Machine will not start a new cycle
I have had this fromt loading machine for a couple of years now and it works quite hard 7-9 full loads a week.
The other day I had a power outage in that part of the house. I had to flip the saftey switch on that part of the house back on to regain power.
Since then I have not been able to get the washing machine to work. It makes a clicking noise a few times (that seems to be coming from the door region..like maybe it can not lock the door and is trying to) and then the light immediately shows next to "end".
Any suggestions?
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Expected longevity for Electrolux washer EIFLW55HMBO
The average lifespan of a washer, whether it is a top-loader or a front-loader, is about 14 years. This is determined by calculating seven loads of washing per week, or doing one load per day.
By the Numbers Washers are rated by how many cycles they can perform before they break. Each load is considered one cycle, so for a washer to last 14 years, it must be able to handle about 5,100 cycles. Of course, machines that cost less may only be rated at 4,000 cycles, while high-end machines may be rated at 8,000 cycles or higher. If possible, always check the cycle rating before you buy. You may find a bargain where you'll pay only a couple of hundred dollars more for a washer that is rated at twice as many cycles.
Stress The biggest cause of washer breakdown is stress. Overloading the washer puts stress on all of the extra parts, like the motor, the drive belts and the coupling. The harder these parts work, the shorter their lifespan. An 8,000-cycle washer can be reduced to a 1,000-cycle washer if constantly stressed with loads that are way over capacity. To prevent this, wash smaller loads and take larger objects, like quilts, comforters and sleeping bags, to a commercial laundry. This will limit the stress on the washing machine components and assure you of a longer washing machine lifespan.
Extend the Lifespan Wash less to extend the lifespan of your appliance. Even if you cut out just one load per week, you have automatically extended the lifespan of your washer. If you only do three loads per week, you'll effectively double the washer's lifespan.
Jan 13, 2017 | Electrolux Washing Machines
Trips breaker
I would suggest looking at the heating element for current leakage
Apr 04, 2014 | LG WM2655HVA 3.6 Cu. Ft. Graphite Steel...
My frigidaire stopped working
The bearings are bad. My sears kenmore did the same thing. Do you have hard water, that would be one cause. Or maybe it's still under warrenty because it is not a cheap fix.
Dec 31, 2009 | Frigidaire FTF530FS Front Load Washer
For the past several weeks the washing machine would quit once the tub was full of water. With a "gentle" opening and closing of the lid, the machine would resume it's cycle. Last week, it quit for the...
Open the control panel and check the fuse inside at the lid switch. Also check continuity on the lid switch and the micro switch. They are all located in the same lid switch block.
Check the position of the plunger that activates the lid switch. It can become dislodged with a off-balance load.
Aug 05, 2009 | Maytag Washing Machines
Shaking
Most common cause for the machine to shake during the spin cycle is due to a unbalanced load. A load of a couple of small bulky items or a small load in general may not be able to distribute the weight properly causing the machine to be unbalanced. It is best to wash full loads whenever possible. We have a brand new front loader as well, our first load about took the walls down...We just tossed a couple things in to see how it worked....thats how I learned to wash full loads. Now with the knowledge of why it shook so bad, we have had no more problems. Hope this helps
Please take the time to give this solution a fix ya rating
clarkco
Feb 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machine Shaking
Please take the time to give this a fix ya rating
clarkco
Washing machine quits after filling
I believe you need a new belt. The weight of the water is to much for a loose belt that is connected to the agitator.
2. Make sure nothing is blocking the safety shut off located on the machine.
Jan 19, 2009 | Washing Machines
I have a 20 year old Maytag washer. It is in EXCELLENT condition. We have never had a problem with it! A few weeks ago, the spin cycle began to have a growling noise resembling a bearing. It sounds like a...
Your old Maytag is a much better machine than the new Maytag's, but replacing the drum bearing and seal is a somewhat expensive and rather difficult job, requiring a couple special tools. Not usually a do it yourself job. Unless you really love that machine, it's time for a new one. The average life of a washer is about 9 years. Look into the front load models which use much less water and spin out over twice as fast as your old top load machine. LG is the top rated by consumer reports, but you don't have to buy the top of the line models to get the the direct drive motor with 7 year part warranty. Other companies make a pretty good product also.
Don't bother rating this "solution" as anything but a FixYa lowers my rating.
Dec 01, 2008 | Washing Machines
Kenmore 80 series heavy duty super capacity washer-new in 2002
HI colleen. thanks for the question. i know that you have been doing laundry for 30 yrs. i have been repairing for 45 years. they did not have daugs then. so the problem was not there. yes overloading is the cause . but if it wont go into the spin cycle . that could be the lid switch.
Oct 07, 2008 | Washing Machines
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
