Question about Compaq 331224-001
User guide 331224-001
I have a mainbord bud no user guide bv. powerled on swits hddled
Does not beep to show problems
You have an optional or failed delivered part , a little buzzer to connect black with 4 points connector . so like i show to you some mainboards are delivered without an onboard buzzer.
This is NOT mounted on the audio output i think you know that also but the place near or above the hddled, reset and powerleds connectors connector or sometimes on the same bus. look the manual
Jan 03, 2016 | Computers & Internet
Cls1110 hold mon
Here's a link to the user guide http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0CDQQFjAB&url=http%3A%2F%2Fwww.axcesstechnologysource.com%2Fmanuals%2Fcls_series_userguide.pdf&ei=1K6uVN3bIYikNsykg6AK&usg=AFQjCNHicPhdIfAnW0RvYf03G6KeqBqkBA&sig2=prqdNr24Qi09zfv9PolaTg&bvm=bv.83134100,d.eXY
Feb 19, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
User guide motherboard samsung alioth-50 r1.09g
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCsQFjAA&url=http%3A%2F%2Fwww.samsung.com%2Fau%2Fsupport%2Fdownload%2FsupportDownloadMain.do&ei=uBelUoGmNdGXiAfHo4D4DA&usg=AFQjCNEYbDs1DSSDFLOAiz-qdpHqrdMWVA&bvm=bv.57752919,d.aGc
Dec 08, 2013 | Computers & Internet
Jumpersettings ex761 front panel
On the pins marked on the motherboard. The location on the motherboard varies from board to board. Your motherboard manual will show you. If you don't have a manual go to the board manufacturers website and look in the support section.
Feb 05, 2013 | AOpen XC Cube EX761 (95EX7692Z1) Barebone
I have five wires off my computer. hddled reset switch turbo led powerled and key lock and one other wire red and black comming out of the fan It as gave to me and i m trying to fix it>
You need to check your motherboard. Look for a manufacturer name and a serial number. Google it and look for manual. There will be a bunch of pins on the motherboard in a cluster and these connectors fit onto those. The motherboard manual will tell you exactly where. The writing on the motherboard is usually far too small to say which pin goes where. The fan will either be a case fan or a cpu fan. There will be a set of 3 pins in a line on the motherboard and labelled. If it is a case fan dont put it on the cpu fan connector. You will have to peer to find it. The manual will help considerably with the location, but these are usually readable on the motherboard unlike the hddled and powerled etc.
Mar 07, 2008 | Computers & Internet
Compaq 331224-001 Logo
21 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
