Question about Logitech Webcam
Translucent yellow band down centre of recieved picture.
My received picture from my contacts has a yellow translucent vertical band running down the centre of the picture. It occupies 20% of the incoming picture.
    President:
  • 8,637 Answers
Normal 0 How much memory is installed in your computer? The camera uses quite a bit of your memory to operate properly and would cause the poor video. Could be other
Issues, but worth checking.
Hope this helps. Bud
Posted on Feb 06, 2009
Can you give me pictures of where to add brake fluid on a 2000 chrysler voyager van se
under the hood on the drivers side at the firewall under wiper over hang you will see a cap, usually yellow in colour, this is the master cylinder. you can see the full mark on the translucent reservoir. remove the cap and fill to level mark.
Aug 23, 2014 | Cars & Trucks
How to change setting picture just opposite
If opposite means that you want to rotate the image or picture for projector mount in the ceiling.
KEYS location: (keys are located back side of the projector there is 2 keys 1 for menu and second is a joystick witch have 4 arrow keys and center press is a enter key)
Press MENU button to display the menu screen.
then use joystick UP and DOWN to select the OPTION menu. Press joystick for ENTER to display the option screen. Then press joystick UP and DOWN to select INSTALLATION.
Then press joystick RIGHT and LEFT to select your required image rotation there is four type of rotations.
1. FRONT DESK
2.FRONT CEILING
3.REAR DESK (A translucent screen is required for rear projection)
4.REAR CEILING (A translucent screen is required for rear projection)
If opposite means negative to positive so there is no any setting in your projector witch is chang your picture or image positive to negative.
Jan 21, 2011 | Panasonic PT-LB60NTE LCD Projector
My Viewsonic N3751W lcd TV has a @2" vertical
you need to clean the vedio connector properly inside your tv , if you dont have good idea about electronic you need a technicien
Dec 29, 2010 | ViewSonic N3751W 37 in. LCD Television
My Monitor, which had never been used but been in storage for about 1 year, has a 2 inch translucent vertical pink stripe down the left hand side. Rest of image is perfect. Any idea how to make this go...
Check the RGB settings from the monitor panel.... Plus try moving the neck of the monitor left and right a couple of times.... Sometimes, the picture tube displays illegitimate pictures with some twisted cables or so...
Jan 09, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Light red translucent stripe at top of screen
On your Remote
>menu
>parental controls,favs & setup
>system setup
>display
>centering
You can use this screen to move your picture up a bit and get rid of the line. If it doesnt work the first time, move it a little more. Good Luck!
Aug 03, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Yellow stripe
perdi o cd de instalacao...eu queria saber onde posso encontrar o drive para instala-lo
VF-0050
creative
agradeco muito quem conseguir isso para mim
Jun 08, 2008 | Creative Labs WebCam Live!
Green translucient vertical bar on left side of screen
Cover green CRT lens with towel and see if red/blue video is normal......= bad CRT ?.............................T.
May 09, 2008 | Toshiba 57H82 57" Rear Projection...
A small dark blob, exactly circular, translucent, fuzzy outline, which is on every pic.
Same problem here too! dark spot and what looks like dust appearing on all pictures. Comes into sharper focus on extreme zoom.
Feb 24, 2008 | Ricoh Caplio R6 Digital Camera
Scanner screen
open the top glass cover,after that u can see the lamp assy ,on the banx
ck side of that assy there are some mirrors,clean all that mirrors with a cotton bud ,fix it again n chech\
do revert
th
Jan 26, 2008 | Umax Astra 2000U Flatbed Scanner
Logitech Webcam Logo
73 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
