Question about Food Mixers
How to replace gears on sunbeam mixmaster model 9
How to remove mixer gears from a sunbeam mixmaster model 9
Email or SMS Dave Holden.
mixmasterman@bigpond.com
SMS 0458018866
Posted on Feb 01, 2013
  • 3 Answers
SOURCE: Sunbeam Mixmaster model 9 speed control problem
OK, this may not be a solution, but might help you get there.
The speed control is NOT a potentiometer, it is a mechanical governer, and may be out of adjustment, or one of two components in the speed control mechanism has failed. The following is a test/ adjustment procedure.
During this procedure you will not be fiddling with electrical components (No risk of shock) You will be making adjustments with the motor running.
In the centre of the speed finder dial is a chrome cap. This can be *carefully* pried out. Be gentle, it's easy to chip the phenolic resin plastic.
Behind this cap is a nut around a threaded part with a screwdriver slot. Using a spanner and screwdriver to stop the centre part turning, loosen the nut some.
Turn the speed finder dial to 1. Plug the motor in and switch on. Whilst restraining the outer nut with a spanner, turn the central screw. From memory, it needs to be turned clockwise, that is, screwed inwards. The motor should respond by slowing down. Should you get no speed change, try turning the screw the other way some.
If you get a speed change, continue turning the screw in that direction until the motor stops. Now screw the other way until the motor just starts again.
This is the lowest speed and corresponds to 1 on the dial. Check the speed finder dial is still pointing to the 1 position. Lock the adjustment screw by restraining the central part, and turning the nut clockwise with the spanner until tight. Try turning the dial to see that the speed changes smoothly throughout the range. You may need to tweak the adjustment a little to get things just right.
Once you're happy with the speed control refit the chrome button, and you're done.
If you could get no speed change, one of two components under the speed finder dial has indeed failed.
Now you will need to determine just what the machine is worth to you. A motor specialist should be able to diagnose which part has failed. However, new parts will not physically fit and modifications will be needed. This could prove costly. If you know an inveterate tinkerer, you're costs could be substantially lowered.
Best of Luck.
Posted on Jul 11, 2009
  • 4 Answers
SOURCE: Regarding the Sunbeam Mixmaster (model
Pry the beater release button out with a screwdriver. There are two screws underneath it and one under the motor housing between the the beater holes. This will allow you to remove the chrome front cover, but not the motor and drive assembly. Getting to the part that contains the gears requires complete disassembly of the mixer. It is not designed for service, and requires patience and a variety of tools to disassemble.
It has a metal worm gear and plastic drive gears. If the beaters are out of alignment, then one or both of the plastic gears are stripped and the mixer is junk. Repair plus shipping costs equals the price of a new mixer. This is the weak point of these mixers and a fundamental flaw in an otherwise robust and sturdy design. It is definitly not the same mixer *********** bought 30 years ago.
Posted on Dec 16, 2008
SOURCE: beaters
changed my mind
Posted on Jun 24, 2009
greenspan
  • 1734 Answers
SOURCE: I need a User Manual
Check here, I guess they can get you virtually every Sunbeam manual
Posted on Jul 28, 2009
  • 44 Answers
SOURCE: Where can I find the Manual for Sunbeam Model 2350 350
http://www.sunbeam.com/ca/category.aspx?section=kitchen&cid=14
Posted on Sep 08, 2009
I need the internal gear set for the Sunbeam Mixmaster Model -10. Where should I look/
Chero, unfortunately because of the age of this unit Sunbeam stopped production of the internal parts.
Apr 14, 2012 | Food Mixers
Sunbeam Mixmaster... where's the model number?
Lift up the head, should be right by where you insert the blades
Jan 24, 2010 | Sunbeam 2366 MixMaster Series Hand/Stand...
Hello, I have sunbeam mixer model #2360 and had one large and one small turntable. I lost the large turntable and am unable to locate a site to purchase another one. Can you please help? Thanks, so much!
Sunbeam 2386 Sunbeam 2386 MixMaster Series 275 Watts Stand Mixer. Overall User Rating. 3.0. out of 5 ... 2386 Reviews & Articles. Sunbeam - Small Appliance Parts ... retrevo.com/s/Sunbeam-2386-review-manual/id/952ci071/t/1-2
Good luck_Ned_
Nov 03, 2009 | Sunbeam 2386 MixMaster Series Stand Mixer
My sunbeam mixmasters turntable is not turning
Hi Jill. Your mixer's gears are made of plastic and can't really handle heavy loads such as cookie and bread doughs. Contact Sunbeam Corp. to locate a parts place near you. You'll need to replace at least the large gear that turns the turntable base, possibly the worm gear that turns the large gear too. Grease these gears when you re-install the parts. You'll have to cut a couple of cable ties to get the machine apart enough to do the work. If this solution has assisted you, please rate it. Good luck! ricardok45.
Mar 09, 2009 | Sunbeam Food Mixers
Sunbeam Mixmaster Heritage Series Model 2350 speed problem
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
Dec 14, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Regarding the Sunbeam Mixmaster (model 2346): How do I remove the front cover of the mixer so that I may reallign or replace the beater gears?
Jul 18, 2008 | Sunbeam 2346 Heritage MixMaster Series...
Sunbeam mixmaster heritage series
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix.
You probably have to replace worn gears and or bearings.
Feb 20, 2008 | Sunbeam 2370 MixMaster Series Stand Mixer
Food Mixers Logo
173 people viewed this question
Top Food Mixers Experts
eyecam
Are you a Food Mixer Expert? Answer questions, earn points and help others
