Question about Sunbeam Oster CKSTBRTW20 Bread Maker - Expressbake 2 lb Capacity
Kneading blade comes off during breadmaking process
We just bought a new breadmaker, the bread doesn't knead like it should and when it is finished baking, the bread is not fully mixed. The blade is off. When you first slip on the blade before baking, it does not fit firmly, it easily slips on and off could this be the problem?
    Genius:
  • Sunbeam Master
  • 1,280 Answers
Yes, if the blade come off then your bread is not going to mix and knead properly. The blades on all makers are designed to slip on and off though so you can remove them for cleaning etc. Be sure you are pushing the paddle all the way on. If it still comes off when mixing that would be very odd as the weight of the dough ball itself helps keep paddles on. I have owned dozens of machines by different manufacturers and never had a paddle come off in process.
Posted on Jan 01, 2013
  • 3 Answers
SOURCE: Kneading Blade chattering
I had the same problems with another manufactures model. I found that the bread pan needs to slot in the machine only one way. The pan will fit in the machine with the handle both vertical and parallel to the front. However to stop the clacking noise I found that one way in the machine..it makes noise, the other way it doesn't. You'll have to try. If it makes noise, open the lid and turn the bread pan 45 degrees in either direction and secure it back in the breadmaker then close the lid. I hope this helps. If it does, remember how the pan is in the machine for next time to avoid the noise.
Posted on Jan 18, 2009
  • 4 Answers
SOURCE: kneading blade keeps baking into the bread- help!
Watch/listen to the machine your machine. After the last knead cycle, remove the paddle from the bake pan before the dough rises, continue to bake as normal.
Posted on Dec 15, 2008
SOURCE: Kneading blade stays in the bread
I had that problem with my Zoji breadmaker. I sprayed a little non-stick spray on the blad and it worked. You can also spray the pan.
Posted on Jan 06, 2009
  • 433 Answers
SOURCE: Kneading blade stuck
The little bearing that turns the paddle is frozen. You will need to get a new bread pan. This happened to me after 7 years of use. If under warranty have them replace it. It was about $25.00 for a used bread pan on ebay, so I just bought a new machine at Wally World (Walmart) for $52.00.
Hank
Posted on Aug 06, 2009
  • 670 Answers
SOURCE: How do I keep the kneading blade from staying in
You could try to take out the dough after the breadmaker is finished kneading the dough into a bowl. Then rub some butter or margarine on the paddle and inside the paddle. Return the dough back into the pan to continue the rise and bake cycle. This should keep the paddle from ripping a big chunk of your bread when you remove it.
Posted on Aug 16, 2010
I have had a Panasonic breadmaker from Jan 2009 and it has been in regular use without problems. Recently on several occasions (not consecutive) the dough paddle has become detached during the mixing...
The kneading blade on the Panasonic bread makers is designed to fit loosely. If the dough is 'stiff' the kneading blade may stay in the bread when the loaf is removed from the pan. Allow the bread to cool completely before removing the blade carefully. Some types of flour absorb more water than others, so you can try adding an extra 10 - 20ml of water next time to see if this results in a slightly less 'stiff' dough.
This problem can also be caused if crust has built up underneath the blade. Make sure to wash the blade and its spindle after each use.
Trust this is helpful. Thank you for using FixYa!
Oct 19, 2011 | Panasonic Kitchen Appliances - Others
Where can I find a replacement kneading blade for my Mr. Loaf breadmaker
I'm sorry to point this out but how can your issue possibly be about a "Problem with the Betty Crocker BCF1690 Bread Maker"?
That being said...
Use your make + your model + your model number (omitting any dashes, slashes, or spaces) + the words KNEADING BLADE DOUGH PADDLE as your Internet search.
Example: For the Fredericks Home Bakery model KHB-178 enter your search as
FREDERICKS HOME BAKERY KHB178 KNEADING BLADE DOUGH PADDLE
Happy Hunting!
Note: Breadmakers model numbers are usually located on the backside or bottom of the unit, either on a printed decal or raised plastic embossment, and usually followed by abbreviations such as mdl, mdl no, model, model no, type, style, art, art no, article no, cat, cat no or catalog no.
Jun 21, 2011 | Betty Crocker BCF1690 Bread Maker
The post holding the kneading blade came out of bread pan
The sealed bearing on the bottom of your pan is broken. There is no fix for it...sorry. If under warranty sunbeam will replace it. Try looking on eBay for a new pan. ( I have same model as you and the bearing froze after 5 years of heavy use. The pans on eBay were very expensive, so I bought a new Sunbeam iat Walmart in New Hampshire for just under $50.00 and no tax).
Dec 12, 2009 | Kitchen Appliances - Others
Hank
Aug 03, 2009 | Sunbeam Kitchen Appliances - Others
Broken kneading blade 6725
kneading blades get stuck in the dough and have a hard time removing the bread from machine when done
Mar 02, 2009 | Regal Ware K6725 Kitchen Pro Bread Maker
Kneading blade cooks into the loaf
Hi Jessica,
As I read the manual, under the Care & Cleaning section,
"2. If the kneading blades remain in the bread pan, grip the kneading blade and
pull straight up to remove......"
Based on the diagrams and instructions, I don't think you're supposed to pull the blades before baking...why do you want them out? Cosmetics?
If I can be of further assistance, let me know. If this solves the issue, please rate it accordingly.
Thanks in-advance for using Fixya.com,
Jon
Jan 08, 2009 | Black & Decker B2300 Bread Machine
Need kneading blade for old Regal auto breadmaker K6773
Nope, haven't solved the problem yet. I got into the wrong category of breadmaker: mine is a regal K6773 "Automatic Breadmaker."
Dec 16, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Need replacement for kneading blade
I had great success in finding what I wanted for my breadmaker at http://breadmakerpartsemporium.ioffer.com/. They have manuals and parts for most breadmakers at very reasonable prices.
Nov 09, 2008 | Chefmate TR 7000 Bread Maker
Kneading blade
Oct 08, 2008 | Regal Ware K6725 Kitchen Pro Bread Maker
Sunbeam Oster CKSTBRTW20 Bread Maker - Expressbake 2 lb Capacity Logo
254 people viewed this question
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
