Question about Harman Kardon AVR 7000
HK AVR-7000 sound cuts out periodically at any volume..
Can't make it do it and there is no pattern might do it once every three songs might do it three times a song just no sound for a second and then back on....thanks Adam
  • Adam R Jan 04, 2013
    Nothing clicking no change in the display ,when listening to a song all of a sudden no sound and without doing anything it's back on in a second...
HK AVR 125 display strobing and no sound, even in headphone jack
Hi...
Find someone that does TV or audio repair and have them open it up. A cable assembly may have loosened during the MOVE.
Cheers
Jan 30, 2014 | Harman Kardon AVR 125 Receiver
No cengter display or sound
I also have the problem of no center display but I do have sound.
On my avr 7000 I am sure that the display is not functioning but on yours try holding the middle select button for three seconds as in the manual this is how you turn the display brightness back on.
I have no clue why they have made it able to be turned off lol
Dec 31, 2013 | Harman Kardon AVR 7000
I have the Harman Kardon AVR 254. Just recently it stopped responding. It will cut on and the volume dial will respond but none of the front panel buttons will. Any suggestions on a fix?
There should be two fuses on the secondary board of the main power transformer. They don't look like regular fuses - they are small round can fuses. These are probably open. HK under-valued these fuses originally, and they need to be replaced with 3.15 amp.
Jan 17, 2013 | Harmon Kardon Harman Kardon Avr 254 7.1...
Headphones not working
try geting a new jack if not bye a now wone
Jul 25, 2012 | Harman Kardon AVR 7000
AVR 1600 receiver won't connect to bose series III EQ
You mean BOSE 901 Series III Active Equalizer; and HARMAN KARDON AVR1600 right?
Sure it will. It goes in a Tape Loop such as Tape Out/In or Video 1 Out/In. But it won't work for anything except analog stereo sound sources as all digital audio is not available to the RECORD OUT jacks when the Tape or Video 1 is activated. AND 901 Active EQ is intended solely for 901's, not any other speaker system
The HK has no Line Level volume-controlled Pre-Outs so you're out of luck if you want the 901's to take part in a multichannel setup, which would require a separate power amp to drive them anyway.
Aug 23, 2011 | Audio Players & Recorders
I just got my hk avr 145 -- works great -- but will only stay on for about 3-4 minutes before it says "protect" and shuts off. I have monster cables supplying 2 baby advent speakers- going to my...
Does this happen at modest or very high volumes? If the latter, is the amp getting hot? Just the two speakers? If yes, ease up. If NO, get it fixed.
Dec 26, 2010 | Harman Kardon AVR 140 Receiver
Hello. I get no sound out of my AVR 7000 Receiver. No cables behind has been touched in the past. I'm trying TEST TONE, and everything seems normal in the display, but still no sound. I use Preout a NAD...
You don't say if all speakers are silent or just the ones to the unspecified NAD power amp. Do ANY speakers work regardless of which device powers them? Could the NAD be the problem?
Dec 25, 2010 | Harman Kardon AVR 7000
HK receiver has power and volume except on video 2
Hi...
What are you running thru Video 2?
Have you unplugged the AC cord and re-powered up yet?
Thanks
Jan 18, 2009 | Harman Kardon AVR 235 Receiver
Harman Kardon AVR 7000 loosing memory
This is what's in the AVR7000 service manual:
Subject: Backup Memory on AVR/DPR/HK series receivers.
In the event of the complaint: “the receiver is losing its memory (any programmed system settings)
when the unit is turned off, or after the unit is unplugged (briefly*)”:
Check and replace:
Model: AVR7000
Designator: C730
Description: 0.047 Farad 5.5v capacitor
Part number: # P10790-ND or # J3432147324X
I'm having the same problem and this is how far i got so far. I don't kwow how to get and replace this part.
Oct 25, 2008 | Harman Kardon AVR 7000
Denon avr-5600 protection circuit.
My AVR 5600 has worked flawlessly for nearly 9 years!
Suddenly, when trying to play music (DVD or CD) through my LS32's (JBLPro), once I achieve higher volume, the receiver cuts off.... Using a Symetrex mixer, NO OVERLOAD light on the Denon, it simply cuts off!
Re-cut all the wire connectors... TV movies (5.1) work great at normal listening volumes.... but tonight, when cranking up music, the receiver simply cut off. Blinking light...
HELP
forfrance@hotmail.com
Apr 12, 2008 | Denon Audio Players & Recorders
Harman Kardon AVR 7000 Logo
56 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
