Question about Brother MFC 210C All-In-One InkJet Printer
Prints blurry docs - Brother MFC 210C All-In-One InkJet Printer
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 66 Answers
Change the cartridge problem will cartridge only.
Posted on Jan 02, 2013
Hp 5550dn prints text fine but pictures are blurry?
Don't replace but verify the condition of fuser assembly, if you found any cracks or folds on teflon roller or pressure roller causes the same thing, just verify get back to us...
Feb 01, 2012 | HP LaserJet 5550DN Printer
Prints letters blurry as if you pass the brush.
How blurry? Like toner can be wiped of or like the letters are verry light?
Did you check pressure between fixing and pressure roller, it could be the bad bushing that causes the problem.
If they are very light, clean optics.
Jun 30, 2010 | Canon PC170 Copier
How do I fix canon mx310 which prints with lines
please check doc. page setup, may be outline or outside margin resulting not space.
Apr 15, 2010 | Canon PIXMA MX310 All-In-One Printer
My HP D2560 does not print photos properly. Drawings are ok but photos are blurry, colours are weird. I changed the settings to photo printing, no luck. Any idea?
It does not appear in the user manual and looking on some forums, it will only put the date on the print and not saved with the image - to print the image with date you can do it with a docking station or some additional details - but cant find the full details
Apr 12, 2010 | HP DeskJet D2560 InkJet Printer
Will not print black on any word docs
the head may have got jammed....kindly remove the head and try cleaning it
Sep 01, 2009 | Canon PIXMA MP750 All-In-One InkJet...
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
Jul 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Prints blurry every other line with black color
Is it the ink cartridge contacts you already cleaned? If so, then you can also clean it using the tools menu from the printer panel:
-press setup menu, then go to tools
-select clean print cartridge and press ok
-it will print a test page. If the printout is good, you can try printing again.
I hope this helps.
Regards,
Feb 24, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Brother laser printer HL-2070N prints same doc over and over.
Hi Jeffery,
Can you give a little more info, you say the same doc keeps printing, do you know how many times you haved tryed to print this doc.
If you can get inside the print q and delete the print job.
then try a new print job it sounds like the same job is stuck in the Q
Jan 27, 2009 | Brother HL-2070N Laser Printer
BLURRY PRINT OUTPUT
The head probably needs aligning.
An interum fix is to turn off bi directional printing in the preferences.
This could possibly solve the problem.
Jun 10, 2008 | Brother DCP 115C All-In-One InkJet Printer
Fuzzy page continious.
Yeah I just read a tip. There seems to be a problem with the wave amp board, I will send you the engineering note. Sometimes though that encoder needs replaced and cleaning is not the total fix. The encoder may need replaced, but I found this also.
I just received this, this morning.
Failed Wave Amp
Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Historically blurry print was caused by oil on the drum encoder wheel. This can be caused by the wave amp board. A cracked capacitor on the board causes the wave amp to produce a malformed amplified wave signal to the printhead. This in turn causes the printhead to eject ink at the wrong times, so the prints look blurry.
You can generally distinguish a wave amp problem from an oily drum encoder. The wave amp problem will usually be an infant failure. The printer will start producing blurry prints soon after it is installed and running. With a failed wave amp all prints will be blurry with no improvement. The drum encoder, on the other hand, may produce good prints and then bad prints and then good prints. Blurriness changes depending on how the oil is interfering with the encoder.
May 05, 2008 | Xerox Phaser 8500/DN Printer
Brother MFC 210C All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
