Heat pump will not turn on
Rthl 2510 honeywell thermostat on tempstar heat pump model number hps018a2c1. According to wiring diagram its correctly hooked up. Have a blue wire that is says not to use- if this type of heat pump has auxiliary heat feature? Hooked up thermostat in summer, conncected blue wire and air conditioner worked. Did not check heat. Tried heat recently with no luck. Rewired according to honeywell thermostat directions (on theory this tempstar unit has aux. heat). Now nothing works. The fan option where you can make fan run continuously will not even work. Went thru advanced programming options as well. No luck. Flipped all breakers on and off in fuse panel inside. Pulled exterior breaker on outside as well and reinstalled.
    Master:
  • Heating & Co... Master
  • 523 Answers
You probably opened the 3 or 5 amp fuse at the control board to the indoor unit. Wire it like you had it during the cooling mode to begin with. Find that fuse and replace it, 3 or 5 amp. Get it cooling again, then check you system/installer configuration to ensure it knows that is a heat pump, with aux. heat. The blue wire is usually used as a common wire, C terminal, to allow the tstat to work with no batteries, when C is used. As far as the manual no using the blue wire?... Not sure where it was wired in to begin with. If it was in the C terminal, put it back, won't need batteries. Hope this helps!
Posted on Mar 25, 2017
    Top Expert:
  • 78,267 Answers
I would call an expert, testing needs to be done, but based on what I have seen it may be the control board of the heat pump is defective.
Posted on Mar 24, 2017
  • 30 Answers
SOURCE: Honeywell TH8000 5 wire
7wires? wtf with that! how many things you got runnin there. you need to give way more info to get a decent reply.
Posted on Feb 04, 2008
jcpark50
  • 52 Answers
SOURCE: Need to know which terminals run what
Had similar problem, continuous fan, turn off power, then won't start up. Replaced thermostat, no change. The main controller board in the furnace went bad. What was weird was that it happened in the summer, while the heat was turned off. One day I noticed that the fan was running. The thermostat was in the off position, and I had to shut off power to the furnace to make it stop. I forgot about it till heating season came along and it wouldn't start up. The preliminary blower would start, the gas would click on, it would light, then quit. After tracing and checking the various safety switches, etc. it became apparrent the main board was bad. I found one on ebay, replaced it, [a simple job, unplug, a few screws, replug] and it's been working fine..good luck, John
Posted on Nov 07, 2008
  • 10 Answers
SOURCE: Properly installed electric baseboard heater won't work.
I am an electrician. You must measure the voltage across the black and red wires. Measuring each wire to the neutral will not cut it. If both your red and black wire are on the same phase the heater will not work.
To double check your wiring, measure the voltage across the two screws feeding your subpanel, they should be 240v or 208v depending on your power company. Then do the same at the breaker feeding your thermostat. Again it should read 240v.
If you have no potential across the screws it is possible that you installed an incorrect breaker. Not all breakers with two screws on them are 240v breakers. There is what is called a twin or split breaker that has two screws that are on the same phase. These are for wiring two 110v circuits, when you run out of spaces in the panel.
Double check everything. This is a relatively easy circuit to wire, even for homeowners. If the heater does not work them something is wrong so do not leave the circuit energized.
Posted on Mar 16, 2009
  • 5 Answers
SOURCE: Honeywell CT3611 thermostat, not working..
if you cross the two wires and you see a slight spark and heat comes on, then the problem is in the thermostat, if not then problem is at furnace it self.
Posted on Apr 26, 2009
SOURCE: thermostat wiring diagram for heat and cool unit
use an ON-OFF controller whose output can be given to themostat or a circuit breaker....
Posted on Sep 04, 2009
Need to know correct color wiring from goodman model gph1330h41 with heat kit to honeywell model th5220d thermostat. Thanks
here is the wiring from man. f you have trouble figuring out the programing or what terminals to use in thermostat there is an help phone number. Be shure to turn off all power to unit and thermostat, remove batteries from thermostat.
jl+ax8un4pr7j8pz3ifmkacgi5aaaaaelftksuqmcc
May 12, 2014 | Honeywell Electronic Programmable...
A 6 wire payne thermostat to a Honeywell rthl 3550,need to know where the blue-c wire and the o-orange wire go?
Orange is for a heat pump. c wire goes to common If you have a heat pump, otherwise just fold them up and tape them so they don't touch anything
Aug 31, 2013 | 2004 Mustang Factory Wiring Diagrams
I have a Trane 3AAT80B1A1 thermostat that I'm replacing with a Honeywell RTHL 3550D. Is it possible to do this myself or will I need to have an electrician come out?
The easiest way to be certain the wires get connected is to cut the wires close to the screw without loosening the screw. That way the color of the wire can be seen on the correct terminal without mixing them up.
Feb 24, 2013 | Heating & Cooling
Wiring a thermostat
Are you changing out thermostat? If so you must turn off power to your furnace or air handler. You should mark or write down each color and what terminal it was removed from. example= red from term r=green from term.=g yellow from y... Be careful, some thermostats are wired different according to type of system you have. Heat pumps are different than straight cools and the thermostats sometimes have setting or little switches. Honeywells have installer set up guides in package. Read it carefully
Sep 16, 2012 | Honeywell RTH3100C - Digital Heat Pump...
How to wire rth3100c to tempstar heatpump
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 26, 2010 | Heating & Cooling
Proper wiring for honeywell 6400 thermostat
depending on how they had it wired originally but there could be a switch on the back of the thermostat for electric
May 17, 2009 | Honeywell Programmable Thermostat Heater
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
I had an old thermostat that i had to change need wiring diagram
HONEYWELL WEBSITE:
Go to honeywell.com
Dec 20, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
