Question about Garden
I need to know why fuel leaks from the bottom of my MTD 2M1 snowblower
  • 433 Answers
Most likely the needle seat seal has gone bad.
Posted on Jan 06, 2013
4 Suggested Answers
BAMOUT
  • 2478 Answers
SOURCE: need to view manual for mtd snowblower
Try www.managemylife.com
Posted on Jan 30, 2012
SOURCE: Auger stopprd working on an MTD snowblower.
The manual has a step by step procedure for adjusting the cables for the auger, speed selector and drivewheels. One socket wrench and about 10 min should do it.
My Yardworks is an MTD product and it's manual should be similar to yours. If you lost it, you can download it from MTD's site.
Posted on Dec 26, 2008
  • 26 Answers
SOURCE: Replacing the belts on a 20 year 8/26 MTD snowblower
you will need to take the housing off.
Posted on Jul 30, 2009
Replace snowblower belt
Locate the two top auger housing fastening bolts and remove. The auger housing will tilt forward and then lift the housing off of the bottom 2 bolts/bushings. You will need to support the traction frame as it will try to fall onto the handles.
Feb 27, 2017 | Mtd Garden
Snow blower dying out?
Its the carburetor. Needs to be cleaned. But try this first. On the bottom of carb is a round bowl with a bolt holding it on .If snowblower has gas in it clamp fuel line to stop fuel leakage. Remove bolt and pull bowl down slowly. Look in bowl to see if there is water at bottom under gas.To be sure dump out fuel and clean out bowl with clean rag and some air. Next place a small piece of tube in bottom of carb that you took bolt out to hold bowl on. Blow air in to remove any dirt and reassemble carefully and refuel carb and start engine. Good luck.
Feb 17, 2014 | Craftsman 21" 179cc* Single Stage...
Yard machines by mtd 11b-509n062 lawn mower is leaking gas from what appears to be a fuel line. The fuel line is a few inches below the gas cap.
Not sure what the question is. If the fuel line is leaking it is because it is not on the bottom of the tank well or it has a crack and needs to be replaced
Aug 10, 2013 | Mtd 22" Yard Machine Push Mower
I need a manual for my Yard Machine (by MTD) 2 stage, 12" impeller snowblower
MTD Yard Machine manuals are available online, but you'll need to locate and copy the model number and serial number, which should be on a model plate that looks like this:
When you have these numbers, click this link, and enter the information to download the manual for your snowblower:
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10451&langId=-1
If you can't locate the numbers, or they are difficult to read, it would be best to call their customer service department. They will know which manual you need. They can be reached at 1-330-220-4683, or 1-800-800-7310.
Jan 13, 2011 | Garden
I have a mtd 26" 8hp snowblower that need aufer
if the bolt broke off then you need to get old part of it out before putting in a new bolt.
Dec 12, 2010 | Mtd Products Yard Machines 158CC Tiller
MTD Snowblower starts good but runs very rough
Carb adjustment. There is usually a HIGH and LOW fuel mixture adjustment on the carb. Sounds like the LOW needs to be adjusted. Do a search on the Internet for a service manual for your particular model/make. Simple job IF you have the manual there for guidance.
Good Luck
Jan 26, 2010 | Mtd Products Yard Machines 158CC Tiller
Jul 30, 2009 | Garden
Mtd snowthrower fuel line leak
Possibly cut a very short piece of the old fuel line off and put it back on the fitting with one of those small spring type hose clamps.
Feb 21, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
