Beko WM5101W not draining
My Beko washing machine is not draining after spinning. Already checked pipes etc for blockages and can't find anything. Any ideas?
5 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: I have a beko eco
If you are certain the pump is working,hold the drain hose directly into a bucket or something similar and see how fast the water pumps out.
It should come out with a reasonable force, if it does not, then you have partial blockage somewere in the m,c.
Posted on Dec 05, 2008
SOURCE: The washing machine (model -
possible blocked or faulty pump does your outlet pipe go directly outside
Posted on Jul 31, 2011
  • 2006 Answers
SOURCE: I have an Indesit WIXL123 washing machine that
Since I have never physically worked on a Indesit, I can only tell you what a normal washing machince diagnosis would be: Drain pump is not functioning. Possibly something clogging the intake (count you socks) or just stopped working.
My supplier does not have Indesit parts so can't give you the part number for the drain pump.
Posted on Oct 03, 2011
gavi80
SOURCE: hi i have a beko
I had the same problem with the same machine, Theres 4 bolts you have to take out on the back that have gray rubber round then, there used to transport the machine from new but need taking out to use it or they make it shake, it will stop when you remove them
Posted on Aug 17, 2012
My washer wont spin
Hi if your Beko WME7247W washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor more Beko WME7247W test videos at site
Aug 08, 2014 | Beko WME7247W Washing Machine
Washing machine fills with water but then won't wash, spin or drain
Hi Claire if your beko washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Jan 28, 2014 | Beko Washing Machines
BEKO eco care WMA W10, replaced brushes still wont wash or spin,pls help
Hi if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Apr 08, 2013 | Beko Washing Machines
Duets washer won't drain
Probably a blocked filter, outlet pipe or pump.
Take the drain hose and lay it flat and lower then the level of the drum and this will drain the machine providing the blockage is not solid. When machine is empty check filter , pipes and pump and remove any blockage found.
Replace drain hose and you should then be able to carry on with your wash or spin the clothes.
Dec 28, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine wont begin a programme
Hi sam this might help if your beko wma10w washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
May 17, 2012 | Beko Washing Machines
My beko 1613 washing machine wont drain, and how do i operate the dial
Hi if your beko 1613 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below. At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
Mar 10, 2012 | Beko Washing Machines
Wont do final spin
you might find this test video helpful but only do it if you have checked the motor more beko test videos at site
Dec 02, 2011 | Beko WME7247W Washing Machine
My beko washing machine is stuck on the end spin cycle and stops and starts a spin in short bursts.it has water in it and wont move on from this.
Hi jennyandeddy,
Most likely your washing machine is trying to drain, but cannot, and as such cannot start to spin.
Please follow my Tip below, for detailed directions on how to access, drain & clean your Drain Pump Filter (Please Note: Your Filter compartment is located at the Bottom Right):
DRAIN PUMP FILTER
Hope this helps :-)
JEDEMEYER1
* If you found this solution helpful, please rate it
Jul 13, 2011 | Washing Machines
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
