Question about Cameras
Do i need the 3v battery for my camera to work.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
What make and model camera?
Posted on Jan 02, 2013
3 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: AA Battery Drain...just discovered a 3V battery in my camera
Usually the 3v battery holds the date and time in your camera. A lot of time with digital cameras you have to remove the batteries when there not in use for a long period of time to prevent the draining from happening.
Do you have regular AA batteries to see if the meter changes? That would be the best way to see it the camera is reporting the correct battery life.
Posted on Dec 05, 2008
jackboy
  • 2985 Answers
SOURCE: lithium crv3 3v battery and charger and usb cord need to purchase.
Google is a good place to look
Posted on Jul 21, 2008
Camera not starting
charge the battery overnight. try to test the voltage with unimeter/voltmeter to see if the battery is still alive. if battery is full (showing more than 3V voltage) - then camera needs to go to a repair center. if not . get a new battery
Mar 09, 2012 | FUJIFILM FinePix AV100 Digital Camera
Canon gl2 fell from tripod. it hasn't turned on since neither from the power outlet or the battery power. i don't see anything broken or scratches. i put the 3v lithium battery in but no power. i took the...
This is usually caused by a failed component in the power circuit within the camera and can usually be repaired fairly inexpensively. However, it's not a user serviceable problem and will need to be repaired qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Jan 23, 2011 | Canon GL2 Mini DV Digital Camcorder
Need to know what battery type to use for the Vivitar PZ3090 35mm Date-A-Print. It needs a replacement battery. Thanks!
Your camera takes a 3v CR123 battery. Click here for details of the same battery under different model numbers.
They're still easy to obtain.
Sep 12, 2010 | Vivitar Photography
Fuji FinePix S2 Pro won't turn on
I had a very similar problem a couple of years ago. Found intermittent power from AA source when battery tray was moved slightly while shooting. I ordered a new AA battery tray from Fuji ($50 I think), problem solved, no trouble since. The tray must hold the batteries tightly against the contacts inside the camera. Camera had only shot about 5000 frames when the problem arose. Hope this helps.
May 01, 2009 | Fuji FinePix S2 Pro Digital Camera
Cannon EOS Rebel G battery light
Film Advance mechanism is jammed and needs service.
Apr 09, 2009 | Canon EOS Rebel G-II 35mm SLR Camera
AC adapter for ViviCam 3765.
The polarity is correct, but 400mA is not enough. One commercial supply I saw was rated at 2.5A. I even suspect 3v isn't enough as I have tried an external battery pack with D-Cells in it and after a few flash shots it wants new batteries. The camera itself seems to be over-sensitive to "low" voltage and complains about new or freshly charged batteries (see other posts).
There is a problem with these cameras in this battery voltage area. I have asked Vivitar what external voltage to use, but no reply. Good luck! I am sufficiently fed up with this camera that I may try 4.5v external supply and if it blows up, good riddance!
Mar 31, 2009 | Vivitar ViviCam 3765 Digital Camera
Need batteries
Hi there and welcome to FixYa.
Your camera takes 3V CR2 batteries. Your camera takes two of them.
Thanks for coming to FixYa.
Rob
Mar 23, 2009 | Nikon N75 35mm SLR Camera
Dec 05, 2008 | Canon PowerShot A560 Digital Camera
Cameras Logo
18 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
