Red lines going down the screen on Panasonic DLP projection TV
  • Televison & ... Master
  • 17,093 Answers
DMD board needs replaced.
Posted on Jan 01, 2013
  • 10 Answers
SOURCE: RED LINE GOING VERTICALLY DOWN THE SCREEN
control board
Posted on Jan 29, 2008
RFICKES
  • 51 Answers
SOURCE: Yellow lines going down the side of the screen
It's a warranty issue. Back to the dealer for replacement.
Posted on Jan 03, 2009
  • 1779 Answers
SOURCE: red line down right side of screen
I would have a tech come out and look at it. Sometimes the ribbon connectors from the upper or lower buffer boards have poor or corroded contacts. Should'nt be a major deal since it comes and goes.
Posted on Apr 21, 2009
  • 80 Answers
SOURCE: Red line on TV screen.
The LCD panel is defective...sorry I have to give you bad news.
Posted on May 21, 2009
  • 187 Answers
SOURCE: PERMANENT RED VERTICLE LINE DOWN THE SCREEN
Replace the timer control board
Posted on May 27, 2009
Red lines down the screen of my Panasonic DLP TV. Trying to see if there is a easy fix or not
rRED LINES INDICATE A WORN OUT CAPACITOR, EITHER, OR IF YOU TELEVISION IS AN LCD/LED it might be the screen it self
Jan 01, 2013 | Televison & Video
The tv has power , the volume comes on ,but no picture,just black screen. The red change lamp light has been on for some time,and it is still on
I believe this is a DLP set. There is a single high power bulb that shines thru the dlp chip and onto the screen. My old Panasonic 55" (forget the model) had the bulb access on the front left side-1 phillips screw to remoce the door and another to pull the light assembly. Replacement bulbs are available plain or in the assembly-your choice. Just google your make and model plus DLP bulb and you should be good to go- I paid $85 for the bulb alone- order 2 as the life span is much shorter than what panasonic claims- there was even a class action lawsuit over this issue that covered about 10 different set.
Dec 19, 2009 | Panasonic PT-51HX41 51" Rear Projection...
Picture goes away on my DLP TV
that is an overheating problem. With the TV unpluged clean and or vacuum the internal tubes. Not the lamp though. Do not touch the lamp as any oils on your hands will cause a hot spot and the expensive lamp will fail.
Dec 08, 2009 | Panasonic PT-50DL54 50" Rear Projection...
Panasonic PT-52LCX16 DLP TV color problem
This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Apr 26, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red blue and green not lined up
56 inch panasonic tv has blue yellow lines running up and down on right side
Apr 09, 2009 | Panasonic PT-56WXF95 56" Rear Projection...
Screen is fine when I first turn on TV, then goes black
Sounds like you dlp lamp is going out. That's a pretty old TV and if you are still running on the stock lamp this is exactly the type of thing that will happen. The lamp model for this particular tv is the ty-la1001. You can find that over here:
http://dlplamps.com/products/panasonic-dlp-lamp/panasonic-ty-la1001.html
Mar 21, 2009 | Panasonic PT-52LCX66 Projection Television
Red tube out!!!!
Your TV is not DLP it is projection it has 3 tubes RED /GREEN /BLUE cost of new tube $500.00 used if you can find one maybe $100.00
Feb 28, 2009 | Panasonic PT-53WX42 53" Rear Projection...
Help!backlight on tv is showing through the screen!
Contact panasonic directly, they will authorize a repair without cost to you. Just mention you heard that the set is in need of a (EPROM UPGRADE).....You have to have this done by a authorized repair center, Panasonic will set this up for you.
Jul 08, 2008 | Panasonic PT-52LCX65 44" HDTV
Red Horizontal Lines On Screen
Sounds like the DMD board, I would rather have Samsung to do the in home repair
Dec 27, 2006 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
