Question about Polaroid TDA-03211C 32 in. LCD HDTV
The remote needs to turn on tv - Polaroid TDA-03211C 32 in. LCD HDTV
  • Polaroid Master
  • 8,617 Answers
If your'e meaning the set turns on with the remote and works but will not turn on by the power button on the TV itself. Then it would be an issue with the front controls pcb possibly bad tact switches, connections or other issues. But the front control board will require replacement if your symptoms as I described above. If so you can get the front control boards from www.tvcircuitboards.com
Posted on Jan 01, 2013
Need help programing my vizio tv to a blackweb universal remote
You don't program the TV to the remote, you program the remote to the TV
Find the Vizio codes on the paperwork that comes with the remote. There will probably be several codes. You need to try each one. Before programming turn the TV on manually. After put in each code try turning the TV off with the remote. Then try to turn back on and try volume up If OK everything else should work. Occasionally 2 different codes will turn off the TV in the test above. Use the one that allows the most functions to work
FINALLY not every "Blackweb" remote will control every TV You may need to get another one that specifically says it can control Vizio.
Jan 11, 2018 | Vizio Televison & Video
I need step by step instructions to program the codes into my One For All universal remote URC-4220 to my JVC tv.
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
Feb 12, 2011 | One For All URC4220 Remote Control
Programming the innovage remote
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Oct 04, 2009 | Innovage Jumbo Remote Control
Need instructions to add TV button to AKB36157102
1. While pressing and holding down the TV POWER button, press the CHANNEL UP or CHANNEL DOWN repeatedly until your TV is turned on (or turned off if you had it on). 2. Release TV POWER button when the TV turns on or off. The remote's TV POWER button will now control the TV.
Jul 19, 2009 | Televison & Video
Need code
Hi beebeehuf, I will be happy to help.
  1. Turn tv on.
  2. Press and hold tv button on remote
  3. While holding tv button press and hold power(on/off) button, led light shold go off then back on after a coupke of seconds.
  4. Release both buttons.
  5. Aim remote at tv and press the power(on/off) button every 5 seconds until tv turns off.
  6. When tv turns off press the stop button at bottom of remote, that will lock in the code.
  7. Turn tv back on with remote and test all buttons.
Let me know if this helps and please rate this solution.
Lone99star
Jan 21, 2009 | iLO 3200 32 in. LCD Television
Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Jan 16, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
TV will not turn off with remote or manually
That means that you either need to buy a replacement remote (or use an universal remote) , or you need to replace the TV IR sensor, that is a small board located inside tv.
Dec 15, 2008 | Hitachi 46GX01B 46" Rear Projection...
NEED CODE FOR TOSHIBA TV
Codes for Toshiba TV.... 159,178,109,120,181,105,049,095,170,260,358,394,902,012,095,117 and 141
Nov 29, 2007 | GE JASRM24912 Remote Control
Need code
try code 238, if it does not work you will need to try the code search.
1) turn on tv
2) press and hold "code search" until indicator light comes on
3) release code search
4) press and release "tv", indicator light should blink once
5) aim remote at tv and press the power button until the tv turns off (you may have to press it 200 or so times)
6) once the tv turn off, press enter on the remote
Nov 17, 2007 | RCA RC-U703SP Remote Control
Polaroid TDA-03211C 32 in. LCD HDTV Logo
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
