifier output section and any output amplifier chip becomes bad, receiver set protection mode and refuse to power up to avoid further damage in circuit board.
It is very hard for novice to troubleshoot what output chip is defective out of six amplifier output ICs in unit, check by professional is needed to solve this issue.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Jan 14, 2011 | Sony Audio Players & Recorders
Sony 5 changer dvd player won't work. displayed code 31
Hi:
This may be caused by one or two causes. The laser pickup assembly is bad or the most common failure for DVD and CD players is the spindle motor. This motors bushings fails over time and does not spin the disc at the right speed so the unit times out. You can repair the by purchasing what sony calles the Mech Assembly it comes with new laser and stepper motor as well as the Spindle motor.
Mar 14, 2010 | Sony DVP-NC600 Multi-disc DVD Player
Code19 on sony cdrwdvd willnot reconize on inspiron 1525
Your CD drive or DVD drive is missing or not recognized by Windows or other programs, so you cannot play or access a CD or DVD. This issue might have occurred after you installed, uninstalled, or updated a program or Windows Vista.
This issue may have occurred after one of the following situations:
  • You upgrade a computer to Windows Vista or install Windows Vista Service Pack 1.
  • You install or uninstall CD or DVD recording programs.
  • You uninstall Microsoft Digital Image.
You may see one of the following error messages:
  • One of the following error messages appears when you view the CD drive or the DVD drive in Device Manager.
    Error message 1 The device is not working properly because Windows cannot load the drivers required for this device (Code 31). Error message 2 A driver for this device was not required, and has been disabled (Code 32 or Code 31). Error message 3 Your registry might be corrupted. (Code 19)
  • An "error code 39" error message.
  • A message that resembles the following appears in the notification area: Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41)
  • you can find this information and more at this site..
  • http://support.microsoft.com/kb/314060
Nov 08, 2009 | Dell OptiPlex GX260 PC Desktop
Dvd not playing.c 31 00 occur
The only thing you can do is get a CD DVD player cleaner with liquid. Found at any store these days, then run it a couple times. If it plays, Problem solved, if not, it must be repaired. They will put a new transport in the unit. Usually runs 100-150 to replace. Weigh the cost to fix vs. the cost to replace and the age of the unit before you get it repaired. Hope this helps
Jun 01, 2009 | Sony MHC-RV888D Shelf System
Error messages / Manual useless
have you run a Head Cleaning tape thru it? definite;y try that...run it for 10 seconds at a time
May 23, 2009 | Sony Handycam CCD-TRV57 Camcorder
Error C:31:00
It seems this sort of problem is very common with this player. The fix I have is pick the player up, rotate it 90° give it a very light nudge, and then put it back. This has fixed the problem on mine each and every time. It will come back, but just do it again. It's probably best to put the dvd player in an easy to reach place cos you'll need to do it often once it starts making the noises and error messages.
May 16, 2008 | Sony DVP-F25 DVD Player
Sony Great Dav-bc150 5-disc Cd/dvd Receiver / S-master Digital Amplifier Logo
65 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
