Question about Bosch Nexxt WTMC 3300 Electric Dryer
My bosch Nexxt WTMC 3300 dryer makes a squeaking sound when the load is light -- drying a larger/wetter load less likely to make the noise.
The dryer is 8+ years old; recently it has started making a squeaking/rubbing sound when running with a small load of laundry. Generally, a full or heavy load won't make the noise, but when a smaller load gets about half dry, the sound starts. The sound is not constant, but pulses about once a second. I suspect it is something in the drum-rotating mechanism, but beyond that I don't know what to look for -- the belt, the main bearing, the drum itself rubbing on something? Could it be something with the front cover, where the front of the drum is supported? Not sure how to diagnose. Suggestions, and/or disassembly instructions would be a great help. Many thanks Matt
    New Friend:
I had a similar problem with a different model Bosch dryer. First I made sure the dryer was unplugged. I found, after taking the front and rear panels off, that one of the front wheels that supports the drum was broken. I replaced the wheel and it works fine with no squeaks.
Posted on Jan 26, 2013
5 Suggested Answers
  • 319 Answers
SOURCE: Bosch nexxt model gas dryer - screaching noise coming from Bearing shield
call tech support
Posted on Mar 11, 2008
SOURCE: Squeaks from drum area during operation
We have a Bosch Nexxt dryer and it, too, squeaks during operation. We have not been able to find a permanent solution for this problem although we've had the repairman come out 3 times now. We have however found a temporary solution that lasts for about a week. We spray Static Guard (in an aerosol can) in the inside lining of the dryer... kind of in the lip of the front. (You shuld be able to feel it if you put your hand right inside the door.) We've just been spraying the static guard all the way around that area and the squeaking stops! Hope this works for y'all. May not be permanent but at least it stops the annoying sqeaking!
Posted on Jan 18, 2009
heatman101
  • 43501 Answers
SOURCE: When the dryer is running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker
Posted on May 03, 2011
  • 150 Answers
SOURCE: Bosch Nexxt WTMC 6300 Electric Dryer won't start/ no light, No power
check and see if the outlit it is plugged in to works with somthing simple like a light somthing may have triped the breaker in your house
Posted on Jun 05, 2012
Hi there!
I think it is the drum main bearing that has started to sieze.
If it is not this, then the drive belt may need replacement.
If this leads to a solution, please take a moment to accept. Thank you.
Jun 18, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
When the dryer is running it sometimes makes a screeching sound momentarily on and off during the dryer cycle. Some cycles it does not make the sound at all. Is something going bad? It doesn't seem to...
heatman101
Asker
May 02, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
When it is on it makes a loud clunking sound
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Apr 02, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
My Bosch Dryer WTMC300us/01 is making a rubbing noise with or without items in the dyer. And it "smells" hot. What's wrong and can I fix it?
heatman101
Asker
Mar 27, 2011 | Bosch Nexxt WTMC 3300 Electric Dryer
After the dryer heats up for a while, it makes a loud squealing noise. It does not stop until the dryer totally cools down. Several certified Bosch repairmen have tried to fix it with no success.
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Nov 28, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Belt, bearings etc. awful awful noises. Need to replace parts! bosch dryer wtmc 3300
heatman101
Oct 29, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt Dryer gets warm but laundry doesn't get dry. Dryer stops after about 10 min of running and starts ''beeping''
this could be a faulty moisture sensor. try running the dryer in a timed dry mode and see what happens.also be sure to make sure all the duct work is free and clear and that the lint filter is clean
Jan 14, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer
I have a Bosch Nexxt WTMC 3300 electric dryer. The dryer doesn't heat up. This is the second time this has happened over a one year period. The first time it happened, the technician reset the thermal cutoff, but said he saw no reason why it should have tripped. Can you tell me how to reset the thermal cutoff or offer another solution?
Apr 25, 2008 | Bosch Nexxt WTMC 3300 Electric Dryer
Bosch Nexxt WTMC 3300 Electric Dryer Logo
163 people viewed this question
Top Bosch Dryers Experts
Lawrence Oravetz
MightyMikeJr
Are you a Bosch Dryer Expert? Answer questions, earn points and help others
