Onkyo ht rc430 subwoofer problems - Audio Players & Recorders
4 Suggested Answers
  • 11800 Answers
SOURCE: My Onkyo SKW-520 subwoofer has
This is caused by the aging of a component from the amplifier - as they age the capacity gets lower = the resistance to the lower frequencies increases = the sound gets weaker.
To fix that you must open the subwoofer and check all the electrolytic capacitors from the signal path - all the way from the input RCA jack to the output of the integrated amplifier.
Posted on Oct 03, 2010
dunnbiker
  • 8546 Answers
SOURCE: hooking up our onkyo ht-r340 the subwoofer has 2
First would be to name the subwoofer so we can look at its "Line OUT's". The IN's would be more important as far as ITS function goes. I'm sure a manual exists for the unidentified subwoofer.
http://g-ecx.images-amazon.com/images/G/01/electronics/detail-page/htr340large.jpg
This receiver has direct subwoofer amplifer for a passive (unpowered) subwoofer as well as a Subwoofer Line Out for controlling an active (powered) subwoofer amp.
Posted on Jul 24, 2011
gregs_rockin
  • 274 Answers
SOURCE: onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Posted on Oct 20, 2012
Audio problems with HT-S7100.Sound only comes through center speaker and subwoofer. Sound is very tinny. Zone is off and can't be turned on.
Hi Tori,
Not sure if this has been resolved for you. If it has not please email me the units serial number along with a copy of the dated sales receipt so that I can see what options I have for you. Please email me at askOnkyo@us.onkyo.com, Thanks, JT
May 10, 2015 | Onkyo home theater system HT-S7100 User...
How to Connect HT-CN300 Subwoofer to Onkyo TX-SR313?
Hello! You will most likely need a RCA cable with single ends (both being male ends) One end plugs into your subwoofer input....marked subwoofer input on the subwoofer..........The other end will plug into your receiver that is marked subwoofer . When low frequencys from your media.....whether dvd,s /cable or audio cd,s is present the sub woofer will kick in , Make shure to adjust your setting on the rear of the sub if it has any like volume or frequency , most better subs have them as where the home theater in a box combo usually does not!
Jan 01, 2014 | Sharp HT-CN300 System
Onkyo ht-r530 subwoofer stopped working
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
Hooking up our onkyo ht-r340 the subwoofer has 2 line outs left and right back of amp has one subwoofer outlet. what to do
Jul 24, 2011 | Onkyo Audio Players & Recorders
I have 2 onkyo home theater systems, one is an older ht-r8230 with an skw-8230 powered subwoofer & the other system is a ht-r420 with s powered skw-420 sub. all i did was change the rooms the 2 systems...
It's possible that you have accidentally switched off the sub-woofer outputs on the receivers. Onkyo have a speaker set up test. You should run that and see if the speakers are on and that a signal is getting through to them.
May 28, 2017 | Onkyo SKW-110 Subwoofer
My subwoofer is not getting power to it properly. It keeps cutting out. Any suggestions??
The subwoofer was recalled, check the Onkyo website for information. It was a no hassle repair--they will ship you the box and mailing labels. Mine was working properly, but I sent it in for the recall anyway and had it back within 2 weeks.
That being said, when the subwoofer doesn't think it needs to work, like during prolonged dialog without music, it will shut itself off.
Feb 04, 2011 | Onkyo HT-S5300 Theater System
Connected home theatre system but no sound sub woofer
If the system uses a remote control, you may need to adjust the subwoofer out signal setting or turn on the sub in a menu, and on many systems, you can only access those settings via a remote control (you should check the onkyo user manual on how to do it).
Now, this is just one suggestion, it may work, but then again, it may not.
These could also be connection problems or some internal trouble in the onkyo sub signal output section or in the subwoofer input section, but hopefuly, it's just a "turn on" or "signal level" setting in a menu.
Good luck
3rq8 (triarcuate)
Jul 23, 2009 | Onkyo HT-S780 System
I have a onkyo HT-S7100. and when im watching my hd tv. i only hear sound out of the side, rear, and center speaker. not the center or the sub woofer. what do i do?
hello you need to check if subwoofer is working also make a test ..testing the outputs for subwoofer,dont forget to view a program using high bass and pay attention if it works........saludos
Nov 25, 2008 | Onkyo Audio Players & Recorders
Onkyo subwoofer not working
I fixed my subwoofer. The resistor at R16 (right next to the fuse) was the fried component. I removed it and replaced it with a 13K ohm 5 watt metal oxide resistor (from Mouser Electronics if not available locally). Works fine now. I got the solution and the circuit schematic from an audio hobbiest at diyAudio.com. This is, evidently, a fairly common problem.
Sep 17, 2007 | Onkyo HT-S780 System
63 people viewed this question
 Grubhead
Grubhead
