Question about Frigidaire FMV157GM Microwave Oven
Magnetron for frigidaire oven microwave - Frigidaire FMV157GM Microwave Oven
3 Suggested Answers
  • 1768 Answers
SOURCE: Frigidaire FMT 148GP Microwave oven. Turntable
1. the motor to rotate the glass table in the micro wave may have stop working or the switch to the motor is defective.
Posted on Mar 13, 2010
walesarumi
  • 6993 Answers
SOURCE: I'm looking for a repair
The truth is that the repair manual for your Frigidaire microwave is not available anywhere online. The manufacturers of this unit did not make it available. I went further searching and couldn't find any.
I would suggest you contact the manufacturer of this unit via phone or e-mail and request for the repair manual from them. They might give it to you or direct you to a dealer where you can get the repair manual.
This is the best you can do to get the repair manual you are requesting for.
Go to Frigidaire's website, check "Contact Us" and you would see their e-mail and phone number.
Additional information concerning your Microwave's Magnetron;
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Testing a magnetron
NOTE: Before you test this component, make sure your microwave is unplugged, and that you have discharged the capacitor.
There are two tests to conduct in order to determine whether or not a magnetron has become defective. If you receive results other than what are detailed below, you will have to replace your microwave's magnetron. Each test is described for you here:
TEST 1: Locate your magnetron and label each of the wires attached to it so that you know which wires are to be replaced where. Set your ohmmeter to the lowest resistance scale. Take a resistance measurement between each of the magnetron's terminals by touching each probe to one terminal each. Reverse the probes and take a second resistance measurement. Each measurement should read less than one ohm.
TEST 2: Set your ohmmeter to its highest resistance scale. Touch one of the meter's probes to a magnetron terminal. Touch the other probe to the metal magnetron housing. Take special caution to not touch the two probes together. This could result in an inaccurate reading. This test should produce a reading of infinity - indicating an open circuit.
Read the tips on the below links on how to replace your microwave oven's diode and how to discharge the capacitor.
http://www.fixya.com/support/r7088355-replace_microwave_ovens_diode
http://www.fixya.com/support/r7088317-discharge_microwave_ovens_capacitor
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged.
Good luck.
Posted on Jan 13, 2011
Fuse location
Good Afternoon Friend, that's a great question!
Depending on the model of your Frigidaire microwave, the fuses are typically on located behind the control console, on the magnetron or on the oven capacity. However, if your microwave does not heat, you may possibly have a faulty control panel, magnetron, or experiencing an issue with the power supply. Please confirm that your microwave is plug into its own outlet and that you are not using a GFI outlet. Hope this helps! - Z
Sep 01, 2014 | Frigidaire FGMV174KF Microwave Ovens
Replacing the magnetron on a microwave
Good Morning Friend,
I understand that you want to replace the magnetron on your Frigidaire microwave, model# FMV156DC. Typically, this is not a do it yourself repair, as there are no step by step instructions, and could potentially be hazardous. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine if it is just the magnetron that is needed or if there could possibly be different or more parts that are needed. Hope this is helpful.
-Best Regards-
WP
May 28, 2014 | Frigidaire FMV156DC Microwave Oven
All Frigidaire PLMVZ169GCC Microwave Oven problems
Hello Roger Oesterling - If the microwave is not heating properly, it could possibly have a faulty control panel, magnetron or an issue with the power supply. Contact a professional to move forward accurately for a proper diagnoses.
Jan 01, 2013 | Frigidaire FMV156DC Microwave Oven
Microwave is not heating
There are three parts that will trigger this problem, the magnetron "common issue" or the high voltage capacitor and diode, if the magnetron is the problem it is cheaper to replace the microwave oven for a new one.
Mar 10, 2011 | Frigidaire FMV156D Microwave Oven
Frigidaire MIcrowave does not heat food and it makes a noise
The usual answer here is that the magnetron has failed and is trying to blow the fuse. This seems to be a common failure with Asian manufactured magnetrons. The cost of a typical repair may induce you to purchase a new machine. Hope this helps!
May 14, 2010 | Frigidaire FMV156EM Microwave Oven
MICROWAVE DOESNOT WORK TIMER AND LIGHT WORK
firstly check your fuse by the magnetron if its right check check the diode by the capacitor and still not working the magnetron
Mar 25, 2009 | Frigidaire FMV156DC Microwave Oven
My Frigidaire over the stove microwave not heating food
Hi,It is most likely the magnetron and diode that has to be replaced. This job should be done by a tech, High voltage. Magnetron's normally have a five year warranty, check your owners manual.
Mar 20, 2009 | Frigidaire FMT148GP Microwave Oven
Frigidaire Professional series microwave won't heat
The most likely problem is the magnetron. Check your warranty in owners manual, I believe you have five year warranty on magnetron.
Mar 15, 2009 | Frigidaire FMV156DC Microwave Oven
Frigidaire FMV157GM Microwave Oven Logo
21 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
