What oil to use on an american forge pro 2hp air compressor #92019
  • 82 Answers
SOURCE: HUSKY PRO AIR COMPRESSOR 30 GAL I NEED TO KNOW HOW
Depends on what plan it was made in...
If you have the glass type sight... Only to the max you can see (top of site), then run it for a few mins, let it sit for a few more mins then add more if the level is near the bottom of the sight glass.
If it's the dipstick model that pushed in, there will be an upper and a lower level mark (holes, or checkered section) Keep it between the top and bottom marks.
Finally if it's the older screw-in type, remove the dipstick and wipe it. Set it back in BUT don't screw it in. Keep within the range on the dipstick from that position. Then of course screw it back in/
Good luck
Posted on May 08, 2009
protek480
  • 1723 Answers
SOURCE: My PRO-SOURCE air compressor will not go over 50 psi
Your compressor has got a 'ring' problem. The rings on the pistons that compress air are leaking air by them and need to be replaced. Unless it's the 'pressure release' leaking. When it gets to 40 PSI or so, unplug it and listen for a leak. If no leak then it's the rings. inside on the piston. If you adjust the pressure switch all the way low, it might shut off near where it builds pressure to and you could at least use it some.
Posted on Sep 26, 2009
SOURCE: im looking for a replacement part for an american
don't have solution, but also need help/parts. I have American Forge Pro 5.5 HP upright air compressor (~8 years old). i can;t find any info on-line regarding. Was this air compressor made by another company and sold under american forge pro name? Only ID# on compressor is 88142 Can anyone help?
Posted on Jan 14, 2010
  • 1388 Answers
SOURCE: I need a maintenance manual for model HL700200 air compressor
The following address will provide you with all the info that you need to maintain your compressor. Good luck
http://www.chpower.com/webapp/wcs/stores/servlet/XItemDocuments?storeId=10051&langId=-1&catalogId=10001&findModel=HL7002
Posted on Jul 12, 2010
SOURCE: How much oil for 2hp 8 gallon central pneumatic air #95386
i'm not sure of the solution but what type of oil did you use?
Posted on May 29, 2011
Hitachi ec119sa compressor tipped over and oil is dripping out of air tank drain vlalve what do I do?
I would not worry. Drain the tank completely, and check the oil in the compressor, top off if necessary. Watch it for the first cycle.
Dec 02, 2013 | Hitachi EC12 Portable Electric 2hp Air...
Looking for a product or instruction manual for a Mongomery Ward 2hp air compressor circa 1970's approx. Has the art.no. xer6468 and serial #12039-215993 printed on the side. This is a 2 cylinder oil...
If you need to tighten belt loosen the motor and slide back until belt taut and should have about 1/2" to 3/4" in deflection. You might try ebay for manual
Jul 29, 2017 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Apr 10, 2010 | Air Tools & Compressors
Specific oil for hitachi compressors ???
They make compressor oil, but all you need is non-detergent oil, the little engine spins so fast that it will turn the oil into foam, real quick. I think 30 weight, single viscosity type stuff will do.
Feb 21, 2010 | Hitachi EC12 Portable Electric 2hp Air...
Im looking for a replacement part for an american forge air compressor need a manifold block that includes a regulator
Jan 12, 2010 | Rapid Air Tools & Compressors
I have 2hp 25 litre marksman electric compressor how much oil should be in it and how do you know when it is at the right level
either by the sight glass half full or by the dipstick touching the line on the dipstick (fillerplug) get back to me if need more info
Sep 30, 2009 | Hitachi EC12 Portable Electric 2hp Air...
My husky pro vt631402aj verticle compressor won't stay running when compression rises
Hello,check to see if it cuts off at the same psi each time.If so,youneed to adjust the pressure switch to the tank to the max & adjust the pressure to the tool you want to run with the pressure out kob.Hope this helps
Dec 29, 2008 | Chicago Forge AF5HV 30 - Gal. 5.0 - HP...
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
