Question about Whirlpool GH4155XP Microwave Oven
Replacing a circuit board on a microwave
I need to know how to replace a circuit board on a microwave. my model number is GH9177XLQ-0. my serial is TRP1512931. what all do i have to remove.
  • William Miller
    William Miller May 11, 2010
    What problem are you having with the board?
    We regularly repair such control units for
    customers nationwide by mail for $39.95 postpaid in about a
    week with a one-year guarantee.
    We've fixed them when the cooktop lights or fan failed or when the touch screen failed to operate, etc.
    At
    our Web site, we have a video
    available showing how to remove a typical
    over the range control panel assembly in under 5 minutes.
    After that, only a few more screws are required, then you have to have to carefully unlock the flat strip connectors for the keypad and touch screen.
    You can usually find
    helpful exploded view diagrams and order parts by entering your full
    model number
    here.
    There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connectors.
    Then the keypad strip will lift out.
    To replace it, put the keypad strip back in, making sure both sides are down fully.
    While holding the strip down, push the connector back down to lock it.
    Problem Solver:
  • 11 Answers
It's very easy to do if you can get the circuit board. Take the two screws out of the plastic fan grill and pop it off. There should be one screw above the control panel. Take that off and the panel should pop off by slightly pushing up. Unhook all the wires and unscrew the board. Put the new board in and your done.
Posted on Jan 28, 2009
MT4110RPQ-0 Built - in microwave in our Camper. (Serial FGR202317) Something happened and all of the sudden the microwave doesn't work at all. I do not know if buttons were pushed prior or not! Now...
Cdfacc, we're sorry to learn that your Microwave is not working. We'll be glad to further review your concerns. Please email your name, contact number, address, model and serial number to Whirlpool_Reviews@Whirlpool.com.
Oct 23, 2017 | Whirlpool Microwave Ovens
WHIRLPOOL MICROWAVE GIVING F-7 CODE
hello sir
you are right magnetron is fully interrupted....... but tell me  !. do you want to repair machine( 4 sec problem) 2. do you want to buy inverter , magnetron  please tell i am ready to help you sir
I believe that is a microcomputer board failure. You will have to replace this board. Website below.
I have gotten parts from "repairclinic" on line and they worked fine. I saved $600 on the last repair of an oven. Good luck.
or sir you can find and fix each and every type of code error
http://www.applianceaid.com/micro_faultcodes.html#WLP
Oct 18, 2008 | Whirlpool MH6140XK Microwave Oven
The led readout is not readable, the numbers are just partially lit
The control board needs replacing. The cost is usually 75 dollars and up just for the board. You can order it from your neighbourhood appliance parts store. Just give them: Manufacturer, Model, Serial no's.
Changing the board can take about an hour. It is an easilly replacable module.
Jan 20, 2010 | Sharp R-530ES Microwave Oven
Whirlpool Microwave Oven Serial Number MH660XW-0
Hi Adam,
Built in over the range? The models change so rapidly unless it is less than a year old there probably wont be an identical replacement, Fortunately the mounting brackets remain close if you stay in the same brand. Whirlpools can be purchased at almost any retailer like Lowe's, Sears, BestBuy etc. Measure the the original and look for one that fits that dimension.
Eric
Jun 09, 2009 | Whirlpool Microwave Ovens
Replacing inverter board for my sharp R-2130JS microwave
I do not know how to specifically replace the "inverter board" in this model. On most microwaves I've repaired, though, the hardest part is getting them dismounted from the wall if they are rangehood models. I suspect that the inverter board is held onto the chassis with two phillips screws, and all the connections thereto are modular and therefore easily disconnectable and swapped out. The great majority of times, manuafactureres do NOT put multiple connectors of the same pin count and oriention on a circuit board. Give it a go.
Feb 27, 2009 | Sharp R-2130JS Stainless Steel 1200 Watts...
Need a replacement fuse for an Emerson Microwave Model MW8774
Please understand there are some liability issues that Emerson or their parts supplier have in selling you the fuse.
You should be able to find one by going online and searching with the terms you gave, using Google. I just did, and there are a number of hits to choose from.
Try Sears Parts Direct or Repair Clinic as well. You will need to enter your model number to find the parts listing.
In all likelihood, you have a failed controller board or microwave circuit (magnetron, transformer, diode, capacitor). Be prepared for additional troubleshooting.
REPLACE THE FUSE WITH AN EXACT REPLACEMENT> DO NOT REPLACE WITH A LARGER (more amps) FUSE TYPE.
Jan 16, 2009 | Emerson MW8777W Microwave Oven
GE JVM240 microwave - shut door, fan runs,can't set timer or cook
The "main" relay on the control circuit board is stuck (shorted) and needs to be replaced.
We regularly repair these control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Dec 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Daewoo microwave problem
The Daewoo model # is WM 1010CC.
The unit blows a fuse every time I open the door to get food out.
Please suggest a fix!
Bart Gibbons
Nov 03, 2008 | Daewoo Microwave Ovens
Kitchenaid microwave/oven combo model KEMC308KSSO
The keypad circuit board must be replaced to start. Sometimes, the fault can also be on the main processor board.
Jerry G.
May 15, 2008 | LG LMV2055ST Microwave Oven
All functions work except no heat
In this case I would most suspect the magnetron (or a bad connection at the magnetron) or a problem on the control panel.
But generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool GH4155XP Microwave Oven Logo
386 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
