Question about Maytag Neptune MAH7500WH Front Load Washer
Display keeps flashing
Hi, the display keeps flashing on and off. The touch pad is unresponsive. The only way to stop the flashing is to unplug the cord. Is there any way to reset the machine or is the problem more severe. The problem started when I opened the door to put in another load. Thanks. DZ
  • 2 more comments
  • plsehelp Jan 02, 2008
    I have the same problem and it just keeps happening. 1.unplug 2. replug after an hr or 2 begins blinking and if i keep trying to press button it comes on and I can get it to do one load and then I have to begin all over again. Is this a computer issue or display issue? Any clue would be helpful. Thank you.
  • tstony Jan 13, 2008
    I have the same problem and when I plug into another outlet everything is OK. Plug back into original outlet and flashing continues. Outlet tests OK with 119 volts. Really confused...
  • rarose13 Feb 14, 2008
    I have the same model MAH7500WH problem and nothing but patience seems to work. If you wait long enough it will start to work again for a load or multiple loads but you cannot depend on it to be ready to wash when you are. It has a mind of its own. I've tried all the above mentioned solutions but if they work at all it is only temporary.
    I have had service out and they said it was the control board (computer) which now has a list price of approximately $500. They would discount slightly but still nearly $500 for the service. You can buy a very good top load washer and even a low end front loader for that price. I still haven't made up my mind as to what to do. My wife will not allow a mis-matched pair so I would have to invest in a washer/dryer set. The dryer has performed well.
  • bitbngr Mar 06, 2008
    Having the same problem, with the same results, as rarose13. I've noticed that the problem happens more frequently when the dryer is running, which is on the same circuit. I can usually resurrect the washer by holding my finger down on the display panel (seems to make the blinking stop sooner), and by plugging the washer into a different circuit than the dryer.
    Would love to know how to resolve this without a major investment...
  • 641 Answers
Try to unplug the power cord for few houres, and then plug it back, it might solve your problem. Good luck !
Posted on Jul 24, 2007
  • Dov Dror Aug 03, 2007
    Do you still have this problem or it was already solved ?
    In case it was solved,it will be nice if you will let us know how !
Hi, I have Sharp SPC 182 clock, which is not turning on..just a flickering display with beep keeps coming when plugged in..
If the display is flickering I would consider it being a bad main circuit board. If it just keeps beeping when power applied could be a bad touch pad too. Unplagging the pad and reapplying power and see if it beeps with the pad unplugged that would tell you if is the board. If it still beeps with the pad unplugged it is a bad board. It may be thinking your standing there pushing a pad. Either get both or replace the unit. Prices have come down drastically. Encompass parts was selling parts for those, sorry I do not currently have their number.
Jul 02, 2018 | Sharp Microwave Ovens
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
My htc tytn II screen suddenly became unresponsive to the stylus or even my finger. I can only open my screen lock through the keyboard which worked but takes longer time to use. many commands can only...
Hi. You need to replace the digitizer. This happens to many touch screen phones from all brands.
you can purchase from:
http://cgi.ebay.com/US-NEW-HTC-TyTN-II-TILT-8925-TOUCH-SCREEN-PAD-DIGITIZER-/350435156469?pt=LH_DefaultDomain_0&hash=item51979021f5
After purchasing you can have it replaced in a cell repair shop or similar shop. Or you can chose to replace it yourself.
Thank you for using fixya.
May 24, 2011 | HTC TyTN II Smartphone
Operation manual is lost, how do I set the clock?
The manual for the Magic Chef MCD1311ST Microwave can be downloaded in pdf format from the following site (follow the link then click the "Manuals" tab):
http://www.mcappliance.com/mwodetailpage.aspx?ModelName=MCD1311ST
If you don't have time to download, here's what the instructions state:
SETTING THE CLOCK
When the oven is first plugged in, the display will flash ":0" and a tone will sound. If the AC power ever goes off, the display shows ":0" when the power comes back on.
1. Touch CLOCK pad.
This is a 12 hour clock system.
2. Touch CLOCK pad once more.
This is a 24hour clock system.
NOTE: This oven has multiple clock system. If you want 12 hour clock system, omit this step.
3. Enter the correct time of day by touching the numbers in sequence.
4. Touch CLOCK pad.
The display stops blinking, and the colon start blinking. If you selected 12 hour clock system, this digital clock allows you to set from 1:00 to 12:59. If you selected 24 hour clock system, this digital clock allows you to set from 0:00 to 23:59.
5. Touch STOP/CLEAR pad.
NOTE: If you attempt to enter an incorrect time, the time will not be set and a error signal tone will sound. Touch the CLOCK pad and re-enter the time.
Jun 28, 2010 | Magic Chef MCD1311ST Microwave Oven
Touch pad not working properly
That sounds like the interface controller which is just a little computer chip that cotrols everything and watches the signals from the touchpad is having problems. Usually these will behave like this and then just stop so your touchpad is totally dead. It may take out the time displays as well.
If you have warrenty from GE or the store it will be covered. If you are not covered then it can cost about the same or more as a new microwave as they will have to replace the board. Check your warrenty's, then check the repair cost and check replacement costs. Usually a new microwave is the cheapest.
Apr 28, 2010 | GE JVM1740DM Microwave Oven
After cleaning, display flashes F7 and it
HI. This code is referring to a failed function key(s). These key are located on the control board. Replace the touch pad or if touch pad is part of the clock(main control board), replace the clock (ERC).
F-7 Function key(s) shorted or stuck
Dec 07, 2009 | Jenn-Air Kitchen Ranges
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Advantium 120 (Display Pad is not Illuminated or Working)
try removing the touch pad/switch membrane and cleaning connections on ribbon cables. if problem still exists replace switch membrane.
Phil
Jun 11, 2009 | GE Advantium 120 Convection/Microwave Oven
Maytag Neptune MAH7500WH Front Load Washer Logo
147 people viewed this question
Top Maytag Washing Machines Experts
Sheldon Dedek
John Tripp
John Tripp
Donni Steen
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
